Rust
Kilometers2
Rust
Post by Kilometers2 » Sat Dec 04, 2021 11:46 am
My new to me 2017 Sahara bought last month with 480 miles on it shows signs of what I take to be road use on salty roads. It was sold originally by Ural of NE and the original owner put only 277 miles on it before a friend of mine in Huntsville Alabama bought. I know for a fact it was indoors the past 3 years. Some of the bolts however are very slightly corroded and the front axle has rust around it as shown below. Is there anyway to clean this up without removing the wheel? It won't be difficult to take off and I am guessing I need to replace the bearings....
Miles
2017 GU Sahara
Previously 2007 GU, 2014 Patrol, and 2016 GU
Hero of the Soviet Union 2022
Re: Rust
Post by windmill » Sat Dec 04, 2021 12:24 pm
I've had good luck swabbing on Ospho with a Q-tip. It eliminates light rust and provides short term protection. Once cured overnight one can go over it with touch up paint or some sort of corrosion protectant like Fluid Film.
treebone
Re: Rust
Post by treebone » Sat Dec 04, 2021 12:36 pm
You are catching it early, no problem.
Other places to check are the sheet metal seams in your sidecar, especially the floor under the mats.
I treat them with a spray corrosion inhibitor, let it sit for a bit, then wipe excess with a coarse cloth.
There are several types available (amazon is a source) but this is what I use.
This stuff smells EXACTLY like ALOX cast bullet lubricant.
Alox, if memory serves, was originally used as a corrosion inhibitor in gear oils. It was found to be a good cast bullet lube when mixed with beeswax in the late 60's.
2021 OD Ct, disguised as a Gearup
Sold in 20 minutes flat... -2015 Gearup Sportsman Adventure Camp Wandawega Edition 13,500 K
Gone but not forgotten- -2009 Patrol, Sold at 26000 klicks
Ransom
Re: Rust
Post by Ransom » Sat Dec 04, 2021 12:41 pm
Agree. Depending on the location you might want to use a rust converter and primer product. Lots of them on Amazon.
Mark M, Hazelwood, Missouri
2016 Ural cT
2021 Honda CRF300L Rally
History:
2013 BMW R1200GS
2000 Kawasaki Super Sherpa 250
1995 BMW R1100RS
1983 BMW R80RT
1983 BMW R65 - the one I miss
1975 Suzuki TS185 - popcorn popper
Kilometers2
Re: Rust
Post by Kilometers2 » Sat Dec 04, 2021 1:20 pm
Thanks for the advice and recommendations. I was fortunate that Ural of NE applied undercoating to the entire sidecar tub. It is the gray wrap around at the base of the tub. A quick look makes me think they did the inside of each fender too.
Miles
2017 GU Sahara
aduthie
Re: Rust
Post by aduthie » Sat Dec 04, 2021 2:43 pm
The undercoatings are applied at the factory as an option, for $600 MSRP.
Andrew Duthie / Nashville Motorcycle Repair / Ural and Vintage Sales & Repair
Re: Rust
Post by chaos2 » Sat Dec 04, 2021 7:20 pm
Probably a good idea to pull the front axle and give it a good coat of anti-sieze. Mine and other's have rusted in place and would have been impossible to remove if I had a flat on the road. I was in the comfort of my garage and it was still a heckofa challenge even with a full array of breaker bars, various nut loosener concoctions and BF hammers. (and yes, I knew the thread was backwards)
Past afflictions include limey cars and motorbikes, R60/2, R65ls, 2012 Ural GU & a Citroen ID-19.
Nowadays a bunch of bicycles, 1987 K75s,
and a brand spanking new 2023 flat green Gear Up!
treebone
Re: Rust
Post by treebone » Sat Dec 04, 2021 8:05 pm
The undercoat is a good idea, check under the rubber mats anyway. It is a good place for moisture
to collect and not dry out. If you see rust anywhere, it is time to have a good look around to catch it early.
I had my 21 Ct undercoated and the interior of the tub coated for good measure.
Re: Rust
Post by Mr Wazzock » Sun Dec 05, 2021 3:55 pm
Plus, do check the outer seals in the hubs. Any sign of wear, a gap is formed letting water and dirt get in, then the bearings are at risk. Guess how I know! Your's shouldn't at 488 miles, but it is something to bear in mind for later – mine failed at around 12,000 miles.
Forv rust proofing, also spray ACF50 or whichever you prefer into the seam joints of the fenders – where the curved part is welded to the flat side parts (only 1 side part on sidecar) – hope that makes sense.
I put a generous amount of ACF50 on the tub and trunk floors before putting the mats back in. Seems to have worked so far.
HTH :D
Re: Rust
Post by VWK75S » Fri May 26, 2023 5:32 am
2017s don't have dust covers?
2010 ST 10,000kms
2009 GearUp 165,000kms
Re: Rust
Post by Tomcatfixer » Fri May 26, 2023 6:01 am
No. The switch to sealed bearings eliminated the need for bearing tensioners and dust covers.
2015 cT "Mobile Chernobyl", 2003 Retro Solo, 2001 Patrol "Little Red Bear", 1999 Tourist "The RPOC", 1994 Honda VFR750F, 2007 BMW K1200GT
1993 Honda CBR600F2 - 1984 Yamaha FJ1100
Two 1986 Yamaha FZX700S Fazers
1997 Deco Classic
1998 Tourist "The Heap"
Re: Rust
Post by windmill » Fri May 26, 2023 8:03 am
The dust covers came back in 2020.
Re: Rust
Post by Tomcatfixer » Fri May 26, 2023 8:15 am
1997 Deco Classic
