2016 Gear up sidecart tire is leaning in
Re: 2016 Gear up sidecart tire is leaning in
Post by Lokiboy » Fri Mar 01, 2019 10:08 am
My two cents and as most others have said. If it’s tracking straight then leave it alone. Mine has a 1° - 2° lean in at the top
I worried about my tire not being perpendicular when I first got my rig. It’s the wrong rabbit hole. Camber has nothing to do with the tracking of your rig. You can adjust the rear dog leg so the tire is indeed perpendicular, but as Heindl pointed out, the driveshaft will hit the snowman supports whenever there is any flex. You need to maintain a 1/2” inch or so clearance. If you maintain that clearance, the tire will not be perpendicular (at least on my rig)
When you get everything the way you want it, use a Dremel to mark the dog leg. That way you won’t need to guess if there is any movement, and provides reference points if the dog leg is moved in the future.
90,000 km and counting
Post by hotflash44 » Fri Mar 01, 2019 10:31 am
perfect description/suggestion IMO, i pretty much have the same situation and many folks here insisted that the wheel be 90 deg straight. my Ural drives and tracks perfect so i just moved on to other worries. :cheers:
