Noobie 2016 cT oil questions.
JNRIII
Re: Noobie 2016 cT oil questions.
Postby JNRIII » Sat May 27, 2017 10:45 pm
Why did the member suggest 85-140 in the trans , not the 20-50 ????
JNRIII
Postby JNRIII » Sat May 27, 2017 10:47 pm
Why did the member suggest 85-140 in the differential, not 85-90 and why gear in the trans , not the 20-50 ???? Please , what is the rationale ??? JNRIII
JNRIII
Re: Noobie 2016 cT oil questions. TransMission dipstick
Postby JNRIII » Sat May 27, 2017 10:52 pm
My 2014 T doesn't have a dipstick in the trans, just a plug with a magnet. Was that maybe wrong from the factory ? Other members have mentioned a dipstick in the trans . Should I buy one from parts ???? Thanx JNRIII
Postby chaos2 » Sat May 27, 2017 11:02 pm
Magnetic plug on the transmission fill is normal, fill to bottom of threads. The magnet on the fill usually picks up more swarf than the one on the drain plug. I'd just stick to the factory recommendations for oil in the engine, trans and rear until you get a good feel for what you want change.
Raceway needles
Modtop exhaust
JNRIII
Postby JNRIII » Fri Sep 29, 2017 9:11 pm
Mr Wazzock stated » Tue May 23, 2017 7:33 pm
Engine: 20W-50, or 20W-60, fully synth.
Gearbox: 75W-90, fully synth. Thicker makes cog swapping a bit smoother.
Final drive: 85W-140 gear & rear axle oil. Again thicker discourages it leaking out past the input shaft seal*. For the same reason, only fill to 20cc less** than what the book says (capacities are different depending whether 1wd or 2wd). E.g. 1wd, 90cc; 2wd, 110cc (I think).
I wanted to know, why gear oil 75w90 in the trans? I think the manual says 20w50
Also, why 85-140 in the rear end ? Again I think the manual says 75-90 .
Can you explain your experience and reasons for a newbie ?????
Postby gobium » Sat Sep 30, 2017 8:22 am
The tricks on Ural are!
Use the very cheap wal-mart or wallyworld oils But change oil often, often!
Take it from a guy that owned a few ural
Unlike Darell he used very expensive oil. :lol: in Babe
Good luck, ride safe.
Good bye all
made some great friends here
Postby gobium » Sat Sep 30, 2017 8:25 am
Ural is not race bike
Use lawnmover oil
Good bye all
Return to “Oil Threads”
