I Bought An RPOC Today
dneprlover
Re: I Bought An RPOC Today
Post by dneprlover » Sun Dec 10, 2017 5:35 am
Lmo wrote:Lookin' good Chad! Whadda you do in your free time?!?
Now you need to do this mod. Makes adjusting the shoes much easier, not mention eliminates any deflection from the wimpy OEM link.
Be very careful about the use of that link. It is ONLY used to set the operating arms parallel to each other. Any attempt to use it to adjust brake shoe contact with the drum will result in severely impaired braking capability. Cut yourself a sheet aluminium angle template for setting the arm angle ( as per the book) and set the arms to that. On a Ural, shoe adjustment is only set using the screws on the end of each shoe.
To refer to it as making shoe adjustment a lot easier, is extremely misleading.
Post by Tomcatfixer » Sun Dec 10, 2017 6:08 am
Be very careful about the use of that link. ... To refer to it as making shoe adjustment a lot easier, is extremely misleading.
Guess I've got some reading to do. Thanks for the tip!
Virginia Beach, Virginia, USA
Post by Tomcatfixer » Sun Dec 10, 2017 6:09 am
Post by Lmo » Sun Dec 10, 2017 1:17 pm
You are, of course, correct Mr. 'lover. I should have said, "brake actuator link length" easier to adjust. I adjusted the shoes for clearance, and then adjusted the clevis to take up the slop between the clevis ends and the brake cam arms. Having a true "turnbuckle" ( right & left hand threads) is superior to the stock link, simply because you don't have to take one end of the link loose and trial-and-error it for fit.
It also deflects less than the stock link. The installation of the heavier 2.5mm Barnett brake cable, and its corresponding stiffer outer housing also helped, alot.
Post by Tomcatfixer » Tue Dec 19, 2017 3:21 pm
More little "nibbles" at progress:
Besides critical decisions, like which way to orient the slicer...
...I performed a little experiment to see if there is a way to chemically strip (or at least etch) chrome at home with muriatic acid.
Conclusion: while the acid cleaned the heck out of any exposed rusty steel, it didn't etch the chrome, as I hoped. It seems my original method of 40-grit sandpaper was the most effective, if labor-intensive, paint prep technique for chrome surfaces.
I'm also dabbling in alternative seat suspension (A.S.S.), based upon input from forum members.
Help me get the most out of my A.S.S. :lol:
As always, your ideas, thoughts, opinions, and smartassed remarks are always welcome. :D
Post by VWNate1 » Tue Dec 19, 2017 3:37 pm
I just use two silentblocs, @ 230 + # it works O.K. so far .
I like the dual coil springs and silentbloc idea .
Post by Speedbump » Tue Dec 19, 2017 5:05 pm
Sounds like you are trying to Bolster Uniform Tush Tranquillity. :D
Glen³
Yeah, I got something on the side.
1977 GS550
1979 XS750
Post by Tomcatfixer » Tue Dec 19, 2017 5:45 pm
My man! :lol:
Mrs. Tomcatfixer solved the Great Slicer Dilemma of 2017:
Post by Lmo » Tue Dec 19, 2017 8:01 pm
On my list of to-do, air springs for the Dnepr seat. I've got an old HD Police saddle, but it's a monster, don't know if I'll use it or not.
$175 for a kit from Revzilla, or buy the "spring" from an industrial supplier for <$30, and fabricate your own mounting hardware.
Goodyear Model: 1S5-174, or any of this series.
http://www.sdtrucksprings.com/index.php ... s_id=16214
Chinese equivalent, with load information > http://www.suspensionairspring.com/sale ... cycle.html
Post by Mr Wazzock » Tue Dec 19, 2017 8:25 pm
Tomcatfixer wrote: I'm also dabbling in alternative seat suspension (A.S.S.), based upon input from forum members.
What’s wrong with just two springs?
Post by Tomcatfixer » Tue Dec 19, 2017 8:41 pm
They're insufficient for my 225 pounds + riding gear.
Dammit, Lew. Why did you have to show me that? Now I'm gonna have to explore that option, too! :P
(It's a very interesting concept)
Me too. I've come to the conclusion that, aesthetically, the H-D police saddle only looks good on the Retro and it is incompatible with the rear tractor saddle (just gobbles up too much real estate).
Post by Mr Wazzock » Wed Dec 20, 2017 12:38 pm
As much as that! Image
And I fort you wuz a svelte thing
Post by Tomcatfixer » Wed Dec 20, 2017 1:24 pm
Ha! Camera tricks.
Post by Tomcatfixer » Fri Dec 22, 2017 6:24 pm
Today? Just more of my standard substandard painting.
Bendog02760
Post by Bendog02760 » Fri Dec 22, 2017 6:49 pm
Looking great Tomcat, like your attention to detail! Any day I have an open spray container is usually a good day!!!
:cheers:
2012 GU (I bought in May 2017) All my GU rides are with my dog, Liberty
HD Road King
HD Wide Glide
Owned about 15 other HD over years
Boston Mass.
