iKon Suspension for Urals
Re: iKon Suspension for Urals
Post by gobium » Wed Sep 20, 2017 11:40 am
Lmo wrote:Just to add some reference material to this discussion; this old thread dealt with actual weight (empty) distribution measured by load cell.
http://www.sovietsteeds.com/forums/view ... hp?t=45839
The result, provided by Brother Glenn (Speedbump) is shown below
LF = 266 #
LR = 337#
RR (sidecar) = 188#
Perhaps a brief explanation of spring rate vs. load rate would be helpful (to me anyway).
Am I correct in my understanding that 75/120 (below) represents zero deflection at 75# load, and 1" deflection at 120# load?
Ural used progressive on their solo NOT for sidecar rig
Post by gobium » Wed Sep 20, 2017 11:48 am
IkonUSA wrote:Brievietsthir list members,
Roger from iKon Suspension USA reaching out to forum members for some information on OEM shocks.
We're starting to get more and more inquiries and orders for suspension to fit Urals but I have a few questions with regard to any suspension dimension changes which may have taken place over the years.
Presently, we offer our 7610 series shock absorber part# 7610-1664 which measures (from center of top eye to center of lower mount clevis) 325mm or 12.8" with an inside lower clevis width of 25mm and a 10mm hole for the fixing bolt. We list this as being suitable for all Ural models from 2008 to the present and is suitable for front, rear and sidecar suspension.
My question to forum members is with regards to earlier Urals. What is different (if anything) about the shock absorbers used on Urals prior to 2008?
'Appreciate your input.
Roger
iKon Suspension USA
Bedford, PA
1wd swing arm (sidecar) nut clearance for shock
Post by gobium » Fri Sep 22, 2017 9:52 am
Old 650/750 vs new 2013
tx2sturgis
Post by tx2sturgis » Fri Sep 22, 2017 11:43 am
Sorry I'm late returning to the party!
You got an answer but let me cut to the chase on dual spring rates (you can tell its a dual-rate because the coils are not evenly spaced all the way from top to bottom, or sometimes the spring wire itself is tapered).
The first number, 75, is the rate of deflection, pounds needed to compress one spring, one inch, in the first inch of travel.
The second number, 120, is the pounds needed to compress one spring, one inch of deflection, in the LAST inch of travel.
A single rate spring would only have one number, such as 100. Meaning, 100 pounds needed to compress the spring one inch, all the way thru its travel.
And yes, this is a Solo sT. I only posted because the original question asked about ALL Urals of certain years, and it needs to be posted on the product website that the Ural Solo is a bit different. And, it only uses two shocks!
Nuff said. Back to lurking.
Great offer by iKon BTW! :thumbsup:
---Brian
Republic of Texas
2013 Ural Solo sT
Jim_Z
Post by Jim_Z » Sat Oct 07, 2017 11:40 pm
I spent some time talking to the folks at the IKON booth at the Barber Motorsports Vintage Days the week
They are very jazzed about working with folks on Sover Steeds on the project to develop a set of shocks for the Ural sidecar rigs. Think I will start setting some funds aside for a set. Good job Van and others working on this for the be night of the SS Collective.
Jim_Z
2005 Ural Tourist Project
GillaFunk
Post by GillaFunk » Sun Oct 08, 2017 2:01 am
I'll order of a set of these next month for a future Ural purchase I plan on making in the near future.
Sgt. USMC 0311, 8156
2011 Gear-Up "سميرة" (Samira). Gone, it not forgotten
Tin Man
Post by Tin Man » Sun Oct 08, 2017 9:22 am
Looks like Santa might be a bit busier this season..... :foilhead:
2007 GearUp (Arctic #1)
130/45 jets, KTM rock solid mirrors, Delaware Dave's outstanding trunk lock, Mr. Cob's most excellent skid plate, Cycra Probend smashproof hand guards, Duro strong like bull 307's, RotoPax damn near bulletproof fuel cans, MKIII all but water proof air box and Dimples super duper magnetic drain plugs all around...oh yeah, and a manual fuel petcock.
.........if you see something that needs doing, just do it........
GillaFunk
Post by GillaFunk » Mon Dec 04, 2017 3:28 am
Whatever happened to this?
Did anyone upgrade?
Post by Tomcatfixer » Mon Dec 04, 2017 5:42 am
Did anyone upgrade?
There are things... in the works.
Virginia Beach, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 1999 Ural Tourist "Desert DisGrace: the Iron (Oxide) Curtain", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
BlueRockCrawler
Post by BlueRockCrawler » Tue Dec 05, 2017 8:25 pm
Did anyone upgrade?
For the cT or the rpoc?
2015 Ural Patrol
1996 Magna Deluxe
previous Honda's were
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Post by Tomcatfixer » Tue Dec 05, 2017 8:29 pm
cT
Tin Man
Post by Tin Man » Wed Dec 06, 2017 6:41 pm
:lurker:
Post by Lmo » Thu Dec 07, 2017 12:55 pm
Snakeoil - I PM'd you... do you copy?
IkonUSA
Post by IkonUSA » Thu Dec 07, 2017 2:18 pm
The Ikon Suspension USA project to design (with assistance from Snakeoil, TomCatFixer and Gobium) Ikon units specifically for the Ural is going well. Pre-production suspension units are already in the field with Snakeoil. he's submitted truly outstanding reports which been above and beyond. These comments and observations have been fed back to the Ikon factory in Australia and design/manufacturing 'tweaks' have already been implemented as a result.
Refining a product to suit a particular application is so much more than just selecting the correct length of a suspension unit; we're trying different spring rates to see how the Urals react and will also (based upon feedback from the unpaid focus group) adjust internal damping (valving) rates.
As winter begins to bite on the eastern seaboard, road testing will understandably slow somewhat over the next few weeks, however I'll post updates to the forum as more development occurs.
Post by Tomcatfixer » Thu Dec 07, 2017 2:44 pm
Uh, not on account of me. 8)
