Oil Pump Shaft Connection: Question
jrvb
Postby jrvb » Mon May 02, 2016 9:06 am
Ok, just removed the oil pump and gave it a bit of a clean. If you look at the photos, you will see a centre piece , which is about one inch long with two eyes in it, the left eye holds it on to the main shaft that goes up it to the engine, and the other one of the right, fits onto the oil pump fitting, which you can see sicking out.
So my question is, does this just shove on as seen in the photo, or should it be permanently connected to the pump, just like the other end - or doesn't it matter.
Cheers Jeff
Jeff Roberts
1967 KMZ K750
Manchester - UK
http://www.jrvapourblasting.co.uk
Re: Oil Pump Shaft Connection: Question
Postby rivers » Tue May 03, 2016 1:35 pm
I haven't been that deep into a IMX/KMZ motor but suspect it'd just be a slip fit. If the long pump shaft required a set screw, is there even working room to install a screw with the pump mounted? Not sure on a KMZ but doesn't pump mount from below and the shaft drop in from the top?
jrvb
Postby jrvb » Tue May 03, 2016 2:27 pm
Yes, it does fit from below. But I was just asking whether it should be connected like the other end. After all it does have the indentations just like the other end.
The way it is doesn't effect the operation in anyway by just slotting onto the pump, I was just asking if it should be fixed.
Cheers Jeff
Jeff Roberts
1967 KMZ K750
Manchester - UK
Postby rivers » Tue May 03, 2016 4:25 pm
I don't see any sign in the stub shaft divit a set screw was ever used. A good clue would be if the long shaft collars hole is threaded? I'd suspect it's a drop-on slip fit. Can't see where a set screw would be needed or even desired. 1967 huh? If it's been working fine for 50 years just slip fitted I wouldn't suspect a design flaw.
wyowillys46
Postby wyowillys46 » Sun May 08, 2016 2:00 pm
Just took a look at the pump out of my flathead. I believe they are dimpled into the divot on each shaft with a press. It's intended to be a flexible/wobbly coupling. Drill the end of the oil pump shaft to a slightly larger diameter and drive a tight fitting pin into the coupling and through the pump shaft.
Morgan
'06 Gear-Up
195? M72/K750 hybrid
Return to “Oil Threads”
