Car oil vs motorcycle oil?
BikerMage
Postby BikerMage » Thu Nov 05, 2015 12:20 pm
Would it be safe to use normal car oil in these Urals? Does anyone?
The reading I've done on the subject tells me that friction modifiers in car oil don't play well with wet clutches, hence the biggest difference between oils. But if the Ural is a dry clutch, that shouldn't matter, right? Of course, then it becomes a question with the transmission, and I have 0 experience with a separate transmission.
Maybe someone here can enlighten me.
Previous bikes:
1981 Yamaha XS1100 (full rebuild, really fun)
2005 Suzuki Katana (we all make the crotch rocket mistake once, right?)
1982 Yamaha XJ750 (lucky enough to have my wife buy me a bike)
1984 Honda Goldwing
Re: Car oil vs motorcycle oil?
Postby rivers » Thu Nov 05, 2015 12:43 pm
Car oil is fine. Just use a quality brand name oil that meets required specs. FWIW I run Castrol 20w-50 in Urals and many other bikes. Never an issue with the motor or trans.
MartyL
Benevolent Emperor
Benevolent Emperor
Postby MartyL » Thu Nov 05, 2015 12:50 pm
NO!!! Do not use car oil in a motorcycle... Don't screw around with this....
1976 Yamaha XS650C
2015 Yamaha FJ09
Postby Wildhorse Cafe » Thu Nov 05, 2015 12:59 pm
Why take the risk?
barnone
Postby barnone » Thu Nov 05, 2015 1:46 pm
What do you run in a Volkswagen Beetle? Motorcycle oil?
tonered
Postby tonered » Thu Nov 05, 2015 2:00 pm
BikerMage wrote:Would it be safe to use normal car oil in these Urals? Does anyone?
Ever since I started riding in 2006, I have always used synthetic automotive oils. I even once used a 5w oil with friction modifiers in a wet clutch. Not a single problem.
Until recently, my drug of choice was Mobil1 15w-50, bought in a 5qt jug for a bit over $20. A few years back after many good reports, I've switched to Rotella T6 5w-40, a bit over $20 for a 4qt jug. I use it in everything, our cars and my bikes. I transitioned the Ural to T6 after the warranty expired.
The big difference between "motorcycle" oils and typical light weight automotive oils is the additive package, where with the excellent metallurgy of new motors, the additive package has been reduced for environmental reasons. M1 and T6 are still classified as 'diesel oils' and T6 has the Japanese JASO rating for motorcycles. Motorcycle and diesel oil have a bigger additive package, esp in the zinc department (ZDDP) for flat tappet protection.
I prefer full synthetics oils to resist sludging and extreme heat, esp in m/c motors.
It makes me laugh when folks cough up almost $20 for a single quart of motorcycle oil. Research at bobistheoilguy.com shows (or at least used to / I haven't looked in a couple years) that oil analyses are not much different between diesel, heavy weight automotive, and motorcycle oils.
Have a good one.
tony b
Lynnwood, WA
2013 GearUp (Taildragger)
2001 Duc ST4 (Thumper)
BillyG
Thread Killer
Thread Killer
Postby BillyG » Thu Nov 05, 2015 2:42 pm
300K+ km on house brand automotive 20w/50 oil. Nuff said.
Bill Glaser
2002 Ural Patrol "CYKA"
Leftka
Postby Leftka » Thu Nov 05, 2015 4:58 pm
Your rig...do what you want...you'll get a lot of different answers here. I always used royal purple 20x/50 synthetic mc oil in the engine. It has additives that mc engines need, synthetics handle the heat better and the independent tests I read convinced me it was superior at protecting the moving parts. In the tranny I always used redline shockproof lightweight...better that motor oil and helped my tranny shift better. FD I always use redline shockproof heavy. Never had a FD issue, never had any engine problems and tranny shifts as smooth as a Russian gear box could be expected. Each of those fluid are very different in color too...can help you pinpoint a leak...if your rig should ever decide to mark its territory...all this IMHO.
Leftka
Naples, FL
128/40 Jets
Harmonized at 10" hg
K & N MG 200 Filter Element
7/64" Drilled Carb Slides
Parabellum Scout Fairing
Retro Lighting
repeat offender
Postby repeat offender » Thu Nov 05, 2015 5:49 pm
20w-50 regular dino works fine......The motorcycle oil ain't gonna hurt if you can get it. I use that in the Beemer. Urals are not so fussy.When in doubt, go to the manual. :wink:
George
1997 Valkyrie with Sidecar
Former rides...
'37 W
48 FL
57 G
53 K
77 FLH
62 FL
73 G
71 XL
07 PATROL
77 HONDA 500
1988 BMW R100GS.
BikerMage
Postby BikerMage » Thu Nov 05, 2015 6:09 pm
Thanks for all of the advice. I intend to use 20w-50 motorcycle oil, it was more of a curiosity than something I would actually do.
Previous bikes:
1984 Honda Goldwing
Postby rivers » Thu Nov 05, 2015 6:59 pm
That'll work, if specifically badged 'motorcycle' oil is your thing and makes you feel warn-n-fuzzy. My standard 'what oil' reply is: "yes by all means use oil in the motor" Keep it clean and up to proper level...you're golden. :thumbsup:
Tin Man
Postby Tin Man » Thu Nov 05, 2015 10:29 pm
To answer the title question...............Yes!
2007 GearUp (Arctic #1)
Postby chaos2 » Thu Nov 05, 2015 11:29 pm
ever notice MC spec oils usually cost more? I'm guessing it's more marketing than ingredients. And having a dry clutch negates the main reason for it. My step-son's Honda does fine on regular dino, so even that may not be that big of deal.
Raceway needles
Modtop exhaust
puttaround
Postby puttaround » Fri Nov 06, 2015 1:53 am
:lurker:
2001 Bavarian Classic--gone but not forgotten
1975 Yamaha RS100 "The Eternal Project"
2014 Maddog "chuckus" scooter
"The past is a foreign country: They do things differently there." --L. P. Hartley
Ти́ше е́дешь -- да́льше бу́дешь. --Ride slower, you'll get further. (Russian Proverb)
camo
Postby camo » Fri Nov 06, 2015 4:29 am
Ive heard we should use mineral oil in the engine due to the ball bearing crank ?
2010 Red October limited edition 1 of 4 in AU
2005 DL650
2001 GL1800
2000 TL1000S
1998 TL1000R
1998 GSX750R
Return to “Oil Threads”
