Rear view mirrors suggestions
- Comrade Colonel
Hello Folks, I would like to replace the stock mirrors on my 12 Gear Up. The oem mirrors just dont stay put, where you adjust them,and the view is not that great, as they tend to vibrate some.. Looking for replacement suggestions,
What are you guys found that works well?
Thanks
Rick.
Thanks
Rick.
2012 Ural Gear Up / Forest Frog color. 2008 Goldwing Champion Trike, 73 Guzzi Eldorado, 17 Guzzi Griso
- TomsFunMachine
- Hero of the Soviet Union - 2021
Re: Rear view mirrors suggestions
I'm needing the same thing... I've tried two other inexpensive mirrors, both disappointing, what say the rest of the group?
2002 Ural Tourist w/7.4 gal Dnepr tank
1965 BMW R69S Willis (long-term project bike)
2000 KLR 650
2018 Ninja 400 (Wife's rocket)
2000 KLR 650
- Tomcatfixer
- Commissar
I've seen several Ural owners post positive reviews of the Doubletake folding mirrors. They're particularly popular among the off-roading crowd.
Hinkley Triumph twin mirrors are quite solid and good quality, also cheap if bought used on Ebay or wherever.
Vibration proof on an older Triumph 650 twin so no worries on a Ural
Stems are 1/2" solid bar and threaded accordingly so mounting may require some ingenuity.
2022 GU [RHD]
- Order of Victory
I have Double-Takes on my 450. They are superior and do take a beating. Pricy too but if yours suck then...
- Comrade Colonel
I like those double take mirrors. I had seen them on "Itchy Boot's" new Honda , and liked them, didnt know what brand they were.
Thanks for the info.
Rick.
Rick.
- Tomcatfixer
- Commissar
- Order of Victory
You know the Double-Takes are actually just the mirror part. Everything else that you get in their full kit is Ram Mount and probably the more expensive parts. But if you already have the Ram parts then you can just order the mirror. I was moving from bike to bike, the 2 wheelers. Do they still offer replacement if you break one?
On my Patrol I still have Emgo lollypops which are high and fine. Remove the left side in the woods.
It take an annoying time to set them up because you want them tight enough that they don't vibrate but loose enough so that they "break-away" on impact. Excellent for the off-road stuff. Might be overkill if only street/pavement.
- Comrade Colonel
Thank you, Stagewex. thats helpful, I do have some old ram mount stuff, from an old st 1300, I will have to dig up, to save a little $$.
Rick
Rick
Could you share the size of the ram mounts for our urals? I have a 2020 ir model year mKes a difference. And do either of the sides require left hand threads? I had the double takes on a 15 Tenere that I really liked and am considering ordering but unsure which threaded mounts to order.
History
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
- Tomcatfixer
- Commissar
Your 2020 does not, but older Urals do.And do either of the sides require left hand threads?
Sort of....
From 2005-2013 (mid-year), Urals came with the "oval"-shaped mirrors shown at the bottom of the photo. From mid-year 2013 on, Ural switched to the round mirrors shown above them.
The not-exactly-oval mirrors feature reverse threads on BOTH mirror stalks, but they came with the adapters shown to convert the stalks to a standard M10x1.25 mirror mount.
The round mirrors come with a standard M10x1.25 "slip-fit" base, which allows you to simply loosen the top but of the base, swivel the mirror stalk to your preferred position, then tighten it back down. On the older mirrors, post-adjustment tensioning was facilitated by "double-nutting"
I can show you 650 Ural mirrors, too, which are a different animal entirely, but they suck, so let's never speak of them again.
OK, thanks!Tomcatfixer wrote: ↑Thu Jan 20, 2022 4:15 pmYour 2020 does not, but older Urals do.And do either of the sides require left hand threads?
Sort of....
History
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
1980 Suzuki 800
1996 Honda 750
2004 Kawasaki
2000 K 1200 BMW
2013 F 700 BMW
2015 Yamaha Tenere
2018 R Nine T BMW
1994 R 1100RS BMW
2020 750 Ural GU.
- Comrade Colonel
Thank you Tomcatfixer, for the info and pics. very helpful.
Rick.
Rick.
- Tomcatfixer
- Commissar
You kidding, Rick? I LOVE helping out by posting the detail pics!
