2014 Turn Signal Flasher
Post by Albuquralque » Wed Jun 13, 2018 1:08 pm
The stock flasher is a TH-S502.
Of course these are made in Taiwan and are spec'd for some not so common vehicles.
Has anyone found a suitable substitute for this?
Darrell - Albuquralque
EFI Map OR 1.02
Throttle Body Vacuum Ports
K&N Air Filter
wooden nickel
Re: 2014 Turn Signal Flasher
Post by wooden nickel » Wed Jun 13, 2018 5:36 pm
I used an EF36L in my M70. I don't know if your Patrol is wired the same. I like the solid state relays.
Nick
Eric N
Post by Eric N » Fri Jun 15, 2018 1:37 am
When I installed the signalminder (self cancelling turn signal controller) in my 2018, it was a standard 3 pin relay. I had to rewire because my power/ negative were backwards from the one I bought on eBay, but the correct signalminder says it's for Kawasaki cruisers and other Japanese bikes. Swapping the wires in the bracket was easy, just a small screwdriver/ dental pick to pop them loose, then push back in place in the correct location.
You should be able to find a 3 pin in any auto parts store but you might need to swap wires to make options easier to find.
2018 Gear Up
2013 Retro Solo
2001 Patrol - Sold
Post by Albuquralque » Fri Jun 15, 2018 7:25 am
Eric N wrote:When I installed the signalminder (self cancelling turn signal controller) in my 2018, it was a standard 3 pin relay. I had to rewire because my power/ negative were backwards from the one I bought on eBay, but the correct signalminder says it's for Kawasaki cruisers and other Japanese bikes. Swapping the wires in the bracket was easy, just a small screwdriver/ dental pick to pop them loose, then push back in place in the correct location.
I found a Napa one that is readily available and works with any combination of lights - EP-36L.
EFI Map OR 1.02
K&N Air Filter
