Sidecar leveling system
54vintage
Post by 54vintage » Sun Apr 14, 2019 9:31 pm
Toying around with a leveling system.....still in the design stage, but closing in on it.
Chuck Loftin
2002 BMW GSA with 2005 Ural tub
2014 Sage Green GU....off to a new home
1974 R90S----gone
2009 G650GS---outtahere
Re: Sidecar leveling system
Post by Tomcatfixer » Mon Apr 15, 2019 5:10 am
Interesting. I've seen aftermarket hacks with this feature, but I gotta ask: why on a Ural?
54vintage
Post by 54vintage » Mon Apr 15, 2019 10:01 am
Hi Chad
It's a Ural frame alright , but will be hung on that GS you see in the background in the vid.....Not that I wouldn't do this to my Ural if I was keeping it, I've seen theses mods in action and they do come in handy sometimes.
Chuck Loftin
1974 R90S----gone
Post by Tomcatfixer » Mon Apr 15, 2019 10:06 am
Is this to increase ride height for off-road situations and lower it for pavement stability?
54vintage
Post by 54vintage » Mon Apr 15, 2019 10:15 am
That's one thing one could do with this feature. I was looking at keeping the rig level as possible when riding back roads that have a bit of an angle to them.....and to compensate for heavy loads.
Chuck Loftin
1974 R90S----gone
Post by Tomcatfixer » Mon Apr 15, 2019 10:32 am
I see. Will the juice be worth the squeeze?
Seems to me like only a stiffer rate spring on the shock could properly do that, but I might be off-base.
54vintage
Post by 54vintage » Mon Apr 15, 2019 10:49 am
I've done some roads where I sure wish I could have raised or lowered the tub a bit to feel a bit more "comfortable" riding them....mostly when the tub seems to be higher than you are :wink: As to the stiffer spring rate shock.....one is not always toting a heavy load.
Chuck Loftin
1974 R90S----gone
mattzahr
Post by mattzahr » Mon Apr 15, 2019 11:27 am
Chuck, just curious, would it be possible to make a 2WD version of this?
Also, do you make any mods to bolster the axle for the change in angle(s)?
Looks great - thank you for sharing!
Matt
'16 cT - Terracotta aka Orange
SMSgt./1st Sgt., (Ret.)
Proud member of the "Group W Bench"
54vintage
Post by 54vintage » Mon Apr 15, 2019 2:28 pm
Matt
Matt.....you would have to do some frame mods to make a 2wd version......the frame would be in the way when you tried to raise the sidecar up higher.....the drive shaft would hit the frame.....you might be able to lower the rig....looking at my GU, the driveshaft might fit up in the well that runs cross ways in the tub. I didn't have to do anything to the axle.....but to be clear, are you talking axle or drive shaft? I can take some close up still shots if you like.
Chuck
Chuck Loftin
1974 R90S----gone
mattzahr
Post by mattzahr » Mon Apr 15, 2019 2:33 pm
Chuck...the shaft...thanks
54vintage
Post by 54vintage » Mon Apr 15, 2019 3:25 pm
Matt, on the rig I'm working on there will be no two wheel drive, so no drive shaft.....but I'm sure with some design work one could make this system work with a 2wd rig. Is this something you would like to do to your rig?
Chuck Loftin
1974 R90S----gone
mattzahr
Post by mattzahr » Mon Apr 15, 2019 4:40 pm
Currently own a cT, not sure if my bike would be a good platform to start from. A used GU in my opinion may be what I would want to try it on....not sure at this time....
54vintage
Post by 54vintage » Mon Apr 15, 2019 4:51 pm
Right you are.....but it's making me think about doing a bit of design work to see if one could pull it off without too much trouble. I'm thinking the splines in the drive shaft might have to be extended a bit to make it happen. I guess it depends on how far you raise and lower the sidecar wheel.
Chuck Loftin
1974 R90S----gone
Post by Lmo » Wed Apr 17, 2019 2:43 am
Nice. DMC offers a similar set up on their rigs.
Post by stagewex » Wed Apr 17, 2019 8:37 am
Wow, amazing.
1969 BMW r60/2 US model (Kick Start only)
