How to make a 2017 and up tachometer functional.
Burt1713
Re: How to make a 2017 tachometer functional.
Post by Burt1713 » Mon Jan 22, 2018 10:28 pm
What did you set your shift rpm to?
2017 cT "Woody Moose"
Burt1713
Post by Burt1713 » Mon Jan 22, 2018 10:43 pm
Barry, if you wouldn't mind reading through this thread and adding anything you find missing. I'm trying to make a dedicated speedometer thread for trouble shooting purposes.
http://www.sovietsteeds.com/forums/view ... 23&t=49290
Post by windmill » Mon Jan 22, 2018 10:49 pm
Burt1713 wrote:What did you set your shift rpm to?
5400 RPM.
Post by windmill » Mon Jan 22, 2018 10:55 pm
Burt1713 wrote:Barry, if you wouldn't mind reading through this thread and adding anything you find missing. I'm trying to make a dedicated speedometer thread for trouble shooting purposes.
Good thread, wish I had found it when I first got my rig, would have saved me some head scratching.
Looks good so far, still in the learn mode myself, if I learn something I can contribute I certainly will..
Burt1713
Post by Burt1713 » Mon Jan 22, 2018 11:51 pm
Thanks, I wish I could figure out how to keep it nearer to the top of the list so it would be easier to find.
Mikey
Post by Mikey » Sat Jan 27, 2018 3:38 pm
What is the ideal shift rpm? And what is red line rpm?
2017 Gear-up Forest fog
Colin1
Post by Colin1 » Sun Jun 17, 2018 10:53 am
A word of caution for anyone making this modification. Cut the wire going to the speedometer (yellow or blue/red after the connector) don't just splice into it.
Colin1
2017 Gear up
2008 street glide
1997 CBR XX
Numerous project bikes
Post by windmill » Sun Jun 17, 2018 1:32 pm
Colin1 wrote:A word of caution for anyone making this modification. Cut the wire going to the speedometer (yellow or blue/red after the connector) don't just splice into it.
There's another way to hook it up that's the official, unofficial way to do it.
Simply hook the jumper wire to the loose gray wire with female connector on the speedo.
Colin1
Post by Colin1 » Mon Jun 18, 2018 9:07 am
Well I wish I new that before I started! What jumper wire? the one from the coil?
Colin1
2017 Gear up
2008 street glide
1997 CBR XX
Post by windmill » Mon Jun 18, 2018 1:18 pm
Colin1 wrote:Well I wish I new that before I started! What jumper wire? the one from the coil?
Yes, the wire that goes from the speedo to the gray/white wire on the coil, or wrapped around the spark plug wire.
fWIW, the way you did it works fine too.
Colin1
Post by Colin1 » Fri Jun 22, 2018 9:52 am
Well I'm still on the steep side of the learning curve when it comes to Urals. Getting a working tach on my rig has been worthwhile. I've always owned Harleys and am in the habit of using their torque to get where I need to go. I'm definitely not used to the relative high revs the Ural needs to make power.
So with a tach I've already found that it is easy to overrev the Ural in first and second gear. More importantly, I'm spending a lot more time in third gear with the engine singing it's song and moving right along!
Colin1
2017 Gear up
2008 street glide
1997 CBR XX
violation
Post by violation » Thu Jul 19, 2018 2:52 pm
windmill wrote:
Sun Jan 21, 2018 1:12 pm
That shouldn't be a concern for folks with mid 2017 and later rigs with the upgraded, matched FD gear sets.
is there a way to know whether my 2017 has matched FD gear sets? by VIN perhaps?
Post by windmill » Thu Jul 19, 2018 3:15 pm
That's probably the only way, and even then it might not be certain as it was rolled into production mid year.
Mike_from_Germany
Re: How to make a 2017 tachometer functional - a probably stupid question
Post by Mike_from_Germany » Fri Jul 20, 2018 8:43 am
Hi alltogether,
I am just trying to make my tach working. I read this thread and searched for tach and "gray wire" but I am a little confused.
There is a yellow wire coming out of the Acewell which is connected to a blue wire coming from the ECU (according to the wire diagram which I think is not absolutely correct).
In the first post Burt1713 says I should disconnect this. My question: What is it for? Did they install a useless wire? Or what?
There is a grey cable with a female connector coming out of the Acewell. I found that this is a high-resistance input, Acewell says it should go to the ECU/ignition coil. Does this mean I can simply go this way and forget the first step of Burt1713?
Is there a pinning of the ECU around? This would probably help.
And my apologies for my english, I hope there are not too much mistakes.
Best regards, Michael
Post by windmill » Fri Jul 20, 2018 3:22 pm
I've hooked it up both ways, and both work. The simplest and most functional way is to run a wire from the gray wire on the speedo to the gray and white wire on a coil.
I believe the wire from the ECU to the yellow wire on the speedo just provides a signal to the hour meter.
