O2 sensor replacement
Re: O2 sensor replacement
Post by windmill » Sat Feb 09, 2019 3:22 pm
Sat Feb 09, 2019 3:14 pm
The downside, especially for latter models, is a permanent MIL light. :(
Resistors can address that issue too.
Post by windmill » Sat Feb 09, 2019 3:26 pm
Subsnowden wrote:
Sat Feb 09, 2019 1:18 pm
I noticed the newer Urals have the O2 sensors much closer to the engine. Did they find that location to be better somehow?
Yes, they get to operating temperature quicker, and maintain it in adverse conditions such as rain, snow, and extreme cold.
Post by Mr Wazzock » Sat Feb 09, 2019 3:50 pm
If memory serves, it was to ensure they stay hot enough.
Post by eastbloc » Sat Feb 09, 2019 4:24 pm
I guess the other thing you might miss with the sensor unplugged are compensation for varying O2 levels at different altitudes?
'02 Patrol
Post by eastbloc » Sat Feb 09, 2019 6:17 pm
Albuquralque wrote:
Sat Feb 09, 2019 12:55 pm
Did you do any research on the O2 sensor part number?
https://www.amazon.com/Oxygen-Sensor-Ha ... B075DTWGF5
https://www.ebay.com/itm/28488580-Oxyge ... ctupt=true
Good find -- those look identical for $12 less than UralNE.
I did Google, Amazon and eBay search and found nothing, I must not have transcribed the number correctly.
Anyway, despite having new ones now I think I'll just leave them off for now since the running is so much better.
Does anyone know anything about wiring up resistors in place of the sensors might require? My cursory research suggests that other sensor-equipped marques actually ship with resistors in some markets, so this should be a viable alternative to those who don't want to stare at the MIL light.
'02 Patrol
Post by windmill » Sat Feb 09, 2019 6:28 pm
I've been reading up on it, and I think Dynojet may have a plug-n-play solution?
http://www.powercommander.com/downloads ... 007.01.pdf
I don't know which one specifically, but it's probably just a matter of matching connectors.
Post by Albuquralque » Sat Feb 09, 2019 6:36 pm
If Ural is using same O2 sensor as some harleys, then for sure there will me an Eliminator out there.
Post by Albuquralque » Sat Feb 09, 2019 6:38 pm
Google Power Commander Euro HD Eliminator
Post by windmill » Sat Feb 09, 2019 6:43 pm
Any experience with them? Are the connectors for a 14 the same as an 18?
A neat, easy, reversible solution, but $30 when I have 330 ohm resistors in my stash........
Post by eastbloc » Sat Feb 09, 2019 7:42 pm
The connectors are the same for 2014-2018.
I was thinking I would use my old O2 sensors as connector donors for a project, but I've got more money than I have time to muck about these days, so I bought a pair of these instead:
https://cart.dynojet.com/p-1521-active- ... ro-hd.aspx
I'll let you all know how it works out. Had I known about this option, and how good my bike runs without them, I might have passed on getting new O2 sensors altogether.
'02 Patrol
Post by windmill » Sat Feb 09, 2019 10:54 pm
Yes! Please do.
If you get a chance, could you post a picture of the connector? Don't know if they changed them when they upgraded the wire harness.
Post by eastbloc » Sat Feb 09, 2019 11:03 pm
Here you go.
'02 Patrol
Post by eastbloc » Sat Feb 09, 2019 11:04 pm
That's the O2 sensor side.
'02 Patrol
Post by windmill » Sat Feb 09, 2019 11:18 pm
Looks like they're the same
Thank you. :cheers:
Post by eastbloc » Sat Feb 09, 2019 11:26 pm
My guess is that in using this precise sensor and connector combination IMWA was taking advantage of the HD economies of scale. Changing it would likely incur unnecessary cost.
'02 Patrol
