Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Re: Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Post by Albuquralque » Sat Apr 06, 2019 10:47 pm
Ajax wrote:
Sat Apr 06, 2019 10:34 pm
Maybe someone can help me figure out why my intake pressure reading stays the same throughout a rpm range.
I double checked PID settings and they test fine. The readings for cyl temp reads fine but pressure stays at .73 psi. I'm using an OBDLink puck and software. Firmware is up to date. Everything is functioning normally with all other gauges.
Need to be reading in metric.......kPa
Ajax
Post by Ajax » Sat Apr 06, 2019 11:14 pm
Does the same in metric too.
2004 Tourist 65k km (new to me 2018 @ 48k km)
2018 Gear Up that I have the pleasure of maintaining for the girlfriend
Post by Tomcatfixer » Sun Apr 07, 2019 5:22 am
It doesn't need to be Metric. I've used PSI since I set mine up. Ajax, you must have some little PID syntax error.
rebelrider
Post by rebelrider » Mon Apr 08, 2019 4:13 am
I had a similar problem. I don't remember the exact solution, but it was after I fiddled with the settings for a while. Once it started working, I was able to get readings in both kPa and PSI.
I think I may have deleted that particular PID and reloaded it. I'm not sure. I did have an issue that was fixed by changing the range that the gauge reads. Sorry I can't be more specific. It was quite a while ago.
Image2014 Ural M70 "Trogdor"
1987 Honda CMX250C "Rebel"
1979 Puch Moped "Wasp"
1971 Honda SL100
Post by Mr Wazzock » Mon Apr 08, 2019 8:19 am
Are the settings correct, e.g. each cylinder has a unique ID, but can't remember what
Ajax
Post by Ajax » Mon Apr 08, 2019 10:37 pm
The only letter "O" is the "OB" under PID number the rest of the "0"'s are zeros?
Been playing with priority setting but no affect. I'll try the range next.
Post by hotflash44 » Tue Apr 09, 2019 9:01 am
Darrell, i know where i got my good working PIDs :wink: , but where do people get them, like some of the previous post people? are they in print,will IMZ supply. :? :cheers:
Post by Albuquralque » Tue Apr 09, 2019 11:01 pm
They are free to pm me and I will send them the predefined PID files and instructions
Post by hotflash44 » Wed Apr 10, 2019 8:46 am
Thanks Darrell. your the best and i will vouch that these are the correct values and work perfect on my OBDwiz. :cheers:
cabrown56
Post by cabrown56 » Tue Apr 23, 2019 3:24 pm
Has anyone done this for the 2017 Ural which has the round 4pin connector. Want to balance mine too but cannot find connectors adaptor to fit.?
Post by Tomcatfixer » Tue Apr 23, 2019 4:12 pm
Yes, Burt1713 makes the adapters. Look in the black market.
pbrowne
Post by pbrowne » Mon Jun 10, 2019 8:58 am
If the port is the one below the seat on the left under the cover, mine is much different. It's round with 4 pins. Is there another port elsewhere on the bike?
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
Post by Mr Wazzock » Mon Jun 10, 2019 2:04 pm
No that is it. So it's as per the last two posts before yours then? :D
pbrowne
Post by pbrowne » Sun Jun 16, 2019 7:54 am
Can someone please tell me where that plug is located, I don't see on with that form factor.
Post by Tomcatfixer » Sun Jun 16, 2019 8:15 am
I am unclear as to which plug you are referring, but if you look on Page 5 of this thread, you will see the 2014-2016 six-pin MOLEX connector (a diagram of which is on Page 1) AND the 4-pin cannon-plug style connector used on 2017 and newer Urals to obtain OBD-II diagnostic information.
