Jack for Ural
Re: Jack for Ural
Post by Pterodactyl » Thu Apr 25, 2019 8:33 am
This is a Jack... my grandson Jack. That is a Ural. Does not work particularly well when it comes to elevating the rig, but it is a good time. The neighbor's dog, Avery, is not of the slightest help.
The Outpost, Silver City, Montana
Team Pterodactyl
Re: Jack for Ural
Post by windmill » Thu Apr 25, 2019 10:13 am
Small screw jack. Better than the scissor or hydraulic jacks I carried in the past.
Re: Jack for Ural
Post by jaybird » Thu Apr 25, 2019 10:31 am
Hey Windy, you’ve been quiet lately, where you been?
What kind of a handle/whatever are you using to make your jack go Up and down?
I like to weld a 3/4” nut on the finger wheel so I can use a ratchet, wrench, or speed bar/socket . I'm curious what you’re doing, maybe you came up with something better.
Re: Jack for Ural
Post by S 854 » Thu Apr 25, 2019 11:08 am
Daisy Cutter wrote:
Thu Apr 25, 2019 5:48 am
2x4 for me, just like Van demos in his video.
Maybe the thread should be titled: “Jack for Ural for Old Guys”...
ANYTHING I can use to keep from twisting -pulling-lifting-straining is gonna make my day and my ride better... :oops:
...and yes, I have used the board-under-the-wheel thing in the past... it works...
Re: Jack for Ural
Post by windmill » Thu Apr 25, 2019 11:33 pm
It came with a 3 section folding crank handle that's about 54" long opened up. It has a hooked lip that sort of latches into the square hole in the finger wheel, makes it real easy to use.
My M70 has been gas-n-go, and is my daily transportation so I don't have much to say since commuting, and scheduled maintenance aren't very interesting. Finding and rebuilding old military and camping Gasoline stoves and lanterns has become my outlet for tinkering and fixing things.
Re: Jack for Ural
Post by windmill » Thu Apr 25, 2019 11:41 pm
I expend enough energy working and doing chores, if I get a flat out on the road I want the quickest, easiest method available as they seem to come in inopportune times and places.
Re: Jack for Ural
Post by jaybird » Sat Apr 27, 2019 1:28 am
jaybird wrote:
Wed Apr 24, 2019 3:40 pm
Bobcat MT55 is a toy :lol:
120HP cummins 4BT powered Ural lift
All showboating and ego stroking aside; I carry a small unidentified scissor jack, modified with a 3/4" nut welded to the screw so that you can use a wrench or ratchet to operate it, no need to carry around a bulky handle. It also has a small piece of angle iron welded to the top to make it grab under frame better. I can't seem to find a photo on my computer but I'll try to take one later and post it up.
gobium does have a trick with a 2"x4" that seems to work pretty well, maybe he'll share that, if he's not to busy feeding his ego.
By the way, Welcome aboard! :cheers:
Try this;
I have a mechanical screw jack somewhere that I also welded a nut onto, I can't seem to find that though, it's probably holding something up.
Re: Jack for Ural
Post by S 854 » Sat Apr 27, 2019 11:59 pm
The nice thing about these jacks (whether it be “scissor” or “mechanical screw”) is that they were designed to lift a corner of a car/truck... so very little effort is required to lift even the heaviest part of our rigs... I use basically a glorified screwdriver to turn mine...
Marine Corps Codu
Re: Jack for Ural
Post by Marine Corps Codu » Sun Apr 28, 2019 1:11 am
On my scissor Jack I use a ratchet handle. The square male part fits into the Jack female
Keith Birkhofer
Marine By Choice
Former Bikes:
1947 Cushman Motor Scooter
1958 Cushman Motor Scooter
1964 Yamaguchi
1965 Honda 250
1968 KZ100
1960 Honda 55 (2 of them)
2002 Honda Gold Wing
2006 Ural Patrol
2005 BMW GS1200
treeman1942
Re: Jack for Ural
Post by treeman1942 » Mon Apr 29, 2019 12:31 pm
I got one of these:https://www.amazon.com/gp/product/B009W ... UTF8&psc=1
I like it but it's larger and heavier than I realized, but high quality.
2019 Ural Gear Up, OD Green
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
Re: Jack for Ural
Post by BinDerSmokDat » Wed May 01, 2019 9:56 am
I use the same kind of jack as S 854.
Mechanical screw-type "bottle jack," no hydraulic fluid to leak.
They have been standard equipment in cars for years so you find them cheap at junkyards, swap meets, etc.
Mine is from a Jeep Cherokee, so it it can easily lift the whole bike.
The gear ratio is such that you can turn it with a large screwdriver, no need to even bring the jack handle.
Re: Jack for Ural
Post by BinDerSmokDat » Wed May 01, 2019 9:57 am
29 lbs? Put brackets on it and use it as a skidplate, double duty.
Re: Jack for Ural
Post by BinDerSmokDat » Wed May 01, 2019 10:02 am
We say this at least once an off-road ride when someone needs lifting/towing/tugging out of a situation.
Re: Jack for Ural
Post by jaybird » Wed May 01, 2019 12:40 pm
I've found them abandoned on the side of the trail, David just picked up a nice scissor jack on our last ride. One of the best ways to acquire one :D
More fun than buying one.
Re: Jack for Ural
Post by INSUBORDINATOR » Sun May 19, 2019 10:06 pm
+1, consistent with my affection for old technology, this Model "T" Jack is perfect (& easy) for URAL lifting. It is NOW painted gloss black, with a gloss white tip on the handle. Glued leather into the curved lifting shoe = DELUXE. Highly recommended.
Hydraulic bottle jacks are always oily
Scissors jacks always fall over while cranking to adjust
small $25. dollar roll around floor jack are good - but bulky & fade when old.
