Zerk Fittings for Splined Drive Shafts
Scott C
Post by Scott C » Sun Mar 22, 2015 4:37 pm
Over the winter I overhauled the final drive on my 2011 Patrol. (Thank you Billy G.) It was an obvious opportunity to add Zerk fittings for greasing the splines on my drive shafts. Pumping grease into a Zerk fitting is much easier than taking off the final drive.
Put the holes for the Zerks as far into the splined shaft receiver as possible so the new grease pumped in pushes the old grease out. For the drive shaft from the transmission to the final drive, position the hole so it goes through the thick part of the spline. It will provide more threads for holding the Zerk and if centered correctly, the end of the Zerk fitting won't have to be filed down to clear the splines. It's not an issue on the sidecar drive shaft. The splined area ends well before the place the fitting is installed.
A drop of thread locker helps keep the fitting in place. Use a flush fitting on the transmission to final drive shaft.
This is a good place to express appreciation to Gobium for his videos on adding a grease fitting to the drive shaft from the transmission to the final drive. He had the integrity to shoot a second video about clearance issues someone else ran into when installing a fitting. It's easy to show off a success. It takes some guts to point out problems that might be encountered. Thanks Van.
That takes care of the drive shaft from the transmission to the final drive. There is a slight detail that needs to be taken care of on the sidecar drive shaft.
The sidecar driveshaft is hollow and needs to be plugged. Not only plugged but plugged well enough to withstand the 2000 - 6000 psi of pressure a hand operated grease gun can create.
I decided to plug the driveshaft with flowable silicone, specifically Permatex 81730 Flowable Silicone Windshield and Glass Sealer. Silicone sealer has a very wide operating temperature and remains flexible to absorb the pressure pulses from a splined shaft moving in and out as the Ural suspension makes a modest attempt to smooth out bumps in the road.
A 3/4" plastic plug was coated with RTV, guided with a 5/16" wooden dowel and pushed into place with a deep well socket on an extension. The plug was held in place while the RTV cured overnight.
It took three 1.5 ounce tubes of flowable silicone to fill the driveshaft. Be patient and don't try to fill the shaft too quickly. Air needs to come out as silicone sealant flows into the shaft. Let the silicone cure overnight. It might be easier to plug the shaft on the sidecar side and fill from the splined side. Try it and let us know.
No more final drive removal to grease the splined shafts, just a rag, a grease gun and a few minutes.
Scott C
1977 BMW R75/7 (since new)
2011 Ural Patrol   (since new)
Bad monkey! Give me those matches!
Poacher Bob
Re: Zerk Fittings for Splined Drive Shafts
Post by Poacher Bob » Sun Mar 22, 2015 5:10 pm
:clap:
:bow:
1996 FLHPI/TLE
1999 KLR 650
2003 KDX 200
2002 FLHTCI
2006 Patrol
2005 KTM 950 ADV
Post by gobium » Sun Mar 22, 2015 5:26 pm
:clap: :cheers:
silverdog
Post by silverdog » Sun Mar 22, 2015 8:29 pm
Good work.
2012 gobi
AZer
Post by AZer » Tue Apr 26, 2016 12:33 am
Very nice. After 1+ year and I'm assuming at least one use of the zerk fittings, any feed back about this mod?
Thanks
:o
2015 Gear-Up
2013 KLR
2011 Concours
1971 CL350
keetmanaa
Post by keetmanaa » Tue Apr 26, 2016 9:44 am
I'm also interested
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
markhas
Post by markhas » Tue Apr 26, 2016 5:55 pm
This is not new. I did this mod several years ago following a post here on SS.
markhas
AMA member
ABATE Wisconsin
06' Tourist 41167/over 75,000Km, 91" 750 Honda Nighthawk sold to my buddy Ernie, we keep in touch.
AZer
Post by AZer » Tue Apr 26, 2016 8:53 pm
I knew that it was not new, that's why I asked how it has worked out for you.:-)
I think it was Scott C that posted his accomplishing this mod that I responded to if that matters....
Thx
:o
2015 Gear-Up
2013 KLR
2011 Concours
1971 CL350
Scott C
Post by Scott C » Tue Apr 26, 2016 10:52 pm
The zerk fittings are working fine. They get a couple of shots of grease with every oil change.
Scott C
AZer
Post by AZer » Tue Apr 26, 2016 11:07 pm
Thanks Scott! The pics you posted show that you did a nice job with that mod!
:o
2015 Gear-Up
2013 KLR
2011 Concours
1971 CL350
Post by Wildhorse Cafe » Wed Apr 07, 2021 11:37 pm
