RPM in third gear at steady 50mph
redtails
Post by redtails » Sat Mar 21, 2015 5:38 pm
I've been finding myself waiting to shift into fourth and, at times, leaving the bike in third at a steady 50.
Just curious, to anyone who has had a tach, what is the RPM in third at 50mph? I'm riding a 2014 if it matters.
Thanks! :thumbsup:
- Jon
2014 Patrol Red/White "Uranus"
LRP
Re: RPM in third gear at steady 50mph
Post by LRP » Sat Mar 21, 2015 5:51 pm
Approx 4600 RPM
LRP :moto:
Dick
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
1983 Honda Passport
19 previous motos
Leftka
Post by Leftka » Sat Mar 21, 2015 6:37 pm
I think you are fine at 50 in third...these engines much prefer to rev freely than lug
Leftka
Naples, FL
128/40 Jets
Harmonized at 10" hg
K & N MG 200 Filter Element
7/64" Drilled Carb Slides
Parabellum Scout Fairing
Retro Lighting
MikeVA76
Post by MikeVA76 » Sat Mar 21, 2015 6:49 pm
I usually shift to fourth just past fifty. Mainly because I know I'm going to lose 5-10 mph during the shift, lol.
Michael Barone
2014 Sage Green Gear-Up
Haymarket, VA (DC Metro area)
biker
Post by biker » Sun Mar 22, 2015 1:57 am
Unless your going up and down fairly steep hills or against a strong headwind you should be in fourth running at a steady 50 MPH. Yes these engines may prefer higher revs as opposed to being lugged but there is a happy medium. You have to go by the sound of the engine. Running at high revs all the time is not necessary and not good for it. :shock:
Allan aka Biker
2008 Ural Patrol white
2008 Ural Patrol black
1994 Suzuki GN125E
2 Harleys 2002-2003
thumper05flstsc
Post by thumper05flstsc » Sun Mar 22, 2015 5:39 am
I have no idea what the RPM is at 50 in 3rd gear but the few times I have run mine that high it just seemed like it was wound way to tight to me. That is probably from so many years of riding bikes like Harley and Guzzi that have relatively low revving engines I guess.
"Treat me good, I'll treat you better. Treat me bad, I'll treat you worse" (SB)
Thermos
Post by Thermos » Sun Mar 22, 2015 8:27 am
If the terrain is flat, I'm in 4th at 40 with no lugging. If there is an incline, maybe 45, really steep 50. The engine is really turning fast at 50.
-T
Yogi Berra
2011 Orange/Silver Patrol
2017 CRF1000 Africa Twin
1977 R100S
former bikes-
2001 HD Sportster
1981 Honda CX500 Custom
Roadking
Post by Roadking » Sun Mar 22, 2015 9:00 am
I go by sound too. At 50MPH I shift into 4th if I want to increase speed. Otherwise I can comfortably cruise at 45-50 in 3rd all day long and she's purring like a kitten.
2001 HD Roadking FLHRI
lendrinkard
Post by lendrinkard » Sun Mar 22, 2015 9:10 am
45 to fourth, on flat and not increasing speed. Or something like that. :)
Post by Peter Pan » Sun Mar 22, 2015 9:29 am
Mickey Sherfield in Alaska recomended me to go way up to 54mph for to shift into 4th...since then i had less trouble...
The sweet spot for a semi run in engine is 4500 to 5000 revs.
first 20 to 23 mph
second 32 to 37 mph
third 48 to 55 mph
fourth I i just use as overdrive or downhill.
When the engine wasn't run in free the bike used to dictate the speed and you better obeyed those speeds.
When trucks, buses or Sunday drivers block the road, better let them go and rest for a coffee out of the thermos bottle.
For up hill and strong front wind use those mentioned speeds and you will observe too a happy engine.
I even race now against local car drivers just for to be able to have wind over the engine....the oil temp stays low then even on the hardest long slopes.
Sophie got a free engine after 18.000km, so be patient with a new engine, there is no need to force it...not for nothing I prefer the German term "drive in" over the US term "break in".
Chuck (Loftin?) bought in Salem OR his rig the same week as I did, after a year he had a bent and seized crank shaft just because of going at too low revs...do not ask for force/torque below 4000 revs!
If you do not have a rev meter and are in doubt if you are at too low revs, then just test with a blimp on the throttle if the bike is responding well, then you are fine. if there is a dull sound or no feelable acceleration, you better go down a shift.
These engines NEED to rev. Only in the first 5000km you better go only on flat area.
Sven
Post by rivers » Sun Mar 22, 2015 1:42 pm
You'll learn your motor in time by sound and feel. Once you got that figured out keep the motor in it's happy spot. That's what the stir stick is for.
54vintage
Post by 54vintage » Sun Mar 22, 2015 3:08 pm
I find that my 2014 likes fourth only after indicated 50 on the speedo (what ever speed that really is, who knows) but going into fourth any lower and it's working a bit harder to get to fifty and above. That being said, I will shift at a lower speed.....45.....if I'm not trying to get up to highway speeds to blend into traffic.
Chuck Loftin
2002 1150 GSA with 2005 Ural tub
1985 K100RT
2014 Sage Green GU....off to a new home
1974 R90S----gone
2009 G650GS---outtahere
Post by GHGoodwin » Mon Mar 23, 2015 6:50 am
Roadking wrote:I go by sound too. At 50MPH I shift into 4th if I want to increase speed. Otherwise I can comfortably cruise at 45-50 in 3rd all day long and she's purring like a kitten.
Same here. On my '12 50 in 4th is a little sluggish on the uptake but OK for flat roads. On the '14 it doesn't seem to matter that much.
MartyL
Benevolent Emperor
Benevolent Emperor
Post by MartyL » Mon Mar 23, 2015 8:09 am
Since we're having this conversation, how about smooth downshifting when you aren't forced to due to traffic. For me 4th. To 3rd. At 40. 3rd. To 2nd at 20. And 2nd. To 1st. At 5. These downshifts for me will let the tranny, "snick" into gear smoothly. When up shifting, 1st, 2nd. And 3rd., I wait a couple of seconds after I pull in the clutch and I get a smooth shift. My up shifts are, 1st. To 2nd. At 15, 2nd. To 3rd. At 35, 3rd. To 4th at 50. 50 is a toss up range for me for either 3rd. Or 4th depending on conditions. My engine doesn't like 4th. Below 45.
1976 Yamaha XS650C
2018 H-D FLHXS
redtails
Post by redtails » Mon Mar 23, 2015 11:11 am
LRP wrote:Approx 4600 RPM
Thanks, that answers my question. The 2014 motor HP/torque peak "claim" by Ural is 5500 max HP and 4300 for max torque, so 4600 would be a relative "sweet" spot.
My local riding is not flat and the motor is happier pulling hills in third. Given a flat and more open road, then yeah, I'd shift at just over 50mph to fourth. While the motor doesn't sound too wound up, it is getting up there. Just needed an idea of what the RPMs were at that speed/gear.
- Jon
