How to make a 2017 and up tachometer functional.
Re: How to make a 2017 tachometer functional.
Post by Mr Wazzock » Wed Apr 10, 2019 4:57 pm
Up to 2018, Electrojet EFI, both ECU's will have a coil output wire. So one of the ECU's then.
2019, Keihin EFI, I haven't the foggiest. But safe to assume the Keihin ECU drives an ignition coil, or coils, plural.
Kirkus
Post by Kirkus » Thu Apr 11, 2019 10:35 pm
Thanks thats helpful
Kirkus Maximus
Https://kirkusblog.com
1968 Honda CL175 - for sale
1966 BMW R69s/2 - sold
1992 Harley Heritage Softail - sold
2009 Triumph Bonneville T100
2011 Royal Enfield Chrome C5 - for sale https://kirkusblog.com/2018/12/03/2011- ... c5-chrome/
2016 Morgan 3 Wheeler
2018 Ural Retro - The White Russian
https://www.youtube.com/user/kirkolmsted
Callmemr-t
Post by Callmemr-t » Sat Apr 20, 2019 5:37 pm
Looks like IMZ is on to us! They have removed the rpm wire from the 2019 diagram, still have regular coils though. My question is why doesnt Ural hook it up from the factory? You would think after a few years they would figure out how to get it working? Is this just a crazy oversight or do they just not care that the bike has a non functional tachometer built right in?
2019 Ural Gear Up Sahara
2003 Yamaha Yzf600R
Burt1713
Post by Burt1713 » Sat Apr 20, 2019 5:49 pm
When you cycle through the modes on you 19’s speedometer are there a “RPM” and “Max RPM” displays?
2017 cT "Woody Moose"
Callmemr-t
Post by Callmemr-t » Sat Apr 20, 2019 6:18 pm
I know there is an rpm display but it just reads 0, can't recall if there is a max display and I'm not gonna be home for a while to check.
2003 Yamaha Yzf600R
Burt1713
Post by Burt1713 » Sat Apr 20, 2019 7:39 pm
I would say the speedometer is the same as 17-18s, you’ll just have to figure out which primary wire on the coil to connect to and the rest of the setup should be the same.
Burt1713
Post by Burt1713 » Sun Apr 21, 2019 5:19 pm
From what I can interpret from the schematic, if you splice the grey primary wire from either coil to the grey wire, from the speedometer, shown in the picture below your tachometer should work. You will have to adjust the settings as described in the original post so the tachometer doesn’t read half speed.
This is a proceed at your own risk modification.
Post by windmill » Wed Apr 24, 2019 1:07 am
It wasn't a function Ural requested for their custom configuration of the speedo from the manufacturer Acewell, and as such they didn't have the manufacturer of the wire harness add the wires and connectors for it.
The Acewell speedo is basically one of their standard models with the Ural logo, and a parking brake light added, They simply didn't remove or disable any of the standard functions Ural didn't request.
In reality its a freebie to us from Acewell, not an oversight from Ural.
pbrowne
Post by pbrowne » Wed May 22, 2019 9:16 am
How do you adjust setting to make tach not read half speed?
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
Burt1713
Post by Burt1713 » Wed May 22, 2019 8:41 pm
At this point the tachometer will function, but will read half of the actual RPM. To correct this you will need to turn the key on, but not start the bike. With the key on Press and hold both the mode and reset buttons on the speedometer for 2 seconds. This will bring up the 12/24 hour setting for the clock. Press mode multiple times until the LCD screen reads "RPM SP1r1P" you will need to change this with the reset button to read "RPM SP2r1P”.
At this point turn the key off and you are done.
pbrowne
Post by pbrowne » Fri May 24, 2019 5:52 pm
I found the grey wire, but can't figure out how to get at the coil to tap into the grey wire there. Please help.
Post by windmill » Sun May 26, 2019 4:31 pm
If you remove the fasteners from the fuel tank, you may be able to move it enough to access them sufficiently to add an in line tap. I ended up having to remove the tank on my M70.
Kirkus
Post by Kirkus » Sat Jun 01, 2019 7:17 pm
I think i have a trick figured out to hook this up painlessly, more info when i get parts!
Kirkus Maximus
Pseudoname
Post by Pseudoname » Sun Jun 02, 2019 2:19 am
Throwing some luck your way. Hoping you are successful so I can give it a go.
Kirkus
Post by Kirkus » Mon Jun 03, 2019 8:31 pm
Ok my answer works so far. Mychron rpm sensor for cart.
https://www.bmikarts.com/Mychron-RPM-Se ... p_950.html
Came with no instructions so I just clipped it on the plug wire and laid the wire along the length of the plug wire, put the other end to the grey loose wire in the headlight bucket that goes to the speedometer and so far it works fine.
Kirkus Maximus
