New Exhaust Part 3
Redblock
New Exhaust Part 3
Post by Redblock » Mon Jun 17, 2019 5:18 pm
Hey All,
So I finally got the muffler situation figured out.
I removed the "Crumb Cup" mods I wrote about.
I picked up 2 1 3/4 OD drop in baffles.
The new baffles were tack welded into place on the ends of the muffler cores. One baffle per muffler core
I then mocked up everything and fired her up. The raspy sound is gone as well as the backfiring.
All I have to do is get everything painted up and get a couple brackets fabricated and we are calling it done!
Thanks for following my post. I will post the final pictures when it is completed
Redblock
Re: New Exhaust Part 3
Post by Redblock » Tue Jun 18, 2019 10:07 am
Quick Update.
I used the hanger strap from the Dime City Cycles Muffler to secure the muffler to the bike. I used the stock mounting position and bolt. To do this, you must drill a new, larger hole below the DCC hole. Also mount the strap on the outside of the rubber bumper, just like stock. By doing this, it pushes the exhaust outward a little. There is zero movement or play on the exhaust system (just like stock.)
Post by Mr Wazzock » Tue Jun 18, 2019 5:17 pm
chopfather
Post by chopfather » Tue Jun 18, 2019 5:20 pm
It sounds good like that. Where did you get the baffles ? I might pick one up for the muffler that I bought.
Rick Current Bikes- 2018 Ural Gear Up
'91 HD Sportster
'81 Yamaha XS650 - 2 of them, both works in progress
'2015 Coleman CT200U minibike
Redblock
Post by Redblock » Tue Jun 18, 2019 6:42 pm
chopfather
Post by chopfather » Thu Jun 20, 2019 2:44 pm
Thanks for the link. I'll order them this evening.
'91 HD Sportster
