Maasdam - Mods
Maasdam - Mods
Post by GHGoodwin » Fri May 29, 2015 4:11 pm
Stuck off the road for a day or two due to minor work on knee and associated meds. I finally got around to working on a couple of rope puller mods I wanted.
First - I modded (trimmed up) a 1/2in chain clamp link for the front of the puller. I haven't welded it on yet in the photos.
Second - I made a snatch block out of the pulley. Replaced the bolt with an 8mm clevis pin. The hook axle is three pieces; two nylon bushings on a steel center tube. I green locktited them together so they stay in one piece and the hook still floats. I also had to remove the two rope keeps on the inside of the side panels. They were useless anyway.
nbsdave
Re: Maasdam - Mods
Post by nbsdave » Fri May 29, 2015 4:51 pm
it's always good to futz with the small stuff you never seem to get around to doing without having to
hope you'll be back in the saddle soon
keep your word, no excuses
Ural-it's not just another motorcycle!
2011 Ural T, now only a memory
Re: Maasdam - Mods
Post by rivers » Fri May 29, 2015 5:34 pm
Nicely done sir.
Re: Maasdam - Mods
Post by GHGoodwin » Fri May 29, 2015 7:08 pm
nbsdave wrote:it's always good to futz with the small stuff you never seem to get around to doing without having to
THNX for the concern. Took the day off due to painkiller shot.
markdam
Re: Maasdam - Mods
Post by markdam » Sat May 30, 2015 2:15 pm
playing devils advocate here.... why? how would it be used?
barn find with only 125 km
2000 Ural Patrol 650 with Dnepr airbox mod and Sean G. Steering Dampner currently at 500 km total miles
Red Dwarf
Re: Maasdam - Mods
Post by Red Dwarf » Sun May 31, 2015 2:57 pm
GHGoodwin wrote:I modded (trimmed up) a 1/2in chain clamp link for the front of the puller.
Good job.
I can't imagine why this isn't done at the factory.
I added a hook to mine at the front--good for skidding logs.
[No, I don't have pix. Hint: my snatch block is 6" dia.]
These tools are amazing--so much pull & so little battery trouble. :lol:
2012 Retro
Tin Man
Re: Maasdam - Mods
Post by Tin Man » Sun May 31, 2015 9:19 pm
I've done only one thing to my puller......bought a 150 foot coil of rope.....yup, I can reach just about anything now. I might have to give your mods a look. :foilhead:
2007 GearUp (Arctic #1)
Re: Maasdam - Mods
Post by GHGoodwin » Mon Jun 01, 2015 7:19 am
markdam wrote:playing devils advocate here.... why? how would it be used?
Conversion to snatch block just makes working with the pulley easier. You don't have to thread the line through from the end.
The chain link on the fronts only an easier way hook up the system for loading the bike on my trailer. The puller will get the bike on in a straight line 1:1 pull ratio but what I show is an easy to set up 2:1 because you don't need a separate anchoring point for the hook.
I'm also looking around for another hook/pulley to use as a deadeye so I can increase the mechanical advantage a bit more.
tonered
Re: Maasdam - Mods
Post by tonered » Fri Jun 05, 2015 5:28 pm
Thanks! This thread has turned me on the Maasdam. I like the prices considering the alternatives.
Have a good one.
tony b
Lynnwood, WA
2013 GearUp (Taildragger)
2001 Duc ST4 (Thumper)
vetsurginc
Re: Maasdam - Mods
Post by vetsurginc » Tue Jun 09, 2015 1:46 pm
What do you use as an anchor after getting hooked to the bike, assuming there are no trees or GoldWings within reach? On one of the TopGear shows the Orangutan was off-roading in a scottish bog. After sticking the LandRover, his recovery team looked like they were using small plow anchors (as in boat) to anchor their winch. One more thing to add to the sidecar :?:
Doug
2010 R1200RT Gustav
tonered
Re: Maasdam - Mods
Post by tonered » Tue Jun 09, 2015 2:00 pm
It's called a ground anchor. But, some folks do just carry a boat anchor. They are rather inexpensive.
Have a good one.
tony b
Lynnwood, WA
Re: Maasdam - Mods
Post by VWK75S » Wed Jun 17, 2015 4:53 am
Still not sure I understand why this is better other than using more rope? :?
2009 GearUp 145,000kms
Re: Maasdam - Mods
Post by siberman1 » Wed Jun 17, 2015 9:34 am
tonered wrote:It's called a ground anchor. But, some folks do just carry a boat anchor. They are rather inexpensive.
Have a good one.
Yeah, cheap. I saw one yesterday at 2nd-hand thrift store. It was about 18"-20" across and long double pointy things. It is a pretty heavy thing and comes with about 8' of heavy rope with a metal eye thing braided in it - only $10 for the whole thing. I didn't buy it, maybe some other day...
tonered
Re: Maasdam - Mods
Post by tonered » Wed Jun 17, 2015 10:08 am
That's a great deal.
There are a lot of trees around here, so just the puller should work for me.
Have a good one.
tony b
Lynnwood, WA
Re: Maasdam - Mods
Post by siberman1 » Fri Apr 06, 2018 4:31 pm
The idea is to make the puller smaller without using tools. Hal's idea done.
Replace the center bolt with a (self-made) pin and spring pin. Removing the handle from the "body" of the puller makes the package shorter and easier to put somewhere.
Example:
