Hard starting '14.
Re: Hard starting '14.
Post by stagewex » Wed Jan 30, 2019 11:14 pm
So Urals ('14 to "18) are the only efi machines that can use or need starter fluid in extreme cold weather?
Yet another first for this manufacturer.
You know what... I guess whatever works.
1969 BMW r60/2 US model (Kick Start only)
Post by windmill » Wed Jan 30, 2019 11:57 pm
Still common for industrial, transportation, and military applications.
http://quickstart-ether.com/
Block heaters are still common for cars too.
Urals previous extreme cold weather advantage was the anomaly.
Post by eastbloc » Thu Jan 31, 2019 9:13 am
This morning it was 3 degrees and below freezing since Tuesday. I tried starting normally, and despite the fresh car battery I didn't try more than 4-5 cranks, as by then I felt the starter beginning to lose momentum without any indication of the engine firing.
Next, I used Chad's technique and squirted some starting fluid into the airbox, through the breather tube hole, which is indeed very easy to access and replace. Almost like it was designed for this.
The engine roared to life instantly as soon as I hit the starter and settled into a nice fast idle. It did not stall even once during warmup, and when I rode away it felt like it does when I've been riding it all day.
I would say we've cracked the root cause here. The bike is too lean to start in the cold. Now it's just a matter of personal preference on how to solve for this problem.
The "Chad tek" is brilliantly simple and effective and should honestly be good enough for anyone, and definitely diminishes the priority of my enricher button project, which can now wait until spring, although I still think it is an interesting and desirable option, particularly if it enables reliable all-season kickstarting.
'02 Patrol
Post by hotflash44 » Thu Jan 31, 2019 9:35 am
windmill wrote:
Wed Jan 30, 2019 7:54 pm
hotflash44 wrote:
Wed Jan 30, 2019 7:49 pm
windmill wrote:
Wed Jan 30, 2019 7:20 pm
Wed Jan 30, 2019 6:39 pm
After being out of town for the past three days, I sprayed starting fluid in the crankcase breather input to the airbox and, lawd a-mercy, this bike has never started so quickly!
This is my new cold weather starting method.
Tomorrow morning, it's supposed to drop down to 20°F, so we'll see how it does at twenty degrees colder.
The way the breather hoses lead to the the branch pipes, it's like it was meant to be used that way.
sounds like TCF isolated the cure for the issue. now the fun can begin to make a portal into the breather/air cleaner that is easy to access and looks good. :cheers:
One could put a T fitting in the breather hose and be done with it, but for some folks a solution that doesn't require carrying a can of starting fluid would be more desirable.
are you old enough to remember the starting fluid in capsule form that was dropped into the intake tube of a diesel tractor. lift the small cap insert the capsule and close presto start and go . Ah, the good old days! :cheers: here is a link for just the container dont think product is available, www.worthpoint.com/worthopedia/vintage- ... -220333808
Post by stagewex » Thu Jan 31, 2019 10:02 am
"Urals previous extreme cold weather advantage was the anomaly."
You mean carburetors? Haha.
Like east bloc, it was 3 degrees up by my house this morning. I went to start my Jeep well before I had to leave for work at 6:30am. Just to let it warm up. At these temps the efi kept the revs/idle very high for quite awhile. As I walked back outside to leave I heard the engine finally calming down to normal idle. Normally a 1 or 2 minute procedure. Today almost 10 minutes.
Realizing that IMZ has pretty much abandoned the electrojet system, isn't there a way to re-map the bikes to take into account extreme cold weather starting? A way to make it less lean? There are a few different map versions so just wondering if one might be better than the other. Or a 3rd-4th made available. Something like a Power Commander or other 3rd party dongle was never available. Just too small of a niche for it to be worthwhile. But maybe IMZ could still provide some advanced support for this now older system?
I'm also wondering how these bikes were running in parts of Russia which for the most part would be much colder than here? Did they de-tune the EFI to be less stringent? Are they even using efi?
On the carb bikes it was pretty much the selling dealers that would shim the needles and change jets if they didn't want to hear complaints from customers who had starting or popping/farting issues with their rigs. Some did it as part of their set-up. Others didn't (like mine) until you complained about it. Then did it. As wth the newer bikes... just too lean. But that was something mechanical the dealers could do themselves. Software mapping comes from IMZ.
Post by eastbloc » Thu Jan 31, 2019 10:11 am
They’re not using modern Urals in Russia, for starters. They’re all for export now. Most Russians think we’re nuts for messing with these things, the way we think Germans are nuts for listening to music by David Hasselhoff.
The map is not the problem, my bike runs perfectly fine when it is warm. The Electrojet just seems to be missing any compensating function for conditions required for starting, and you wouldn’t want to mess with the idle mixture overall just to solve for that.
If you want a richer mixture, you can use the Dobeck EJK, that’s exactly what it does. But in my experience it does squat for the starting difficulty problem.
Finally, I am 100% certain no one at IMZ will ever look at electrojet again for any reason. There won’t be a new map or any more updates. It is what it is. Reason being it wouldn’t help them sell a single Ural, so what would be the point of investing precious limited resources in such activities?
'02 Patrol
Post by stagewex » Thu Jan 31, 2019 10:13 am
So what we have here ('14 to '18) was export only? I never, ever knew that. Interesting.
Post by eastbloc » Thu Jan 31, 2019 10:32 am
You might be able to buy one from the factory (it's Russia, you can buy anything if you have the money) but I doubt there's a single Ural dealership in the entire country.
https://www.nytimes.com/2011/05/29/worl ... decar.html
"With the end of the command economy, subsidized steel and cheap labor, the factory was forced to raise its prices, and sales in Russia fell sharply. Older sidecars can still be seen in Russia carrying hay, heads of lettuce and planks of wood. But Irbit sold only 20 motorcycles in Russia last year, and the owners say that the factory would have died without sales to the United States."
That was 2011, and I doubt the situation has changed much, especially as the manufacturing and retail cost of a new Ural has skyrocketed.
'02 Patrol
heindlengineeringural
Post by heindlengineeringural » Thu Jan 31, 2019 10:53 am
do you always squeeze and hold the clutch when using the electric start?
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
Post by windmill » Thu Jan 31, 2019 11:08 am
The electrojet system doesn't have the AIT and MAF sensors necessary to modulate the AF ratio for extremes in temperature. The O2, and CHT sensors only function to adjust the AF ratio once the engine is up to temperature.
Cheap and simple, expensive and complicated, pick your poison.
Post by eastbloc » Thu Jan 31, 2019 11:10 am
Sometimes, if I'm too lazy to find neutral. It doesn't seem to make any difference.
'02 Patrol
Post by eastbloc » Thu Jan 31, 2019 11:11 am
The electrojet system doesn't have the AIT and MAF sensors necessary to modulate the AF ratio for extremes in temperature. The O2, and CHT only function to adjust the AF ratio once the engine is up to temperature.
As evidenced by the effectiveness starting fluid trick, it wouldn't need to modulate the AF ratio. All it would need to do is check the CHT and prime the cylinders on boot.
'02 Patrol
Post by windmill » Thu Jan 31, 2019 11:16 am
The CHT isn't a thermostat, it doesn't send a signal until its up to temperature because its the heat that generates the signal. As far as its concerned cold is cold, it cant tell the difference between 10 deg, and 50 deg.
Post by stagewex » Thu Jan 31, 2019 11:39 am
Windmill, what about the '19's with the new efi system (Keihin). Do you believe this is addressed going forward?
That's a pretty major global company vs. Electrojet.
Post by windmill » Thu Jan 31, 2019 11:52 am
Anomaly as in I've never onwed a bike that starts as quick and easy in the extreme cold as a carbed Ural.
