Paint Top Coat Recommendations
petermertos
Re: Paint Top Coat Recommendations
Post by petermertos » Sat Feb 02, 2019 1:32 am
INSUBORDINATOR wrote:
Fri Feb 01, 2019 1:49 pm
lendrinkard wrote:
Wed Jan 23, 2019 6:05 pm
I used spray on polyurethane and then coated the seams with boat vanish. My 2012 has held up pretty well.
I have also had good results with spray EXTERIOR POLYURETHANE Spar Varnish over more delicate finishes. It can become fuel resistant when fully cured, & very tough. It comes in gloss or matte. If you have spray equipment it can give an interesting toned down effect, using brown or other colors mixed in. IF I used it on a fuel tank I'd be very careful for a while when filling, & have a paper towel handy. I have found a piece of fine wire screen placed in the tank opening, after fill up, limits fuel sloshing while moving. These were sold as accessories for older Urals probably to catch debris in gas, but sure worked to eliminate fuel splashing.
Is there a reference to the particular product? Interested in matte varnish.
Going to use Meticulous Matte Detailer & Spray Sealant for now.
2012 Solo
1999 BC
Portland, OR
Post by INSUBORDINATOR » Sat Feb 02, 2019 2:27 pm
Home Depot's PAINT DEPT has it. Can't remember the brand, but they all have it - UV Proof is in Green Rattle Cans. They have both Matte, & Gloss. The Gloss is always toughest. All good for many uses.
cateyetech
Post by cateyetech » Sun Feb 03, 2019 4:14 am
Hey galcoste
That's our favorite color :D :lol:
Fall foliage and red dirt :lol:
:D
Also as stated earlier and over on the HD forum is Spray Max 2K
https://www.amazon.com/U-S-Chemical-Pla ... B0043B7UQY
I have not used this but have read several positive reports and they say it's Very Good :)
Good Luck
from one of the pumpkin pack
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
2003 Gear-Up Ромашка Мзй
2000 Patrol Teh Урал
glacoste
Post by glacoste » Tue May 07, 2019 4:10 pm
Found Some!
2013 Gear-up
glacoste
Post by glacoste » Thu May 09, 2019 1:01 pm
Top coating went on today.
Next .. sidecar fender install.....
2013 Gear-up
Post by windmill » Sat May 11, 2019 9:20 am
thumbnail - 2019-05-07T160605.051.jpgFound Some!
Very good choice, I used the semi matt clear on a WW2 Coleman stove I restored. Its totally fuel proof, stands up to the heat, and is tough so it doesn't scratch or mar.
Post by INSUBORDINATOR » Sat May 11, 2019 1:19 pm
Lmo wrote:
Sun Jan 27, 2019 7:00 pm
It's holding up pretty well, considering my old Dnepr fuel tank cap leaks like a sieve. I never fill the thing all the way up because it tends to "weep".
Here is a FIX for fuel slosh - that escapes the lid. European part dealers sell a fine screen drop in strainer (probably to clean dirty gas) I happened to buy one for my 1994 650 Ural with a batch of other parts. I was thrilled & surprised to find it remedied sloshing fuel escaping, by catching & diffusing the waves, worked even when tank was very full.
Bet it will work for you to. You could make make one from extra fine screen. The "ready made" one was very easy to get out for quicker tank filling with clean USA Gas.
Best wishes, C.
cateyetech
Post by cateyetech » Sat May 11, 2019 3:13 pm
thumbnail - 2019-05-09T125420.912.jpgthumbnail - 2019-05-09T125414.081.jpgTop coating went on today.
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
wyowillys46
Post by wyowillys46 » Sat May 11, 2019 4:08 pm
petermertos wrote:
Wed Jan 30, 2019 8:49 pm
I would recommend spray max 2k matte clear coat if you want matte finish.
This is the only stuff you should be using. Only use it outside though. The isocyanates will f$&@ your lungs up.
Morgan
'06 Gear-Up
195? M72/K750 hybrid
Post by Lmo » Sun May 12, 2019 12:03 pm
I have one. I think it's more the fuel cap itself; the retaining tabs seems weak. I tweaked them up a tad, and added two gaskets to help 'preload' them but it still weeps fuel if I fill the tank all the way. So I dont'...
Post by windmill » Wed May 15, 2019 12:52 am
I ran both KMZ and Dnepr tanks on my 07 Patrol, both used the same cap and both weep some. No thickness or type of gasket eliminated it, and the filler screen didn't make the slightest difference.
I also tried several style of caps, the only thing that worked was not filling the tank all the way.
Post by windmill » Wed May 15, 2019 12:57 am
Its the only spray paint I've used that is actually fuel proof.
