when is it time for syn?
Postby hotflash44 » Wed May 10, 2017 7:45 am
Hi,guys thinking on switching to redline synthetic, but the bike only has 1800km its a 2016 gu. I don't want to switch until its fully run in. At what mileage is it safe to make the conversion?
drive a 2016 gear up asphalt grey .Air America CIA circa 1967/8 Vung Tau Viet Nam USS Tutuila ARG-4 (AND JUST A TOUCH OF AGENT ORANGE!)
Lee Pape
Re: when is it time for syn?
Postby Lee Pape » Wed May 10, 2017 8:46 am
NEVER!!! IMO.
But, together we have it all.
Postby stagewex » Wed May 10, 2017 8:53 am
I don't use synthetics in any of my bikes but they are all a bit old/long-in-the-tooth. Personally I'm surprised the new one's don't already come with syn in them like pretty much all new cars and bikes.
Not sure if it matters when you change over? For older motors there was and is always the belief that once you go syn you can't go back. I don't know if that is true or not?
Castrol has a High Milage blend of syn & dino that I started using on a BMW r1100rt years ago after it broke 60,000 miles. My only foray into syn. with a bike.
Our cars a 2013 Jeep and 2017 Lincoln both came from the factory with syn so that's what they get at oil changes. I really don't see any difference but obviously the more modern engines must do. Your Urals engine design ain't exactly anymore "modern" than my 2007 or older models even with the EFI slapped on it. Personal preference.
2007 Ural Patrol, 2006 Yamaha TW200, 1995 BMW K75, 1969 BMW r60/2US
Postby hotflash44 » Wed May 10, 2017 9:35 am
Thanks, as i under stand the vehicle world, other than Ural uses syn oil, but the tolerances and machining are modern. I think of the Ural as i would a 1960 ford. they all needed the careful 500 mile break in to do the final machining that the factory didn't. your right i hear that Ural may start sending the bikes here with syn oil? I don't want to introduce syn oil to soon, if the 2016 engine isn't broken in, as some say the break in process will stop when syn is added.
Postby chaos2 » Wed May 10, 2017 9:47 am
If you must, probably wait until most of the fuzz stops collecting on the magnetic drain plug. That should be a sign the engine is pretty well broken in. I run syn in the winter because it flow easier in freezing weather, makes starting less of a chore. But in the summer I go back to good old cheap Castrol 20/50.
Raceway needles
Modtop exhaust
Lee Pape
Postby Lee Pape » Wed May 10, 2017 9:52 am
hotflash44 wrote:Thanks, as i under stand the vehicle world, other than Ural uses syn oil, but the tolerances and machining are modern. I think of the Ural as i would a 1960 ford. they all needed the careful 500 mile break in to do the final machining that the factory didn't. your right i hear that Ural may start sending the bikes here with syn oil? I don't want to introduce syn oil to soon, if the 2016 engine isn't broken in, as some say the break in process will stop when syn is added.
A Ural engine finally gets broken some where around 10,000 kilometers. Many of us that have owned Ural that long will tell you that someplace around 10,000 kilometer their bike seemed to get into it's happy zone. On my current bike it was closer to 15,000 kilometers. One day you get on to go for a ride and it is WOW is this the same bike I parked yesterday? I don't know for sure what happens or why but it sure is a joy when it does happen.
Postby hotflash44 » Wed May 10, 2017 10:00 am
thanks its like getting two bikes in one. a rebirth at 15 thousand K. who would have thought.
Postby rivers » Sun May 21, 2017 3:09 pm
Unless it's specifically designed as a syn 'break-in" oil. Conventional syn is pretty slippery due to the additives(detergents?) I suspect break-in designed syn has less detergents? On initial break-in you want some scuffing to occur to seat the rings properly. On a new motor of any brand I wouldn't switch from dyno to syn motor oil till I had at least 2000km on the motor. On my 06 R1200GS, BMW recommended not switching to syn till 6000km.
darrynl
Postby darrynl » Tue Aug 22, 2017 5:56 am
Using regular oil is good enough. Just don't forget to follow the recommended oil change interval.
Postby stagewex » Tue Aug 22, 2017 8:31 am
Never or whenever you feel like it.
Postby Mr Wazzock » Tue Aug 22, 2017 10:17 am
If it helps, my dealer uses semi for the first two changes, because he says full synth "is too good, you need to rub the rough spots off first". Full synth after that. I.e. 3rd change onwards. Made sense to me anyway.
HTH
Postby Peter Pan » Tue Aug 22, 2017 10:47 am
Friend Tony at Racewayservices put synthetic into my rig at 500km. I went back to mineral at 2500. It took until 18.600km after the second engine seize that the engine started to come free- Since 21.000km you could say the engine is running well.
At now 37.500km I still stick with mineral oil in the engine for to keep motor brake, as the experience for those 2000km with synthetic showed that the bike would push downhill like a 2 stroker.
As long you feel with each oil change that the bike performance improves stick to mineral oil in the engine. Probably 15.000km or more will pass by then.
For transmission and FD I use synthetic with the result that Sophie marks her terrain from there.
Sven
Sophie Travelair
Patrol 2013 a Jim Petitti special.(RIP)
8 weeks 12.000km Oregon - Alaska - Oregon, now in CR 39.000km and counting.
With a DIY foam air filter the rig runs well even in tropical rain. The air box looks then like an aquarium. :moto:
Final drives: 1. at 5000km, 2. at 34.000km(+friction plates)
Return to “Oil Threads”
Users browsing this forum: No registered users and 2 guests
