Homemade 2 into 1 exhaust test vid
54vintage
Post by 54vintage » Sat Nov 11, 2017 3:42 pm
Here's a short vid of the 2 into 1 exhaust system.....still some brackets to make....but I'm almost there.
Chuck Loftin
2002 1150 GSA with 2005 Ural tub
2014 Sage Green GU....off to a new home
1974 R90S----gone
2009 G650GS---outtahere
Re: Homemade 2 into 1 exhaust test vid
Post by VWK75S » Sun Nov 12, 2017 7:30 am
:thumbsup: Sounds good
2009 GearUp 145,000kms
Post by siberman1 » Sun Nov 12, 2017 12:16 pm
What is the thing with yellow/blue lights? (Yellow Arrow)
What kind of muffler did you use?
Can you do better still photos of brackets mounting the pipe and muffler?
Curious
54vintage
Post by 54vintage » Sun Nov 12, 2017 1:06 pm
VWK75S wrote::thumbsup: Sounds good
Thanks John.....hope to have it on the road today for a real test
Chuck Loftin
1974 R90S----gone
54vintage
Post by 54vintage » Sun Nov 12, 2017 1:11 pm
siberman1 wrote:What is the thing with yellow/blue lights? (Yellow Arrow)
Curious
The thing with the lights is a Dobeck unit
The muffler is from a Heritage Soft tail Harley
I'll post some shots of the mounting points soon....yet to make the bracket that holds the muffler
Chuck Loftin
1974 R90S----gone
54vintage
Post by 54vintage » Sun Nov 12, 2017 7:52 pm
Curious
Here's the muffler bracket
Chuck Loftin
1974 R90S----gone
Tin Man
Post by Tin Man » Sun Nov 12, 2017 8:52 pm
Sounds good.
2007 GearUp (Arctic #1)
130/45 jets, KTM rock solid mirrors, Delaware Dave's outstanding trunk lock, Mr. Cob's most excellent skid plate, Cycra Probend smashproof hand guards, Duro strong like bull 307's, RotoPax damn near bulletproof fuel cans, MKIII all but water proof air box and Dimples super duper magnetic drain plugs all around...oh yeah, and a manual fuel petcock.
.........if you see something that needs doing, just do it........
54vintage
Post by 54vintage » Mon Nov 13, 2017 12:18 am
Tin Man wrote:Sounds good.
Thanks Mike....I was a bit concerned it was going to be overly loud.....but after a 40 mile ride today I was quite happy with the sound. If one likes to travel on bikes any distance....the quieter the better :wink:
Chuck Loftin
1974 R90S----gone
Post by siberman1 » Mon Nov 13, 2017 12:27 pm
You mean that the Harley Noise does not come with the muffler? :wink: :sarcasm: :clap: I think I have the same muffler, only in black. Actually I have 4 different sets (of 2), but I do not know what kind of HD they came off of. All are new throw-aways by knowledgeable HD owners....
I removed the air restrictor seal on my Victory to get a few more HP. Then I rode back to Spirit Lake IA. Unfortunate for me, I did not take the seal with me! I was sick and tired of the added noise within 100 miles of a 3500 mile trip. When I got back home I put back in. Whew!, quiet again.
How did you bend the pipe so that there were no wrinkles in it? Where did you find stainless pipe? How did you connect the different diameters together? HD to pipe to Ural? Connection part? Curious.
Post by jaybird » Mon Nov 13, 2017 2:52 pm
Nice work on the exhaust. :cheers:
For anyone that cares to know, all modern H-D factory mufflers that I've seen, have the motorcycle model number stamped into the muffler (as in XLCH, FRXS, etc.), you can almost see it in one of the above photos.
54vintage
Post by 54vintage » Mon Nov 13, 2017 9:13 pm
Didn't have to bend the tube....the entire system was made from tube and weld type fittings for food grade applications. It was constructed from scrap pieces from work I'm doing where I work. The only diameter change that had to happen was from the 1 1/2 inch that fits over the Ural headers to the 2 inch which is the size of the HD muffler. The connection point is made by two 2 inch sanitary fittings and the clamp (see photo)I made it that way so I can drop the muffler off to change the tire if needed.
Chuck Loftin
1974 R90S----gone
54vintage
Post by 54vintage » Mon Nov 13, 2017 9:28 pm
jaybird wrote:Nice work on the exhaust. :cheers:
Thanks Jaybird.....this one has a FDX 1450 stamped in it....also built in cats...didn't know they did such things.
Chuck Loftin
1974 R90S----gone
Post by jaybird » Mon Nov 13, 2017 10:03 pm
You're welcome.
I didn't know that some have built in cats either, are they marked as such? I wouldn't want to tarnish my reputation as a scofflaw!
What makes those pipe fittings sanitary? I've heard that term, is it just the stainless steel, the lack of nooks and crannies inside, or something else?
54vintage
Post by 54vintage » Tue Nov 14, 2017 12:21 pm
You're welcome.
Yes there is a stamp that says USA Catalyst on it. Also a warning not to use it on non approved motorcycles...fed codes and such....since it a Ural....we're good to go :wink: The fitting is called that because one can tear it down quickly and clean it....although it is a nicely polished piece of stainless steel. These types of fittings are used in the dairy industry a lot.....one clamps a silicone seal in between the faces and bingo!! a leak proof joint. :cheers:
Chuck Loftin
1974 R90S----gone
