2016 Gear up sidecart tire is leaning in
Re: 2016 Gear up sidecart tire is leaning in
Post by hotflash44 » Mon Jan 07, 2019 7:28 pm
Bullitt wrote:
Mon Jan 07, 2019 7:00 pm
Tomcatfixer I understand the two fixed adjustable struts but how do I swing the rear pivot up? I took my Ural for a 40 mile ride today all is well but I know it is not right. The sidecar and fender are level but the tire is leaning in at the top.I do not quite understand how to pivot it up to pull the tire vertical to the ground. Also thank all for your input.
im not a expert by a long way but when i was contemplating doing just this, my research showed that loosening the 2 bolts that are on the bottom of the side car u-joint cover where it connects to the final drive, then using a jack raise or lower the dog leg to get the wheel vertically straight. here is a video explaining exactly how to do this look at 3:15 mark approx link www.youtube.com/watch?v=lxq2pExzwmQ
Post by Tomcatfixer » Mon Jan 07, 2019 7:33 pm
If you don't also adjust the front up, then you're gonna place your tub in a nose-down orientation.
I mean, if that's the way you want it, then by all means, point that sucker down!
EDIT - The reason the front wasn't adjusted in that video is because the older Urals didn't HAVE an adjustable front sidecar dogleg! We live in such wonderous times: we can level our sidecars front-to-back, not just side-to-side! :clap:
Bullitt
Post by Bullitt » Tue Jan 08, 2019 12:05 am
I was hoping you would send pics! Thanks mine looks a little different but I get it. I thought that was what I should try but was not sure.
I'll give it a shot and get back to you all.
Thank you
God Bless
Ron Q.
Romans 1-16 For I am not ashamed of the gospel of Christ
Proud Gun Store owner
Family owned Bar-B-Q for 50 years
Ural 2016 Gear Up
Lt. Bullitt, Belgian Malinois my hack pardner,the wife won't ride with me!
Ron Q.
Kansas City Ks
Post by hotflash44 » Tue Jan 08, 2019 9:04 am
here is a real good one from Heindle engineering might be of use www.youtube.com/watch?v=42q0cOaMWGM :cheers: PS at about 1:20 mark notice the sidecare tire is about 1 deg neg cant.
Post by Tomcatfixer » Tue Jan 08, 2019 9:12 am
So is the wall of their workshop. Probably an illusion due to distortion from the wide-angle camera lens.
Post by hotflash44 » Tue Jan 08, 2019 9:42 am
don't think so ,look at the dust on the sc tire.could all be because the set up isnt together tho. :cheers:
Post by Tomcatfixer » Tue Jan 08, 2019 9:58 am
True; there's a little more dust on the outboard side tread than the inside. Jon's gonna have to lower those sidecar dolly struts to get proper shop floor hack alignment. :wink:
Post by harryball » Tue Jan 08, 2019 10:50 am
Lets just replace the connection to the bike with two large springs. Then the bike can lean a little, it would absorb more road vibration and over all be a superior solution. What could go wrong?
That's your cue to try it Chad.
heindlengineeringural
Post by heindlengineeringural » Tue Jan 08, 2019 11:20 am
Please note bike is still on the center stand at 1:20, once it drops to the ground sidecar wheel is 0 camber :D
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
Post by hotflash44 » Tue Jan 08, 2019 11:50 am
thanks for pointing this out, question what is the round tubular part called that the snowmen are attached to called? i want to say its a axle but it really isnt. once saw a member here that noticed the sidecar end was 1/2 in higher than the bike end and he felt making this part straight would make the sidecar wheel 0 camber. as his sidecar wheel had a 2 degree negative. :? :?:
Post by heindlengineeringural » Tue Jan 08, 2019 11:55 am
I would simply call that the sidecar frame. It has to be lower to allow for drive shaft clearance. It is possible to set one up incorrectly enough to where the shaft will contact the snowmen mounting location.
(937) 787-3686
Post by hotflash44 » Tue Jan 08, 2019 11:58 am
understand,does that alignment have anything to do with the sidecar camber?
Subsnowden
Post by Subsnowden » Wed Feb 06, 2019 2:37 pm
Sounds like one of your sidecar swingarm bushings has collapsed like mine. They “replaced” it under warranty and it’s still fubar’d. If Ural would make the swingarm forward mount bar about 1/4 inch or so longer it would probably stop it from happening.
Jon
Nomad
2015 Ural Gear Up
Bullitt
Post by Bullitt » Thu Feb 28, 2019 11:07 pm
Update: I adjusted my sidecar up on the inside and got the tire straight up but it did not seem right to cant it that much so I put it back where it was.
I fell out of warranty two days ago but could not get it to the shop because of bad weather so I guess i am on my own now.
Thank you all for your input.
Ron Q.
Ural 2016 Gear Up
Ron Q.
Kansas City Ks
Post by Tomcatfixer » Fri Mar 01, 2019 5:53 am
IMWA is typically liberal with their warranty period. I recommend that you make the attempt. Even if your local dealer is unmotivated to file the claim, there are dealers that will help.
