EFI TBs and ECU discussion
Post by gobium » Sun Jan 14, 2018 10:11 am
Re: EFI TBs and ECU discussion
Post by gobium » Sun Jan 14, 2018 10:29 am
2 ECUs. = 2 coils
Post by gobium » Sun Jan 14, 2018 10:41 am
Ha!
Fuel pump is connecting to left EJT32L only
Therefore ECU is not interchangeable
Post by Albuquralque » Sun Jan 14, 2018 10:55 am
Post by gobium » Sun Jan 14, 2018 10:57 am
Albuquralque wrote::thumbsup:
I might be wrong on ECU interchangeable
Post by Albuquralque » Sun Jan 14, 2018 10:58 am
I like that large size wiring diagram you have there!
Post by Mr Wazzock » Sun Jan 14, 2018 11:04 am
gobium wrote:Ha!
I already knew this. :D
There is or was a video on youTube showing ElectroJet guy talking about the system.
Post by Mr Wazzock » Sun Jan 14, 2018 11:14 am
Pretty sure someone on this forum tried taking off one of the plastic covers, but it wouldn't budge, I think it is resin filled inside, or glued, the clips at the edge of the plastic covers are only a convenience for assembly, when the resin is cured, they are stuck on.
Of course I might be wrong tho. (Often am. :D )
Of course inside is going to be tiny TINY SMD (Surface Mount Device) components, which you can't do anything with unless you are an expert at that sort of thing and have the relevant tools. (Can't just use your $20 soldering iron from Tandy.)
Post by gobium » Sun Jan 14, 2018 11:17 am
Enjector has 4 small holes
Post by gobium » Sun Jan 14, 2018 11:22 am
Pins are mapped with grid system , 123...abc
Post by gobium » Sun Jan 14, 2018 11:34 am
This hole seems to connect with ECU?
Darrell told me about the tiny hole inside TB
Post by Mr Wazzock » Sun Jan 14, 2018 11:40 am
It is able to sense manifold pressure, so probably what that is for.
Appendix: thanks for the connector photos!
Subsnowden
Post by Subsnowden » Sun Jan 14, 2018 7:41 pm
I really like how they make an EFI that behaves like a carbed bike but you can’t adjust lol!
URAL- Uniqely Reliable Always Lovable
Jon
Central Texas/Copperas Cove
2016 DR-Z400 SM
2015 Ural Gear Up
No longer own a cage
BlueRockCrawler
Post by BlueRockCrawler » Sun Jan 14, 2018 8:29 pm
I've been milling over this very problem recently and I have some thoughts. Gobi, going to pm some interesting abstract concepts to you after I get home. I'm guessing that Ural is never going to release a customer tool for dealing with the computer, and it's a shame because now I'm going to have to give my money to someone other than Ural to fix the problem.
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Post by gobium » Sun Jan 14, 2018 8:40 pm
Eletrojet and Imwa should not under estimate general public!..... :wink:
