Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Re: Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Post by Mr Wazzock » Tue Nov 06, 2018 11:36 am
Assuming the above is correct -
My dealer can have exactly the same problem when his computer is plugged in for the diagnostics. So what he does is, have a battery charger plugged in at the same time. On mine, we can turn the headlight off as well.
HTH
Post by gobium » Tue Nov 06, 2018 11:51 am
Rumor had it!
You can use TwinMax on 2019 ural.
Post by Mr Wazzock » Tue Nov 06, 2018 12:08 pm
OK! :D
stefano1979
Post by stefano1979 » Tue Nov 06, 2018 2:19 pm
ok....i resolved!!
Post by Albuquralque » Tue Nov 06, 2018 3:12 pm
ok....i resolved!!
How?
stefano1979
Post by stefano1979 » Wed Nov 07, 2018 4:19 am
The color of the wires on my obd2 socket was incorrect.
With the tester I checked the wires and I redid the connections.
Unfortunately I can not buy the "professional add on" for obdwiz, the site answers me with a failed transaction.
Are there other software for controlling the two ecu?
Thank you
Stefano from Italy!
AndyH
Post by AndyH » Mon Dec 03, 2018 4:49 pm
Stefano, try emailing OBDWiz. I found them to be quick to respond.
Just an update - Had XXOR_1.03 loaded and my throttles balanced by our Ural Importer. There was little to no difference between my balance with OBDWiz and the Ural software.
Interestingly there are a heap of pointless codes indicated on the Ural software that were also ignored - one ones that come up in red are an issue, none on my bike.
Importer said that sometimes it depends on the way you hold your tongue when you turn on the ignition :)
2015 Ural EU Tourist -
Donbmw
Post by Donbmw » Sat Feb 02, 2019 7:48 pm
Those of you that are using the OBDwiz on your laptop. I have not used my laptop for balancing in awhile. Be using a android Bluetooth tablet mounted on the bike. I replaced the RH throttle body and set idles and balance with the tablet. There is a slight lag with the tablet and wanted to compare the Bluetooth to a wired connection. The OBDWIZ needed to a activation code before it would read the bike. After getting that and started to check balance. The only PID that was working was the tach. The PID’s for temps and vacuums were not working. There were no changes looked at the settings for each PID. Was wondering if any one had this issue. The last time I used the laptop was back earlier in the summer when I got everything to use the small tablet on the bike. The OBDWIZ has been updated to the latest version also.
Don
AndyH
Post by AndyH » Sun Feb 03, 2019 3:22 pm
My Laptop OBDwiz has been updated - all of my PID's still work.
What I did find was that I needed to go on-line with the cable plugged in every month or so otherwise it would require the activation code - guessing it is just talking to OBDWiz and verifying the cable.
Make sure that the Professional Add-On is listed as "available" in your licence features screen.
Maybe remove / reinstall the PID's?
Post by hotflash44 » Sun Feb 03, 2019 5:37 pm
i have had the OBDwiz for awhile now, and only used to check that it worked and the throttles were in balance,they were. i don't want to experiment with the bike as it runs great,but if i ever need to balance/adjust the idle how sensitive are the little screws on the bottom of the throttle bodies? :cheers:
Post by Tomcatfixer » Sun Feb 03, 2019 5:46 pm
Please remember that the idle stop adjustment screws are only to be used for setting idle and performing throttle body balance at idle. This is only half of your throttle body balancing. You will still need to balance the throttle cables to make sure that they are opening the butterflies equally. you can check to see how sensitive the screws are yourself, by turning them and listening to the idle go up or down.
Donbmw
Post by Donbmw » Sun Feb 03, 2019 6:09 pm
[/qu
I do have the add-on listed. Had planned on reloading the PID’s.
Don
Post by hotflash44 » Sun Feb 03, 2019 6:26 pm
thanks,i havent used the obdwiz since the day i set it up,so i tried it today and all is perfect even the trail tech tach was spot on. at first i thought the soft ware wasent working, but found that i needed to go to connections and then pick ECU and it came alive. thanks for the advice TCF,your the best :cheers:
Post by Mr Wazzock » Mon Feb 04, 2019 3:47 pm
extremely
We're talking gnat's whisker fractions of a turn at a time, I've watched the dealer doing it.
Post by hotflash44 » Tue Feb 05, 2019 9:44 am
extremely
thanks, thats what i needed to hear,hope i don't need to adjust, but someday im sure i will. i have hooked up my laptop with OBDwiz several times and all is staying good since new,7000km hope it stays that way. im one of those guys that until i do something with my own hands and brain im a little apprehensive. years ago i had a issue with taking out a spark plug on a Cushman scooter and to this day i cringe when i take that first crack to loosen a plug. guess im just a Scaredy-cat! :cheers:
