iKon Suspension for Urals
BlueRockCrawler
Re: iKon Suspension for Urals
Post by BlueRockCrawler » Fri Sep 28, 2018 11:28 am
INSUBORDINATOR wrote:
Thu Sep 27, 2018 12:13 pm
I Can't & Won't spend what IKON s cost.
So why even bother posting your negative opinions without offering anything helpful to the conversation? Ikon is trying to do better and is the only shock company I've seen so far that is asking for our help to do so. Why post some anecdote about how you had a bad experience with shocks that were not made by Ikon without posting what the actual root cause of the failure was so that Ikon doesn't make the same mistake? :cheers:
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Post by INSUBORDINATOR » Fri Sep 28, 2018 12:21 pm
Posted so you'll know that Oil filled shocks are adequate on a bike with more in common with a tractor than a racer, these MAY be located, & found to work - if you are inventive & look around. I WAS able to find great oil shocks for another application while others spent 5 times the price on Ikons.
I'm still using my 16 year old Russian oil shocks, When I need to replace them - I will take the trouble to hunt some up, then inform everyone of the results. Hopefully I will have encouraged some other rider to come up with a viable inexpensive solution - which might make my search easier.
An excellent reason to exercise free speech. Can't help it if someone's shorts get in a wad.
fpk977
Post by fpk977 » Fri Sep 28, 2018 8:57 pm
I have an inexpensive solution for my 2017 cT, it is to stick with the stock Sachs shocks!
2017 cT Terra-Cotta "SHOPPING CART" (sadly sold)
2018 Indian Scout
U.S Navy vet 1976-1982
Retired Law Enforcement [very retired!]
9/11 NYC Response Team
Fan of Hops & Barley
Franco
BlueRockCrawler
Post by BlueRockCrawler » Sat Sep 29, 2018 11:18 am
Sorry if my autistic post came across wrong, but it's certainly not MY shorts that are in a wad I'm just calling :bs: . From their website "Twin Tube Hydraulic Damper" "Rebuildable". I don't believe that the 7610's being discussed in this thread are gas charged. The 7614 series specifically enumerates "Gas charged" but the 7610's don't and the basix don't enumerate this either.
2015 Ural Patrol
1996 Magna Deluxe
2004 919
1985 500 Magna
Yakatak
Post by Yakatak » Thu Oct 18, 2018 2:05 pm
:lurker: Still hopeful.
2014 Ural Gear Up - Asphalt
Post by Lmo » Sat Oct 20, 2018 1:17 am
Waiting ..
JohnS
Post by JohnS » Mon Nov 19, 2018 5:30 pm
Are these shocks available now? I looked on iKon's website and I see the Ural application listed in one place but when you try to order I don't see anything. Has anyone installed a set? Any ride reports other than what is listed above?
Post by Snakeoil » Tue Nov 20, 2018 9:03 pm
With a year and approaching I suspect Rodger might be busy tidying up business requirements. The last test rider finished up this summer and I suspect but I'm not sure that the shocks were returned to Rodger. And just for the record the spelling of Rodger is not my choice. It is how Google apparently spells Rodger when you speak into your phone. Anyway... We learned that once again not all things Ural are the same. There was an interference in the fit up on the shock for my sidecar wheel, and we discovered another fit up issue on the rear swing arm with the last test rider. So Rodger has a little more work cut out for him with regards to a one-size-fits-all set of shocks. I also suspect that the Prototype shocks maybe coming back my way so I can spend more time with them and swap out Springs to see if there's an advantage of having different spring rates for the three different corners of the rig. If Rodger has time to visit the site and sees this post you'll probably chime in and let us know where things stand. As you can imagine running iKon USA keeps him pretty busy. Happy Thanksgiving to all.
BillyG
Thread Killer
Thread Killer
Post by BillyG » Wed Nov 21, 2018 7:39 am
I wrote Rodger x3 a couple month ago lto return the shocks but never heard back. Side tracked with work as the company I work for got bought out and was swamped in the transition. Walked into the shop and saw the box...figured I’d better jump back on it...
Bill Glaser
2002 Ural Patrol "CYKA"
Post by Lmo » Wed Nov 21, 2018 2:43 pm
JohnS
Post by JohnS » Fri Nov 23, 2018 1:25 pm
Thanks for the update
Post by Claus » Mon Apr 08, 2019 2:07 am
I saw on the European IKON site that they offer Shocks for Ural 08-12 now. They suggest to use article no. 7610-1664SP14 but they seem to be not available yet. Any news in your country?
https://www.ikonshocks.com/de/welches-i ... n/ural.php
owned bikes: 93 Ural rig domestic model, 01 Ural 750 rig, 92 BMW R100GS, 92 Suzuki GSX1100G rig, 95 BMW R100R rig with Ural sidecar, 98 Ural rig with BMW drivetrain under construction
Post by Lmo » Mon Apr 08, 2019 4:21 am
Post by INSUBORDINATOR » Mon Apr 08, 2019 1:12 pm
GLAD I'm patient, & there is nothing wrong with my old shocks yet. Wonder if they're bone dry inside - they don't even leak.
Not complaining - or even unhappy. couldn't afford them anyway - IF they were even available for an 02..
Post by Lmo » Tue Apr 09, 2019 4:05 am
Yeah, I figger it's about time for a shock tear down again too.
