Switch for rear brake light
54vintage
Post by 54vintage » Tue Apr 22, 2014 11:02 pm
Just curious if anyone else with a 2014 is experiencing a sticky switch. No doubt a item that is covered by the warrantee.....but annoying none the less.
Chuck Loftin
2002 1150 GSA with 2005 Ural tub
1985 K100RT
2014 Sage Green GU....off to a new home
1974 R90S----gone
2009 G650GS---outtahere
06motorradman
Post by 06motorradman » Tue Apr 22, 2014 11:12 pm
I had to replace my rear brake light switch on my 2011 model. Not sure if it is the same switch, but the older were prior to issues. I lubricated my new switch and that seems to help.
Sent from my SGH-T399 using Tapatalk
My Bikes: 2011 Ural T ( gone on but not forgotten )
2006 BMW R1200RT, 2011 KTM 990 SMR, 2014 Vespa 300 GTS Super, 2016 Honda CRF250L, 2016 Honda CRF110
SmellyGoatBoy
Switch for rear break light
Post by SmellyGoatBoy » Tue Apr 22, 2014 11:15 pm
Mine was covered by the warranty.
2012 Gobi Gear Up
38/125 jets
2 shims on OE needles
MKIII airbox upgrade
Raceway Perch Rings
2013 Branch pipes
Re: Switch for rear break light
Post by chaos2 » Tue Apr 22, 2014 11:21 pm
I got one on warranty, the same switch is a pretty common universal switch, spring and connections differ http://www.amazon.com/dp/B00230D6KQ/ref ... 7ILPBRUNCT
Roadking
Post by Roadking » Wed Apr 23, 2014 8:24 am
I had the same issue. I removed the switch and gave it a shot of WD-40. Let it run down into the switch. Also adjusted it to pull a little further than it was. Has been working ever since.
2001 HD Roadking FLHRI
MartyL
Benevolent Emperor
Benevolent Emperor
Re: Switch for rear brake light
Post by MartyL » Wed Apr 23, 2014 9:00 am
:twisted: You can not stop," The Evil Dreaded Rear Brake light switch" from unleashing its unholy rathe from the dark depths of the underworld! :twisted: OUT DEMON OUT! BEGONE EVIL ONE!!! :twisted:
1976 Yamaha XS650C
2018 H-D FLHXS
Post by Albuquralque » Wed Apr 23, 2014 9:58 am
Maybe we should have a "Rear Brake Light Switch" forum....similar to Oil Threads, or Deep Sump Debate..... :D
54vintage
Post by 54vintage » Wed Apr 23, 2014 10:11 am
MartyL wrote::twisted: You can not stop," The Evil Dreaded Rear Brake light switch" from unleashing its unholy rathe from the dark depths of the underworld! :twisted: OUT DEMON OUT! BEGONE EVIL ONE!!! :twisted:
This is what I was afraid of.....I'm calling in a priest, rabbi, monk, witch doctor....etc etc etc!! Time to sell the bike :wink:
Chuck Loftin
1985 K100RT
1974 R90S----gone
54vintage
Post by 54vintage » Wed Apr 23, 2014 10:14 am
Roadking wrote:I had the same issue. I removed the switch and gave it a shot of WD-40. Let it run down into the switch. Also adjusted it to pull a little further than it was. Has been working ever since.
Thanks Roadking.....I'll yank it out today and give it a once over. The only flaw on the Sage Green beast so far.
Chuck Loftin
1985 K100RT
1974 R90S----gone
Post by GHGoodwin » Wed Apr 23, 2014 2:11 pm
Note that the activation spring is shorter on the 2014's than before. Mine switch was also bad and the replacement came with the correct shorter spring. The original one had been cutoff and re-bent to fit. Can't photo right now but will get one for you guys tomorrow.
swoody126
Post by swoody126 » Wed Apr 23, 2014 6:51 pm
only found this thread, after picking up a new switch :D
i had tried the lube blast, air blast & politically incorrect vocabularly
all, to no avail :(
the old switch had some RUST on the blades & an invisible knot in the slider, making it stick open
$20±, a little upside down work & i'm back on the road w/ a working system
all n all, a pretty simple fix, for a part that MAY have been exposed to hostile environments :clap:
sw
Respect the person who has seen the dark side of motorcycling, lived, and still rides.
2008 GU
& a bit of most everything in the past
54vintage
Post by 54vintage » Wed Apr 23, 2014 10:28 pm
Gave it a once over, seemed to do it, no more sticking on, but still has a bit of a click to it when stepping on the pedal....might be going after a new switch if it acts up again.
Chuck Loftin
1985 K100RT
1974 R90S----gone
bdlaue
Post by bdlaue » Wed Apr 23, 2014 10:56 pm
No issues with switch, so far. :)
2014 Ural Patrol, red & white
2009 Honda Silverwing
2009 Honda Big Red
Riding since 12 y o, for 58 yrs now
Retired on a fixed income=poor
Post by GHGoodwin » Thu Apr 24, 2014 7:38 am
I keep a spare on each bike in with the extra bulbs. IMHO better to have lights. I've actually had a policeman let me off for a blown bulb when I offered to replace it while he watched.
Roadking
Post by Roadking » Thu Apr 24, 2014 8:23 am
Yes, it will still have a click when stepping on the break and when releasing. Mine does that too.
