Car oil vs motorcycle oil?
Norm
Re: Car oil vs motorcycle oil?
Postby Norm » Fri Nov 06, 2015 6:13 am
[youtube][/youtube]
camo wrote:Ive heard we should use mineral oil in the engine due to the ball bearing crank ?
Camo, I use cheap 20w 50 mineral oil in Speedboat & Penrite 15w 60 fully synthetic in Squib. Speedboat is now a fairly high mileage bike, and has been using cheap mineral oil since new. Squib has used the Penrite oil since its first service. Urals have roller bearings on the crankshaft and a low pressure oil pump.
Both work well, and both are used by many Ural owners.
The only oil I'm not prepared to use is 4T motorcycle oil because our bikes have dry clutches, and normal automotive oil is specified in the owners Manual. But many owners use it without any issue.
Norm; Adelaide, South Australia
2009 Ural Tourist "Speedboat"
2010 Ural Tourist "Squib"
2004 Bonneville America
thumper05flstsc
Postby thumper05flstsc » Fri Nov 06, 2015 6:33 am
I am not going to go out and look it up but I am pretty sure the Manual that came with my Rig recommends Castrol 20W 50 GTX.
Forrest fog 2013 Gear Up. "IT"........GONE Replaced with an Indian Springfield.
"Treat me good, I'll treat you better. Treat me bad, I'll treat you worse" (SB)
hillbillybob
Postby hillbillybob » Sun Nov 08, 2015 8:44 am
I vote for truck oil....HD diesel oil to be exact. And with Ural's recommended change interval of 1550 miles.....I sure won't be urinating my money away on synthetics.
2006 Ural Troyka "Boris" (38/125 out, 40/135 in, much better)
2000 BMW R1200C "Schultz"
1999 BMW R1200C "Dooley"
2011 Chinese 150cc Scooter "Johnny" (13,620 breakdown free miles)
barnone
Postby barnone » Sun Nov 08, 2015 10:50 am
Yep, Castrol 20W 50 GTX is what Ivan recommends.
Lee Pape
Postby Lee Pape » Sun Nov 08, 2015 6:11 pm
hillbillybob wrote:I vote for truck oil....HD diesel oil to be exact. And with Ural's recommended change interval of 1550 miles.....I sure won't be urinating my money away on synthetics.
When I can find it around these parts I have always used 20W-50 diesel oil in my Ural. It has a better additive package then the newer car oil do. More zinc for one.
nbsdave
Postby nbsdave » Mon Nov 09, 2015 5:33 pm
barnone wrote:Yep, Castrol 20W 50 GTX is what Ivan recommends.
and last I heard, that's car oil.
keep your word, no excuses
Ural-it's not just another motorcycle!
2011 Ural T, now only a memory
Postby Msblu79 » Tue Nov 10, 2015 10:49 am
Use SH rated motorcycle oil only, do not use the newer car oils as they do not contain enough of the wear additives that an AIR-COOLED engine needs. Heavy doses of magnesium and moly are needed to protect hot running air cooled engines and oils meant for water cooled cars have a completely different makeup. Oil is not just oil anymore, they are formulated exactly for their intended uses. :foilhead:
2010 Black Patrol
BillyG
Thread Killer
Thread Killer
Postby BillyG » Tue Nov 10, 2015 5:46 pm
That sir is an old wife's tale. Sort of ;-)
Bill Glaser
2002 Ural Patrol "CYKA"
Postby rivers » Wed Nov 11, 2015 7:21 pm
It's a Ural not the space shuttle. Don't over think this. By all means "put oil in the motor".
tonered
Postby tonered » Wed Nov 11, 2015 10:58 pm
Very true, Joe. At the old 2,500km interval, dish soap would probably worked in a pinch. Ha!
That said, synthetic feels better to me given the heat and the amount of oil smoke that comes out my breather. Since the bike went out of warranty, I've upped the interval to a more reasonable 5,000km.
I was looking for a cheap oil for a short run in my other bike. I was shocked to see how much dyno oil was. Store brands are even getting up there. Synthetic is hardly a premium, about $1/qt more. Not a big deal when you consider what even the cheapest oil is at a motorcycle shop.
Gone are the days of my youth and $1 quarts of good stuff.
As I said originally, I like the additive content of diesel oils for our flat tappets.
Have a good one.
tony b
Lynnwood, WA
2013 GearUp (Taildragger)
2001 Duc ST4 (Thumper)
GillaFunk
Postby GillaFunk » Thu Nov 12, 2015 1:34 am
When the ural engines came out back in the 40's, was motorcycle oil offered?
(It's a rhetorical question)
Sgt. USMC 0311, 8156
planeflyer21
Postby planeflyer21 » Thu Nov 12, 2015 8:07 am
GillaFunk wrote:When the ural engines came out back in the 40's, was motorcycle oil offered?
Yes.
But you had to press several motorcycles to get a quart. :lol:
Jon
2Tim2:15
BMW 1983 R80ST Project
GillaFunk
Postby GillaFunk » Thu Nov 12, 2015 1:01 pm
lol
Ragmanx1
Postby Ragmanx1 » Thu Nov 12, 2015 10:07 pm
I use of 20/50 Castrol 4T motorcycle oil in my engine.
Plenty of ZDDP and zinc lube additives, required for these old design engines.
And the beat goes on..............................
SteveG
2012 Ural Patrol
Michal
Postby Michal » Fri Nov 13, 2015 6:02 pm
I use car oil all the time. I prefer car oil for high load turbocharged engines as it's better for high local temperatures of air cooled engine. Motorcycle oil is designed to work with wet clutch and gearbox, not a case for Ural. After all, Ural is low stress low power simple engine designed to work with Russian oil - tapped right off the oil well pipe with barely any additives.
Михаил
2005 Урал 750 Спортсман (2WD)
Return to “Oil Threads”
