help identify this fluid
thecrumb
Postby thecrumb » Mon May 30, 2016 11:34 am
Doing my first fluid change - 2012 Patrol.
Rode it around the block to warm up - dumped the motor oil - looked fine.
Moved back and popped the plug on the gearbox and got this:
????? :shock:
It doesn't appear to be contaminated oil. It's more creamy... some sort of synthetic??
Question - can I just dump some 20w50 in and let it fly.
Should I fill it with oil - run it a bit and then change again?
Should I flush with something else first? :bs:
Inquiring minds want to know.
Jim
| Central NC | 2012 Patrol "Shambo" |
Please contribute useful info to uralwiki.org
"There's a big difference between kneeling down and bending over." ~ Frank Zappa
Re: help identify this fluid
Postby gobium » Mon May 30, 2016 11:44 am
Water gb got in at speedo connection
Good luck, ride safe.
Good bye all
made some great friends here
Postby chaos2 » Mon May 30, 2016 11:46 am
that's probably 20-50 contaminated with water. Runs down the speedo cable and gets into the transmission. Flush it at least once, then wrap some rubber around where the cable enters the tranny. Don't ask how I know this.
Raceway needles
Modtop exhaust
thecrumb
Postby thecrumb » Mon May 30, 2016 11:49 am
Thanks guys!!
Jim
thecrumb
Postby thecrumb » Mon May 30, 2016 12:32 pm
I was questioning Gobium's lack of Ural knowledge :lol: but now that it's been sitting the oil and water are separating a bit and it's turning more tan color. I think you are right!
Who... what... why would they run the cable that way!!! :blink:
Off to get some more oil and see if I can find a rubber boot of some sort to fit over that.
Jim
Postby gobium » Mon May 30, 2016 12:41 pm
Drain your carb bowls too.
Good bye all
Buckhorn
Postby Buckhorn » Mon May 30, 2016 12:58 pm
Some of this would work. I used to use coax seal from Radio Shack to seal my ham radio cables.
I think this is the same.
http://www.homedepot.com/p/3M-Scotch-1- ... /202195402
2013 Ural Gear Up Gobi camo
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
Postby GHGoodwin » Tue May 31, 2016 7:14 am
Try a straight spark plug boot. You'll probably have to slide it on from the handlebar end. The plug end might just be coaxed over the block connector. Haven't tried this. Just thinking at the keyboard.
Return to “Oil Threads”
