EFI TBs and ECU discussion
BlueRockCrawler
Re: EFI TBs and ECU discussion
Post by BlueRockCrawler » Mon Jan 15, 2018 2:36 am
gobium wrote:Eletrojet and Imwa should not under estimate general public!..... :wink:
Are they underestimating us? I get the sense that they don't really care to mess with it unless it become a statistically significant warranty issue. I kind of understand that Harley got into trouble for selling EPA defeat devices and they might be nervous about their "off road" map. https://arstechnica.com/cars/2016/08/ha ... et-tuners/
I also feel that it's rent seeking, but I don't know weather it comes from the dealers, the mothership, or even from EJT.
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
RobH
Post by RobH » Thu Jan 18, 2018 3:18 am
Hi All,
I can back up Van's opinion that the ECU is not separable from the TB. I had the misfortune to drill one of my balance ports a little to close to the void occupied by the ECU on my 2014. Be warned that the void extends about 1/3 of the way out from the ECU. I was concerned with aluminum shavings entering the ECU cavity so I tried to remove the ECU to clean things up.
'Turns out the black cover is extremely solidly attached and it's not just the clips. Unlike Van I tried hard enough to actually break off a clip and the cover/ECU wouldn't budge. The best I could do was move one corner up a tiny amount... but that was probably just the flex in the plastic.
The good news is that I didn't screw up the throttle body and the bike is still running fine.
cheers,
R.
Dum Vivimus, Vivamus
2014 G.U.
1999 Honda ST1100
1981 BMW R100RT
1971 BMW R60/5
1965 Honda CB77
scottolds
Post by scottolds » Thu Jan 18, 2018 10:43 am
Just curious if you know the flow rating on the injectors and at what fuel pump pressure do they operate?
2009 KLR650
1987 Honda VF700C Super Magna
2011 Ural Gear-UP - отвлекающий маневр
1994 Kawasaki Voyager XII
http://www.rokkitrider.com
BlueRockCrawler
Post by BlueRockCrawler » Thu Jan 18, 2018 12:05 pm
And what the tooth pattern on the flywheel is?
2015 Ural Patrol
1996 Magna Deluxe
2004 919
1985 500 Magna
Post by Mr Wazzock » Thu Jan 18, 2018 12:50 pm
"Blue Ox" did a video:
... and Gobium on injectors.....
Post by Mr Wazzock » Thu Jan 18, 2018 1:11 pm
Can't find a photo or diagram of the flywheel showing the grooves, and I thought I did see one once. :(
Annoying.
Post by gobium » Thu Jan 18, 2018 1:19 pm
Mr Wazzock wrote:Can't find a photo or diagram of the flywheel showing the grooves, and I thought I did see one once. :(
Annoying.
Darrell hush dont say a word.
How many groves are there on efi fly wheel?
Subsnowden
Post by Subsnowden » Thu Jan 18, 2018 3:15 pm
If anyone has a dealer tool near me I will probably do naughty things if you let me use it lol
Jon
Central Texas/Copperas Cove
2016 DR-Z400 SM
2015 Ural Gear Up
No longer own a cage
Wolff
Post by Wolff » Thu Jan 18, 2018 7:36 pm
Back in the 80s when i worked at Ford. We would take the fuel pump relay out get our AC gauge hose and freon side can tap and a can of Berkebile 2+2 hook up to the pressure port start the car and bamm! That's how we cleaned Injectors.
Wolff
2016 GU
Post by Albuquralque » Thu Jan 18, 2018 8:28 pm
Annoying.
:roll:
Darrell - Albuquralque
EFI Map OR 1.02
Throttle Body Vacuum Ports
K&N Air Filter
BlueRockCrawler
Post by BlueRockCrawler » Fri Jan 19, 2018 9:31 am
I don't really care about the grooves, the hall effect sensor is counting the raised "not groove" portions of the flywheel. We'll call them teeth for now, the extra large groove that Darrell illustrates is a "missing tooth" and it's part of a pattern that the computer uses for crank position sensing. I could really use the pattern for more research into the project I PM'd you on. Of note I have never been able to find a TDC mark on my flywheel. I have to use the Kentucky windage method.
2015 Ural Patrol
1996 Magna Deluxe
2004 919
1985 500 Magna
Post by hotflash44 » Fri Jan 19, 2018 10:30 am
As to injector cleaning, has anyone used the automotive gas cleaner method with positive results? i know the mechanic shops love to sell people the 150 dollar injector clean job, not totally convinced it isn't a rip off tho. im talking the plastic bottle of cleaner by proportion to our size tank, and fallowed up by a spray job inside the throttle body. i know its a half A$% fix, but when done as preventive maintenance might be worth while. :?: :idea: :cheers:
drive a 2016 gear up asphalt grey .Air America CIA circa 1967/8 Vung Tau Viet Nam USS Tutuila ARG-4 (AND JUST A TOUCH OF AGENT ORANGE!)
Subsnowden
Post by Subsnowden » Fri Jan 19, 2018 12:06 pm
Gobi, can you post a pic of that entire diagram?
Jon
2016 DR-Z400 SM
2015 Ural Gear Up
Post by gobium » Fri Jan 19, 2018 12:13 pm
Post by Albuquralque » Fri Jan 19, 2018 12:48 pm
gobium wrote:
Where did you get such a cool wiring diagram for the EFI ?
EFI Map OR 1.02
K&N Air Filter
