Maasdam - Mods
Buckhorn
Re: Maasdam - Mods
Post by Buckhorn » Fri Apr 06, 2018 8:49 pm
You can make a ground anchor point if you have a shovel. Find a solid piece of limb, or cut one if you have a saw. Dig a trench with the top angled away from your rig, to bury the limb anchor. Make a slot in the center for the rope, so it doesn't pull the limb up out of the hole. Winch away.
2013 Ural Gear Up Gobi camo
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
MizzouRider
Re: Maasdam - Mods
Post by MizzouRider » Sat Dec 22, 2018 10:24 am
I just got my puller. Was shown this thread on FB. Good info and mods. I need to test it out. Have to look at replacing the hinge pin on the lever. Would definitely save room. Does it need the extra pulley? I can see it would increase leverage by a huge amount. Just wondering if you could go without the pulley if you needed the full length of the rope?
Ural 2012 T 1wd
Also ride a 2014 BMW R1200GS Adventure
LRP
Re: Maasdam - Mods
Post by LRP » Sat Dec 22, 2018 7:21 pm
Nice work, I'll have to do something like that to mine.
LRP
Dick
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
1983 Honda Passport
19 previous motos
Glazier
Re: Maasdam - Mods
Post by Glazier » Mon Dec 24, 2018 1:16 pm
Good idea sir. Feeding a long length of rope through the unit can be a struggle. Temporarily removing that top cover helps a bunch.
siberman1 wrote:
Fri Apr 06, 2018 4:31 pm
The idea is to make the puller smaller without using tools. Hal's idea done.
Replace the center bolt with a (self-made) pin and spring pin. Removing the handle from the "body" of the puller makes the package shorter and easier to put somewhere.
Example:
2000 Patrol
2007 Tourist
1979 Hard tail Shovel Head
PhilJet09
Re: Maasdam - Mods
Post by PhilJet09 » Mon Dec 24, 2018 11:40 pm
FYI, removing the handle and stacking the two pieces together just right, it’ll fit inside a 4”x22” piece of pvc pipe. Now I just have to figure out where to mount it in the bike.
2016 Forest Fog Gear Up
2009 FJR is my primary ride
It's my first day, every day.
MizzouRider
Re: Maasdam - Mods
Post by MizzouRider » Tue Dec 25, 2018 10:43 am
Will a 22” pipe fit in the trunk? I still haven’t taken the time to look at pulling and replacing the lever hinge pin.
Ural 2012 T 1wd
Re: Maasdam - Mods
Post by rivers » Tue Dec 25, 2018 11:07 am
Depends on where you are, but the spare wheel/tire makes a good buried anchor. Common with the 4x4 crowd in the desert SE.
PhilJet09
Re: Maasdam - Mods
Post by PhilJet09 » Wed Dec 26, 2018 12:11 am
No, however the disassembled Maasdam will. I’m trying to reserve trunk space for luggage and other things I’d like to lock up.
Re: Maasdam - Mods
Post by siberman1 » Mon Dec 31, 2018 9:25 pm
Rope fits in tube. After unravel new rope, it will never be as small as it was. The 2-pc rope puller handle can fit in trunk or floor of tub.
BTW, my "Rope Tube" is fastened to the little rack on sidecar fender. The tube does not touch the tub, so no rubbing, only independent movement. A screw lid would not fit, so I used an ordinary plumbers' temporary plug for a lid. Simple, no tools required to open/close it.
My version:
Joppe650
Re: Maasdam - Mods
Post by Joppe650 » Wed Jan 16, 2019 9:15 pm
You can increase the mechanical advantage a lot more by using higher quality pulleys with bearings in them, impact is higher as you use more pulleys. Google Z strap system.
Re: Maasdam - Mods
Post by Tomcatfixer » Wed Jan 16, 2019 9:57 pm
"z strap system" produces no relevant sites, as far as I can tell.
https://www.google.com/search?q=z+strap ... VvOjVwfv_U
Re: Maasdam - Mods
Post by rivers » Wed Jan 16, 2019 10:17 pm
Chad try "Z-drag" system.
Re: Maasdam - Mods
Post by Tomcatfixer » Thu Jan 17, 2019 6:05 am
Thanks, Joe.
Why is it so hard for everyone to just post a simple hyperlink? :lol:
https://www.google.com/search?q=z-drag+ ... LrAlm1NPvE
Re: Maasdam - Mods
Post by Mr Wazzock » Thu Jan 17, 2019 1:59 pm
Reminds me on another forum recently I got "shot down" for trying to show what a hyperlink is. Apparently it was too "geeky". :?
So I said, you gotta learn something about this stuff if you want to reliably post links and photos. Image
shawnfromvermont
Re: Maasdam - Mods
Post by shawnfromvermont » Thu Jan 17, 2019 5:54 pm
Nice set up. :beerchug:
SHAWN
2009 URAL T BLACK
1997 DUCATI 900SS
1978 CB750A
1999 VMAX
