2017 and up Speedometer settings database.
heindlengineeringural
Re: 2017 and up Speedometer settings database.
Post by heindlengineeringural » Wed Aug 22, 2018 8:02 am
Some of the settings are now locked on the 2018 bikes to prevent you from inadvertently changing them. When you scroll through the screens on the 2018, you won't see exactly what you would with a 2017.
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
Wanderrad
Post by Wanderrad » Wed Aug 22, 2018 8:14 am
Thanks Jon.
-Scot
TiGGer Dave
Post by TiGGer Dave » Fri Jan 18, 2019 11:33 am
Not withstanding initial comment of this thread My Speedometer has stopped working....... immediately after adjusting the Clock and scrolling through... I hope 'tis only because I out of sequence the Mode / Rest buttons?
Bike is barely a week old with 60 ish km on the ODO.
Deadlines ... I love the whooshing sound as they go by......
2014 VStrom
2018 Gear-up (2WD) Slate Grey
https://spca.bc.ca/locations/wild-arc/
Post by Mr Wazzock » Fri Jan 18, 2019 2:50 pm
Not sure I want one of the new ones! :o
Post by harryball » Fri Jan 18, 2019 3:12 pm
Yep, my wife's cT just got it's second speedometer and it is one with the limited menu so now I can't adjust the tire diameter to get the speed correct. It's set for 18" rims but off by 4mph at 60. Before I could tweek that out, no longer.
First speedo just went whacky then died. Second speedo melted the face inside from the LEDs. 3rd one is a 2018 speedo. So far, it works, albeit not accurate.
Post by windmill » Fri Jan 18, 2019 4:40 pm
Year plus on my 2018, it's spot on, and working fine. A handful of issues isn't cause to assume they're inherently flawed or likely to fail.
TiGGer Dave
Post by TiGGer Dave » Fri Jan 18, 2019 5:40 pm
[/quote]
[/quote]
Harry Ball... I note your Signature sir as follows:
2017 - M70/Retro, Sigmund. My rig.
Should it knot read:
2017 - M70/Retro, Sigmund. My Wife's other rig.
Cheers TiGGs
2014 VStrom
Post by harryball » Fri Jan 18, 2019 6:48 pm
[/quote]
Cheers TiGGs
[/quote]
How crazy of me, you're right, I fixed it.
TiGGer Dave
Post by TiGGer Dave » Sat Jan 19, 2019 9:45 am
BZ Brother!
2014 VStrom
Burt1713
Post by Burt1713 » Sun Feb 03, 2019 6:06 pm
BZ Brother!
Have you gotten your speedometer working?
2017 cT "Woody Moose"
TiGGer Dave
Post by TiGGer Dave » Tue Feb 05, 2019 5:33 pm
All under warranty of course.
New one is on the way. Hopefully soon. I have been using a GPS Puck to keep trac of my ODO.
I'll post pics vids etc when the package gets here
2014 VStrom
Burt1713
Post by Burt1713 » Tue Feb 05, 2019 8:11 pm
Out of curiosity, on your bad speedometer, did you try unhooking the battery ground cable for a minute or more to see if that reset the speedometer?
Camel Jockey
How To Set The Circumference Of A “Locked” Speedometer
Post by Camel Jockey » Sat Apr 13, 2019 3:31 pm
The electronic speedometer locks in the wheel circumference after the first 17 kilometers of riding. However it is possible to reset/adjust it as follows.
Note that all recorded readings will be erased during this process. Record your current Odometer, trip meters, and maintenance meter prior to this process so that you can set them again
Unlock the wheel circumference setting:
1. Disconnect the battery.
2. Press and hold both buttons on the speedometer and reconnect the battery while still buttons.
3. While continuing to hold both buttons on the speedometer turn on the ignition switch.
4. The LCD will shows END which means the EEPROM has been reset to factory settings. The odometer will be reset to 0. The wheel circumference will be reset to the default of c1277.
Program the speedometer:
1. Turn the ignition on, and wait until the needle returns to 0 and diagnostics complete. Press both “RESET” and “MODE” buttons simultaneously to enter setting mode.
2. While in setting mode toggle to the third display setting using the “MODE” button.
3. Use the “RESET” button to increase the flashing digit from 0-9. The “mode” button is used to toggle to the next sequential digit from left to right. Program the maintenance trip meter for the next scheduled service interval (example 310 miles for first service interval in miles).
4. From the “TRIP” function, toggle past the two “RPM” settings, (“RPM” functions are not enabled) to circumference indicated by a “C” in the lower left corner of the digital display window.
5. Set the speed setting for wheel circumference to c450 for 19” wheel or c445 for 18” wheel.
6. From the circumference setting toggle to the speed pulse setting which is the next programmable mode displayed. This function will be indicated by a “P” on the left side of the digital display window.
7. Set the pulse setting to P-001 for all models regardless of wheel circumference.
8. Press MODE button for 2 seconds to finish and go to normal mode.
Mike S.
Stamford, CT
2018 GU; 2017 350 EXC-F; 2014 F800GS
