Sean's R3W Steering Damper kits ready to ship
This is the place for dealers and other commercial entities to advertise and sell their Ural or Dnepr related wares. All listings must include a price or the MSRP.
Re: Sean's R3W Steering Damper kits ready to ship
I had Sean's damper on my '12 Patrol and enjoyed it. It went with the bike when sold.
Last may I bought a '11 G/U and bought a Ural N.E damper that uses a Bilstein shock, because Sean's was not available at that time.
That shock was much too stiff.
My question is;
Is Sean's damper significantly "lighter" than the U of NE's damper?
Thank you
Ragman
My question is;
Thank you
Ragman
Ragman
"There's the way it ought to be..... and there's the way it is" (Sgt Barnes)
2011 Ural G/U Gobi Camo
Location - Glide,Oregon
I also had this question as I was looking for a replacement for my 'updated' UralNE version that I replaced my stock damper with a couple years ago. It has now also blown and is giving me wobble. I don't want to just replace the same dinky damper every couple of years so this one seemed like a better option. This post hasn't had a reply in a while but maybe someone can weigh in.Ragmanxx wrote: ↑Fri Aug 27, 2021 3:40 pmI had Sean's damper on my '12 Patrol and enjoyed it. It went with the bike when sold.
My question is;
Thank you
Ragman
Thanks in advance.
I am an actual Ukrainian/Russian person riding a Ural.
Texas Hill Country
2016 Gear Up
2014 Honda CB1100
Texas Hill Country
2016 Gear Up
2014 Honda CB1100
- chaos2
- Hero of the Soviet Union - 2021
If you're even a little handy with tools it's easy to pick up a dampener, a heim joint, fabricate some mounts and do it yourself. Sean just put it all together in a kit. Bug dampeners are cheap, https://www.jbugs.com/product/113425021 ... d1e6b1a2ec
Past afflictions include limey cars and motorbikes, an R60/2, R65ls, & a Citroen.
Now bunch of bicycles, a still running '87 K75s,
and a trusty & rusty 2012 GU bought new
Dual K&N cones on homemade PVC intake, 40/137.5
Raceway needles, Modtop pipes, E starter delete
I put Sean's damper on my '12 GU when they first came out. Completely satisfied and it's a very durable piece. Oh, and it stops the bad stuff but doesn't make it heavy steering.
2012 Gear Up painted with Black Truck Bed Liner Spray Cans
Yeah, make your own. I posted a thread when I built mine. Here is the thread.
viewtopic.php?f=11&t=47616&p=596486&hil ... er#p596486
Others have posted reviews and I believer others have made them, too.
Certified Blatherer
Certified Blatherer
Thanks for the info on self made steering damper. However, New England Ural still sells a complete bolt on volkswagon styled damper which I ordered and is now waiting for install on my work bench. Sean is not in production anymore. After watching a fellow sidecar rider filming me riding down a rocky back country path, steering with one hand and holding his iPhone In the other filming while riding, I can see the value of adding the enhanced damper. I'd never have been able to take one haND off the handlebar with my 2020 with all the ruts jerking me one way or the other with the OEM damper that is on the bike currently.
History
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
- aduthie
- Contact:
You're replacing the Bitubo gas damper on a 2020? Even after making sure all the mounting bolts were tight and that you had it set to the maximum amount of damping? I've seen a couple that "weren't working," and it was just that the tab bolted to the lower triple clamp had gotten a tad loose. The thing with steering dampers is that any play in the mounting system results in a bit wobble, since the damper can't act until the play is taken up first.
Or maybe you're just tuning for more extreme conditions than most. I don't get much chance to do proper off-road on Urals.
Andrew Duthie / Nashville Motorcycle Repair / Ural and Vintage Sales & Repair
- Tomcatfixer
- Commissar
I haven't fully tested the newer Bitubo dampers, but I was under the impression that they are a quality piece of kit. I would think that replacing one with a non-adjustable Volkswagen Beetle damper would be a step backward.
- windmill
I believe you and Andrew are correct. Having many miles with a friction damper, a generic 2014-2017 hydraulic damper, a Bitubo damper, and having ridden a few rigs with automotive dampers, I would definitely regard them all as a step backwards from a Bitubo. If one finds the Bitubo inadequate, I believe it must be that something is out of wack as Andrew suggested.Tomcatfixer wrote: ↑Fri Aug 05, 2022 12:54 pmI haven't fully tested the newer Bitubo dampers, but I was under the impression that they are a quality piece of kit. I would think that replacing one with a non-adjustable Volkswagen Beetle damper would be a step backward.
If one's biggest priority is being able to one hand on rutted roads and eliminate feedback in really rough conditions, maybe retrofitting a friction damper might be the best solution. They aren't as refined on the street, but one can quickly tighten them down to mitigate even the most extreme conditions, and just as quickly back it off for normal conditions.
Curious how you know Sean has stepped away from his dampeners. Did he tell you?
Thanks and Best,
Yes. He sent me a PM a couple weeks ago. Said that there wasn't much traffic anymore on tge kit o 's he discontinued. I did get the kit from Ural installed yesterday so good to go. Must admit, it's a step up from even the 2020 damper which is a huge improvement from the handlebar friction damper.jeffsaline wrote: ↑Fri Aug 05, 2022 8:11 pmCurious how you know Sean has stepped away from his dampeners. Did he tell you?
Thanks and Best,
History
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
Ruski22,
Thanks for the reply. To bad Sean isn’t making them anymore as they are a good product.
