M70 windshield
Papa mike
M70 windshield
Post by Papa mike » Wed Feb 07, 2018 5:52 am
Why won't a patrol windshield not fit on my m70? How good is a plexstar 2 on one?
2017 m70, 2002 hd,69 Manx, spec const vw trike. 67, riden sickles since I was 10.
Life is hard, it's harder for those who are on my bad side. :lol:
Re: M70 windshield
Post by VWK75S » Wed Feb 07, 2018 8:51 am
I was a little disappointed in the Plexster2. :( Had to make custom lower brackets (came with dumb hose clamps) :x .
Also made a small wind brake to stop the tornado :shock: coming off the top right of the gas tank.
That being said I got it just about dialed in. :)
2009 GearUp 145,000kms
Re: M70 windshield
Post by windmill » Wed Feb 07, 2018 11:46 am
The Ural windscreen will fit, but the Retro/M70 headlight brackets sometimes crack when its installed. I have the Plexistar2, and like VWK75S, It isn't perfect but can live with it. I simply purchased some longer narrow hose clamps and used the standard mounts.
Papa mike
Re: M70 windshield
Post by Papa mike » Wed Feb 07, 2018 3:00 pm
Thanks , appreciate the info. I will look mine over and see if another way to do lower mounts. Would Ural shield mount in front of headlight, or is it wishful thinking?
Re: M70 windshield
Post by VWK75S » Wed Feb 07, 2018 4:17 pm
windmill wrote:I have the Plexistar2, and like VWK75S, It isn't perfect but can live with it.
I wonder if the lowers on the Plexistar3 help with the wind form down under.
Re: M70 windshield
Post by windmill » Wed Feb 07, 2018 4:27 pm
Perhaps, but I have leg guards which direct some airstream upward anyway, and would be in the way of the Plexifairing 3 lowers.
Re: M70 windshield
Post by windmill » Wed Feb 07, 2018 4:33 pm
Papa mike wrote:Thanks , appreciate the info. I will look mine over and see if another way to do lower mounts. Would Ural shield mount in front of headlight, or is it wishful thinking?
If you're determined to use the Ural windscreen, it probably wouldn't be an issue if you made a lower mount that attached to the lower tripple tree, and not attach it to the headlight.
Re: M70 windshield
Post by VWK75S » Wed Feb 07, 2018 6:23 pm
FYI,
Re: M70 windshield
Post by Speedbump » Wed Feb 07, 2018 6:46 pm
Plexifairing 3 works awesome on my Retro. Takes a little time to dial it in, but keeps the wind off.
Glenn³
Red Dwarf
Re: M70 windshield
Post by Red Dwarf » Sun Feb 11, 2018 3:25 pm
Speedbump wrote:Plexifairing 3 works awesome on my Retro. Takes a little time to dial it in, but keeps the wind off.
+1
http://www.sovietsteeds.com/forums/view ... ng#p628470
2012 Retro
