Cutting toe shift level off.
Bacon Andy
Re: Cutting toe shift level off.
Post by Bacon Andy » Fri Dec 23, 2016 7:48 pm
Mothra35 wrote:Image
A little fancier than I would want but you get the drift
Damn it! This won't work unless at some point you can ride no hands. lol. I'll just tweek what I have.
80ish Kawa 650 LTD gone
76 Guzzi 850T-3 needs to go, parts bike
2004 Night Train, fast
2013 GU, loaded.
WTH? I've never had an original idea!
Mothra35
Post by Mothra35 » Wed Dec 28, 2016 10:28 am
Hints the reason it's called a "Suicide" shift :wink:
--2005 Ural Tourist--"Маня"
My U-Tube
Bacon Andy
Post by Bacon Andy » Wed Dec 28, 2016 2:22 pm
With 1wd suicide is no problem but I'm in & out of 2wd regularly. I'll get more beer and contemplate.
2013 GU, loaded.
Post by INSUBORDINATOR » Sun Jan 01, 2017 2:23 pm
GOOD PLAN - there is resale to consider. I was temped to grind off the rear prong on the nasty painted steel shift pedal on my 94, but since it was pretty much out of the way I left it alone. I still use the front pad on my 02 for up & sown shifting - even though some say it is bad - Never had a problem yet.
Words to live by: "Cutting something off - is completely FINAL".
Post by sKiZo » Sun Jun 02, 2019 3:45 pm
DEAD THREAD ALERT !!
:P
Just cut mine off ... I was told there'd be cookies?
Post by BinDerSmokDat » Mon Jun 03, 2019 9:13 am
I wear size 15 Bogs when I ride off-road, using a Raceway foot box which forces my foot higher than on a stock peg and while it's a tight fit up under the carb, I can still tap the toe shifter down without issues. For upshifts I use the heel stomp method.
I see no need to modify anything.
