Connected to ECU's and Balanced Throttle Bodies!!!!!!!
BlueRockCrawler
Re: Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Post by BlueRockCrawler » Mon Jun 18, 2018 8:34 pm
Could be that code means something different than what OBDWiz and the rest of the world thinks it should. It should be a generic OBD2 code, but with the secret black box TB's we have, only EJK would know for sure.
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Kjelleyman
Post by Kjelleyman » Sun Jul 08, 2018 2:00 pm
Can you help ! I have a 2018 M 70 and need help on the pin connectors under the headlamp OBD 1-black wire-ground , 2-green wire-? , 3-red wire-supply voltage , 4-yellow wire-?. I can not find which one is can high or can low.Thanks fro the help NEWBIE
otompotom
Post by otompotom » Sun Jul 08, 2018 2:11 pm
Hi, I connected Retro yesterday and
green should be Can High
and yellow Can Low.
Kjelleyman
Post by Kjelleyman » Mon Jul 09, 2018 6:28 pm
Thank you otompotom
Donbmw
Post by Donbmw » Sat Jul 14, 2018 2:38 pm
I final also got the same scanner. With this Bluetooth scanner my IPhone or iPad is more usable for adjusting idles and syncing.
DammitDan wrote:The Tonwon OBD scanner linked below is the 3rd scanner model I’ve tried, and it has improved latency considerably for me (iPhone user). I’m still playing with the communication settings in OBD Fusion, but it connects via Bluetooth MUCH faster than the two WiFi units I tried, and the connection has remained stable thus far. I get updates on all dashboard meters in pulses that repeat fairly consistently every 1-2 seconds. I can finally use the scanner as a (slightly retarded) tachometer while riding.
[emoji106][emoji106] up on the info, yb1367!
yb1367 wrote:I emailed OBD software support and asked for their recommended adapter for Apple iOS devices and the reply was Tonwon BLE 4.0. It is bluetooth and Android compatible as well.
https://smile.amazon.com/gp/product/B06 ... XMGN&psc=1
Works with iOS app:
OBD Fusion
OBD Auto Doctor
Works with Android app:
OBD Fusion
Torque
Dashcommand
OBD Auto Doctor
OBD Car Doctor
Tonwon Pro BLE4.0 connection guide (iOS)
Plug OBD , RED light flashing
Turn the bluetooth on in your phone, BLUE light flashing.< Please noted. Bluetooth name is invisible DUE to it is not MFI device. Please continue to next step>
Go to OBD app setting and enble BLE4.0 connection type
Start the connection on the OBD app, GREEN light flashing.
Tonwon Pro BLE4.0 connection guide (Android)
Turn the bluetooth on in your phone. Select "Vlink-Android" to connect, BLUE light flashing.
Start the connection on the OBD app.
Connection Issues and Troubleshooting
No signal:Make sure the adapter is fully plugged in and check the cigar fuse of your vehicle.
Does not connect to App or connection drops: Check the App hardware requirements and make sure phone has connected . Check the App setting and make sure connection method is Bluetooth and hardware type is Bluetooth LE.Try with a different App and make sure only one App is running in the background each time.
Does not connect to the vehicle or fail to detect the OBD protocol: Make sure the vehicle is OBD2 compliant and the connector pins are not corroded. If it's at key on engine off mode, start the vehicle and see. Lastly try on a different vehicle.
Don
yb1367
Post by yb1367 » Sun Jul 15, 2018 12:36 am
Glad to hear. The bluetooth Tonwon BLE 4.0 works perfectly well with my iPhone also.
2016 Gear Up
Daisy Cutter
Post by Daisy Cutter » Sat Sep 01, 2018 4:33 pm
Switched to the TonWon bluetooth for Iphone today as well. Works great, Much better than Wifi. With wifi I was showing that everything was balanced but switching to the TonWon showed that I was out of balance at 1500-1800 rpm. I was able to make the necessary adjustments and the rig runs 100 times better than before.
North Alabama
2017 Ural Gear Up
Knolff
Post by Knolff » Sat Sep 01, 2018 10:54 pm
Same thing here - I just picked up an OBDII adapter from Burt1731 and the TonWon... together they work like a charm. Connection to my iPhone X is quick and so far very reliable; super excited to dig deeper into this project. Really appreciate all the work/research others have done to make this come together. I also want to give a big thanks to Greg (tractor_bike) for helping me!
Keith - Portland, OR
'18 Gear-Up
'15 Gear-Up(sold)
'18 KTM 500 EXC-F
'18 KTM 1090R
“The journey not the arrival matters.” – T. S. Eliot
Post by harryball » Sun Sep 09, 2018 11:56 am
To confirm 7E0 is the LEFT Outboard ECU and 7E1 is the RIGHT Inboard ECU, correct?
npshields
Post by npshields » Tue Sep 11, 2018 8:24 pm
Awesome information. I successfully made a cable for my 2018 Ural Gear-Up, adjusted the idle (a touch low) and then re-balanced the throttle bodies. However Ural did CHANGE the diagnostic port connector on the 2018 (I think the 2017 as well), it is now a 4 pin TE Connectivity part # 1-967325, I found one on Amazon for $3.66 :-) (search for "1 sets 4 Pin 1-967325-3 Auto Sensor plug waterproof"... ) took 4 weeks from China but it was the correct plug :-) For anyone needing to make the cable for this connector, looking at the 4 pin plug from the front (looking at the connector on the bike) the pins are CAN High (Top left), CAN Low (Bottom left), Ground (Top right), +12V (Bottom right) - Nick
Post by hotflash44 » Wed Sep 12, 2018 8:04 am
in the process of gathering all the cables to install the OBDwiz,type device i have noticed several companies now make some sort of EFI reading/balancing reader. i decided to go the laptop style rather than Iphone. makes me wonder if Ural will ever offer their official version of the software etc to the public? there was a post about DEERE tractor being unwilling to share their software and owners had to go to a dealer for adjustments,not very popular with the do it yourself farm crowd. EFI is here to stay so got to do what you got to do. :cheers:
Post by Tomcatfixer » Wed Sep 12, 2018 9:20 am
Many famers have turned to Russian-hacked versions of John Deere's diagnostic software to avoid expensive and time-consuming trips to the dealer. I'm surprised that a bored Russian hacker hasn't taken the initiative to crack the ElectroJet software. :P
Post by hotflash44 » Wed Sep 12, 2018 10:26 am
Ah!Ha! very interesting. :cheers:
BlueRockCrawler
Post by BlueRockCrawler » Thu Sep 13, 2018 12:53 am
LOL, I think it is Ukrainian firmware, but the article I read showed a keygen for the official firmware, maybe there's multiple ways to root your tractor. I've been in contact with someone in the Russian federation that has built his own retrofit based on microsquirt for $980. He goes by Artsemi on here, and if I could figure how to give him money in russia safely, I'd replace my blown Right throttle body and be tuning right now. I was hoping some Eastern European of some sort would get bored and root the Electrojet lawn mower EFI system.
2015 Ural Patrol
1996 Magna Deluxe
2004 919
1985 500 Magna
yb1367
Post by yb1367 » Thu Sep 13, 2018 3:03 am
What's wrong with PayPal?
2016 Gear Up
