2017 and up Speedometer settings database.
Burt1713
Post by Burt1713 » Mon Sep 04, 2017 1:29 pm
There have been instances of 2017 speedometers either losing their settings or being accidentally reprogrammed. I would like to make a list of all of the proper settings, all but one of the settings are the same from model to model. I have a CT so I will list the settings for it, and if others could add the settings for a M70/Retro, Patrol, and Gear Up I would appreciate it.
The settings are accessed by pressing the mode and reset buttons for 2 seconds with the key on, the bike doesn't need to be running though. The mode button cycles though the options. The reset button changes them.
12 or 24 hour clock: user preference
Current time: I would recommend the correct time for this setting :lol:
Miles until next service: user preference
Max RPM factory set at 06500
You can set this to any rpm you wish using the mode and reset buttons. When the set RPM is exceeded the LCD backlight will turn red. Thanks to Barry AKA Windmill for discovering this feature.
Tachometer settings factory setting "SP1r1P" if you hook up the tach you will need to change this setting to "SP2r1P"
http://www.sovietsteeds.com/forums/view ... 23&t=49289
Tire circumference on a CT this is c0477, a Gear Up is c0450 need to know what this number is on other models.
Number of pulses per wheel revolution factory setting is P-001
Type of sensor factory setting is HALL
If we can complete this list with the circumference settings for all 2017 models we may be able to save someone a few headaches.
A few more fun thing you can do with a 2017 speedometer.
https://youtu.be/U93fpdl_65c
If all else fails try disconnecting the battery to reset the speedometer. Be advised, you should leave the speedometer disconnected for at least 30 seconds to allow all of the internal circuits to discharge.
Known faults that disconnecting the battery will fix:
LCD flashing red to green with speedometer otherwise functional.
Speedometer inoperable and LCD displaying "Ural"
How to do a “factory reset” by “Camel Jockey”
viewtopic.php?f=23&t=49290&start=15#p689223
2017 cT "Woody Moose"
Burt1713
Re: 2017 Speedometer settings database.
Post by Burt1713 » Mon Sep 04, 2017 1:38 pm
Also if you have the optional higher final drive gear ratio that will change the circumference settings as well. If we can get this setting for all of the models too that would be great.
Patrick
Post by Patrick » Mon Sep 04, 2017 8:24 pm
Will check my info tomorrow and reply here.
“An inconvenience is only an adventure wrongly considered; an adventure is an inconvenience rightly considered.” – G.K. Chesterson (1908)
Now 2017 GearUp (Maruska)
Past scoots: gone but not forgotten :D
Whizzer Motorbike in 1956, Kaw 175, Suzuki SP370, Suzuki DR400, Yamaha SR500, Suzuki GS1000 (78), BMW R100RS (84), BMW R100S (81), BMW 1150GSA (03), Ural Patrol (09)
Patrick
Post by Patrick » Tue Sep 05, 2017 5:42 pm
2017 GearUp Tire C0450 (Delivered In April)
As you mentioned all other readings the same as yours.
Trumpetwasher
Post by Trumpetwasher » Tue Sep 05, 2017 6:32 pm
No high-speed final drives in 2017.
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Handlebar Power Outlet
Deluxe Seating
Sidecar Side Panels
Armrests
Double-Spring Saddle
Santamaria Foot Rest
Custom Nose Art
Dnepr Leg Shields
XMT-MOTO Hand Guards
All LED lights.
Burt1713
Post by Burt1713 » Tue Sep 05, 2017 6:43 pm
Patrick wrote:2017 GearUp Tire C0450 (Delivered In April)
Thanks Patrick.
Pew9413
Post by Pew9413 » Fri Sep 08, 2017 11:37 pm
Thanks Burt1713 the salesman drove the 2 hours out to pick up my bike and take it back to replace the speedo and the mechanic figured out it was not on the hall sensor. They also replaced the recalled parking brake cable that the end came off. So I am up and riding again. Again thanks to all. You all on this site are a amazing bunch that can get it done!
2017 Ural Ct ,1998 Road King, 1998 BWW R1200 with hanagan sidecar
Burt1713
Post by Burt1713 » Sun Nov 05, 2017 9:34 pm
Added an update about disconnecting the battery.
Burt1713
Re: 2017 and up Speedometer settings database.
Post by Burt1713 » Fri Jan 26, 2018 12:04 pm
Added update regarding the shift light feature that Barry AKA Windmill discovered.
Post by windmill » Fri Jan 26, 2018 10:01 pm
Burt1713 wrote:Added update regarding the shift light feature that Barry AKA Windmill discovered.
I thought It was odd that the function was enabled in the LCD menu when the spot for the shift warning indicator as shown in the manualhttp://www.acewell-meter.com/wp-content/upload ... 150211.pdf is used for the parking brake indicator on our speedos.
Set it just to see what would happen, the LCD flashing red was a total surprise.
Mikey
Post by Mikey » Sat Jan 27, 2018 2:33 pm
The flashing after max rpm would be great combined with a chart on this site somewhere that has the recommended shift rpms!
2017 Gear-up Forest fog
Burt1713
Post by Burt1713 » Sat Jan 27, 2018 7:12 pm
Mikey wrote:The flashing after max rpm would be great combined with a chart on this site somewhere that has the recommended shift rpms!
From what I have read the red line is 5800 rpm (but no guarantees), as for shift points those vary by conditions, uphill/ downhill, loaded or not, how fast you are trying to accelerate, etc.
Post by Lokiboy » Sun Jan 28, 2018 9:21 am
There is a chart. Although this thread applies mainly to pre-EFI models the chart would still be accurate.
http://www.sovietsteeds.com/forums/view ... 25&t=28897
90,000 km and counting
Burt1713
Post by Burt1713 » Sun Jan 28, 2018 1:14 pm
Great database, very useful.
Wanderrad
Post by Wanderrad » Tue Aug 21, 2018 5:53 pm
My speedo doesn't show the circumference setting when I cycle through the settings. Am I missing something? It goes from SP1r1P to P-001.
-Scot
