2014 Patrol 1st Valve clearance Check
Re: 2014 Patrol 1st Valve clearance Check
Post by Mr Wazzock » Mon Mar 04, 2019 12:38 pm
hotflash44 wrote:
Sun Mar 03, 2019 7:41 pm
Gino, your Ural shouldn't ping unless you have bad gas IMO, as the timing is set at the factory on the EFI Urals.
Not wishing to quibble, :D but my understanding is the ECU's do all timing adjustments, and only need to know when each crankshaft revolution occurs as a basis, which is given by the crankshaft position sensor (CPS). So no timing settings to adjust, except in the software (I imagine).
:D
As you were . . .
Post by RC20 » Fri Apr 05, 2019 4:55 pm
Just a note: The post that said initial valve movement is to tight is correct. As the valves seat they get tighter.
Long term the wear will loosen them but short of major wear that is catastrophic, not early one.
Better a bit too loose than too tight, on start up things do not go even expansion wise and they can go to tight for a short time.
The adjustment was so easy, I wanted to do them all.
The worst valve adjustment was the KLR 650 with shim in bucket design. On that one I just checked them and was within spec. To adjust the valves you have to remove the overhead camshaft.
The exact reason I got the Nighthawk S back ion the 80s, bucket and shim sucks and you could not get the shims because they were not supposed to need adjusting - better yet the Nighthawk S was SELF adjusting!!!!!. Some very clever air removal to allow a 11,000 rpm readline with hydraulic adjusters.
The R80 GS ran bad at idle, I only found out when I started riding it a lot. I finally decided to do the whole tune up drill. Valves were god awful too tight, last service the dealer, they had a good shop so no idea why they screwed that up. They never were helpful. They felt you should bring it in, so they can do it wrong?
Post by Mr Wazzock » Fri Apr 05, 2019 5:39 pm
My 850 Guzzi went like that once. Rode like sh!t and was hot weather too. I didn't look at the valve clearances because I'd redone them at the last service. So no need to again so soon right? However since then new gaskets had settled and closed the gaps up. :oops:
Moral: must never assume ...
