color of horn ground wire?
Post by hotflash44 » Mon Mar 20, 2017 5:13 pm
okay, i did look the site for the answer to my question didnt find so here i go. simple my 2016 gu has a stock horn with two wires which one is ground or hot ? one wire is pink one is brown.in the event nobody knows other than the 50/50 chance method how can i tell which one is hot. p.s. i do have a volt meter maybe turn the ignition on and see i dont like electric stuff so i would rather have someone tell me the color. im such a coward need someone to tell me the color.
Re: color of horn ground wire?
Post by Mr Wazzock » Mon Mar 20, 2017 5:30 pm
It's pink that's live from fuse #4, brake light switches circuit. Brown goes to horn button, thence to ground. (Via the switch.)
HTH
Post by hotflash44 » Mon Mar 20, 2017 5:38 pm
your the man, would assume, thanks what a quick diagnostic . putting on a denali air horn all good now.
Post by Mr Wazzock » Mon Mar 20, 2017 6:31 pm
Okey-doke. :D
I only looked at wiring diagram.
Bit misleading tho it's the only brown wire that doesn't go directly to ground.
Incidentally BMW also use brown for ground wires.
phliparoonie
Post by phliparoonie » Tue Mar 21, 2017 7:20 am
"Brown is ground the world around" Heard that somewhere.
Post by hotflash44 » Tue Mar 21, 2017 9:20 am
the earth is sort of brown i guess the ruskies arnt to far off,as far as the wire diagram i have always had a mental block looking at them thanks for clearing this up
