Convert '06 to LED?
Nemo
Convert '06 to LED?
Post by Nemo » Thu May 16, 2019 8:40 pm
Hi Guys wanted to convert to LED and with me I always need things idiot proof
https://www.uralne.com/led-bulb-kit/
I saw this kit but it says '08-'16 so what would I need different for '06 and what would I need for head lamp?
Thanks!!
06 bucket of rust and peeleing paint
Re: Convert '06 to LED?
Post by chaos2 » Thu May 16, 2019 9:36 pm
No idea what changed in 08 bulb-wise, maybe call Ural NE and ask. As for the headlight they sell a H4 LED but you also need the Hella H4 headlight conversion to put it in. https://www.uralne.com/h4-led-headlight-bulb/
dogboy443
Post by dogboy443 » Fri May 17, 2019 12:01 pm
For $90 I'll order the bulbs and install them for you P).
Here's what i ordered from SuperBrightLED's and other sites:
Idiot lights:
1 BA7S-R: Red $0.89
1 BA7S-A: Amber $0.89
1 BA7S-G: Green $0.89
1 BA7S-B: Blue $0.89
Tub running and license plate and tub brake
4 1156-CW30-CBT: Cool White $9.95
Bike tail light:
1 1157-R27-T: Red $9.95
Tub brake:
2 BA9S-W-120-12VAC: Cool White 120 Degree 12V $0.98
Directionals:
https://www.amazon.com/gp/product/B0051 ... UTF8&psc=1
For all external bulbs:
https://www.amazon.com/gp/product/B000A ... UTF8&psc=1
I hope this helps. The idiot lights are a pain in the a$$ to swap out, wicked tight on my 06 Tourist, but it's do-able.
Mark Masztal
Total Bad A$$ - Ha!
Nemo
Post by Nemo » Fri May 17, 2019 1:48 pm
And if I remember correctly I read somewhere I need to install a diode? I assume that's what the pigtail is in the kit, would the hookups be different between an 06 and 08?
dogboy443
Post by dogboy443 » Fri May 17, 2019 2:47 pm
You would need a diode to have the indicators blink. I did not do that. I went with new straight forward bulbs. I am not an electrical genius.
Mark Masztal
Total Bad A$$ - Ha!
Post by chaos2 » Fri May 17, 2019 2:59 pm
FWIW, when I converted to LED I left the blinkers incandescent. Just didn't seem worth the hassle.
Post by wooden nickel » Fri May 17, 2019 4:41 pm
You can buy a cheap full wave bridge rectifier and put the two wires going to the indicator to the two AC inputs of the bridge and the DC outputs of the bridge to the LED indicator, it should work. It does on mine.
Post by wooden nickel » Fri May 17, 2019 4:55 pm
I bought a few cheap bridges from Ebay: https://www.ebay.com/itm/10pcs-Bridge-R ... 280678db27
You can help out several friends with them. Just crimp two male quick connects to the AC and two female QD to the DC and place in between the wires and the indicator. If you add short wires to the Bridge leads, it is easier to place out of the way. Don't forget to insulate the bridge leads. I used insulation I stripped off the wires I used to hook it up. Could have just taped them.
Nemo
Post by Nemo » Fri May 17, 2019 5:34 pm
Thanks Guys!!
Post by INSUBORDINATOR » Wed May 29, 2019 7:10 pm
Like DOGBOY 443, I shopped for all my bulbs online (Ebay) if you know what is printed on the bulb you remove, you can figure out what you need.
I even bought a new Diamond Cut Reflector with a projector lens in it for $13. My COBB CREE HEADLIGHT BULB was $10. but most bulbs were under a dollar each, They even sell an LED flasher Unit to flash your directional for $3.
Only problem I had was rewiring my Tail/brake light as in 02 it was wired in reverse. Auto parts stores sell a new universal socket - EZ.
I got all/every bulb etc for under HALF of what retailers get (most came from China - but that's where the parts stores get them - before gouging)
