Hard starting '14.
propwash
Re: Hard starting '14.
Post by propwash » Wed Jan 30, 2019 10:59 am
eastbloc wrote:
Wed Jan 30, 2019 8:13 am
Albuquralque wrote:
Tue Jan 29, 2019 10:11 pm
12V
You’ll have to determine if the injector has a constant 12V input and operates with a switched ground. Or if the injector has a constant ground and operates with switched 12V
It’s the former. I’ve already consulted the wiring diagram and confirmed with a multimeter.
Hence my conclusion that we just need to wire up an alternate path to ground with a diode and momentary switch for the crudest solution here.
I am quite familiar with electronic system controls. ^^ That makes it much easier - no need to worry about the control pulse as much nor the complexity. I would prefer to bench test first, but a decent momentary to ground (with a decent gauged wire) should do it. You can experiment with the pulse width and get an approx value if this works to help start the engine. Then you can build a clean circuit to do just that (no switch bounce, set pulse width, etc) or not - I doubt the injectors are fragile.
Post by windmill » Wed Jan 30, 2019 11:00 am
Wed Jan 30, 2019 10:14 am
windmill wrote:
Wed Jan 30, 2019 12:14 am
propwash wrote:
Tue Jan 29, 2019 11:52 pm
Power on/power off would be digital.
Current required to "energize" the injectors?
Power on/power off is a digital function of the ECU.
The solenoid in the injector opens the needle valve when it receives 12V from any source, it makes no difference if the power on/power off function is digital or analog.
Yes it's just a simple transistor switch.
It occurs to me a manual override will need a 'one shot' type monostable circuit to just put a brief squirt in, if the injectors were direct off a manual switch you may not be able to turn them on then off fast enough, then there's a real danger you could flood the engine so it won't start, or even worse put so much in you get a hydro lock in the cylinders. :o
I don't think there's much danger of flooding or hydro locking the engine with an injector. They spray a mist like an airbrush, from what I've observed with a injector removed and spraying into a rag, it would take 10 seconds or more of continuous spraying to put just a teaspoon worth of fuel in.
Post by windmill » Wed Jan 30, 2019 11:08 am
At cruising speed, they actuate around 1700 times a minute. I doubt the injectors are fragile too.
Post by Mr Wazzock » Wed Jan 30, 2019 11:08 am
Ah well, human fallibility being what it is, I bet someone somewhere can and will c0ck it up. :D
Post by windmill » Wed Jan 30, 2019 11:13 am
Well, that's another issue all together.............. :lol:
Post by Tomcatfixer » Wed Jan 30, 2019 6:39 pm
After being out of town for the past three days, I sprayed starting fluid in the crankcase breather input to the airbox and, lawd a-mercy, this bike has never started so quickly!
This is my new cold weather starting method.
Tomorrow morning, it's supposed to drop down to 20°F, so we'll see how it does at twenty degrees colder.
Post by windmill » Wed Jan 30, 2019 7:20 pm
The way the breather hoses lead to the the branch pipes, it's like it was meant to be used that way.
Post by hotflash44 » Wed Jan 30, 2019 7:49 pm
sounds like TCF isolated the cure for the issue. now the fun can begin to make a portal into the breather/air cleaner that is easy to access and looks good. :cheers: just a idea how about a tubeless tire stem without the Schrader valve just the cap. drill a hole in the air cleaner and pop in the valve stem with a cap.
Post by Tomcatfixer » Wed Jan 30, 2019 7:53 pm
Yes, well, um, I guess it would... had... I... not... removed those... tubes...
Post by windmill » Wed Jan 30, 2019 7:54 pm
One could put a T fitting in the breather hose and be done with it, but for some folks a solution that doesn't require carrying a can of starting fluid would be more desirable.
Post by Tomcatfixer » Wed Jan 30, 2019 7:55 pm
You guys can tackle that one. Slipping the air/oil separator hose off of the airbox is SUPER easy and convenient for me. At this point, no further modification is necessary.
Post by windmill » Wed Jan 30, 2019 7:57 pm
Since the the oil issue is solved, maybe this is a reason to put them back in? I would suspect the closer the fluid gets to the cylinders the better?
Post by windmill » Wed Jan 30, 2019 8:00 pm
But, but a fancy, nifty T fitting in the breather hose would have more coolnessocity.
Post by Tomcatfixer » Wed Jan 30, 2019 10:01 pm
I suppose I COULD, but I have the air/oil separator now, so I don't really NEED to reinstall the lil' branch tubes.
That it would. And I'm not above doing something just for the sake of doing it, but I've already got quite the backlog of projects, so.......
Post by eastbloc » Wed Jan 30, 2019 11:13 pm
The car battery seems to have helped a lot with starting as well. It was 20 today, but it's going down to 6 overnight so tomorrow will be a real test. The interesting thing is that it doesn't just help with the cranking -- the bike seemed literally unaffected by the cold today, it started the way it normally starts in warmer weather.
I suspect the decrease in available amps in the cold has some knock-on effects on some other electrical component required for starting, I'm thinking either the ECU itself or maybe the fuel pump.
I think between the car battery and the prime button (which I am going to figure out, I'm not content with the starting fluid solution) this problem will be permanently solved.
'02 Patrol
