Carb won't stay seated
0ganos
Postby 0ganos » Mon Mar 14, 2016 7:42 pm
Last Friday as I was cruising down the back roads my right carb came unseated from the flange and it has not stayed in place since.
I have checked for leaks in the air delivery system and did not find anything obvious. replaced the stock air filter with a K&N. I pulled the plugs and the right one was fouled pretty well so I replaced those with NGK BP7HS the ones in there were BP7ES with the longer shaft (which I'm hoping did not cause any damage).
After cleaning out the carbs and changing oil because it was nearly due for the 2500K maintenace it will idle smoothly but as soon as I hit the throttle the right carb pops out of the flange.
The flange itself looks OK and I've taken care not to over tighten. Would that indicate that there are some "micro-cracks" in the flange and it needs to be replaced.
Thanks in advance,
0ganos
Dave O.
Re: Carb won't stay seated
Postby Albuquralque » Mon Mar 14, 2016 7:44 pm
When you say flange, what exactly do you mean?
Is the carb coming out of the compliance fitting (rubber piece between the carb and cylinder head)?
Or is the carb coming out of the branch tube (the rubber tube from the airbox down to the carb)?
0ganos
Postby 0ganos » Mon Mar 14, 2016 10:20 pm
The compliance fitting going to the cylinder head.
Although the branch tube can be a pita too
Dave O.
Postby wooden nickel » Mon Mar 14, 2016 10:33 pm
Did you clean both the carb and the compliance fitting? Any oil or residue on either will make them ornery.
When my compliance fittings cracked they still held together, but they leaked air.
Postby eastbloc » Mon Mar 14, 2016 10:35 pm
There should never be significant outward pressure building up in the intake tract.
Is it easy to pull the carb off without undoing the clamp on the flange? If not, check your valves. Maybe the left intake isn't closing all the way?
TerryG
Postby TerryG » Mon Mar 14, 2016 11:06 pm
The PO of my BC had to rebuild a head because he used a 3/4" reach plug instead of a 1/2". It bent a valve when it hit the plug.
Terry
2011 Retro
ichbinbier
Postby ichbinbier » Tue Mar 15, 2016 2:56 am
I had this happen to me last year on the left side. The branch tube has to be installed first with a bit of a twist towards the cylinder head, then the carb (or in my case throttle body) gets installed on the branch tube and then into the head. The slight twist towards the head pushes the carb/thottle body into the head.
2016 CCM GP450
2015 Kawasaki Ninja 300
2014 Ural Gear Up
Postby GHGoodwin » Tue Mar 15, 2016 7:41 am
Loosen all the clamps. Put the tube in place. Seat the carb end first and make sure its fully on by feeling along the underside. Make sure the carb clamp is on square after tightening. Too much pressure can cause it to squeeze off. Do the air box side last.
You might consider some perch rings. Raceway sells them. I made my set.
0ganos
Postby 0ganos » Tue Mar 15, 2016 8:02 am
Wooden Nickel:
I did not clean the compliance fitting but it seems to be seated firmly when I attach them. I will give it a going over though.
Eastbloc and Terry:
I'm concerned that it is the valves because of those spark plugs. Damn PO's! I'm also concerned about getting in over my head. If the valves are bent would a gear-head friend and the "Unofficial Manual" be sufficient? Besides the valves would there be any other parts that would possibly need to be replaced?
Dave O.
Postby eastbloc » Tue Mar 15, 2016 8:22 am
There's nothing to worry about. The valves are easy to service, but let's not get ahead of ourselves. The first thing is to determine root cause.
The valves are easy to check. Pull off the valve cover and watch what happens as you operate the kickstarter with the ignition off. It's easier to do this if you remove the plugs. Your problem may become immediately obvious, but if it isn't, use the standard procedure to check the valve lash.
Take the plug off the flywheel inspection hole and find the TDC mark. Each revolution of the flywheel will put the opposite cylinder at TDC. A valve that is fully seated at TDC will enable you to "twirl" the corresponding pushrod. If the pushrod does not allow you to freely rotate it with your finger, that valve is not fully seated at TDC.
Let us know what you find.
LRP
Postby LRP » Tue Mar 15, 2016 8:57 am
When mounting the carb or installing the intake tubes going to the air cleaner, you need to totally clean the mating surfaces of the
carb flange and rubber elbows with brake clean or alcohol. An oil mist from the crankcase breather system makes the parts slippery
and near impossible to clamp down.
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
19 previous motos
Brian Crean
Postby Brian Crean » Tue Mar 15, 2016 9:59 am
Loosen up all the hose clamps, center everything up, then one by one, tighten the hose clamps till they start to snug down. THEN STOP TIGHTENING. Do this to all the clamps, one after the other. Just snugged, not tightened. Then, go over all the clamps again, tightening each 1/4 to I/2 of a turn. Go down the road a few miles till it's warmed up, pull over and do a carb wiggle test. If loose, go another 1/4 turn. If you tighten too much, it's like squeezing an oily ball bearing, it's going to pop out. Make sure your surfaces are clean, and let the natural friction of the rubber fittings work for you.
0ganos
Postby 0ganos » Tue Mar 15, 2016 10:22 am
eastbloc wrote:There's nothing to worry about. The valves are easy to service, but let's not get ahead of ourselves.
That completely goes against my basic nature! I will take a few breathes when I get home and start diagnosing.
Thank you for all the replies everyone!
Dave O.
Postby Snakeoil » Tue Mar 15, 2016 10:27 am
Take the carb off, put your hand over the compliance fitting and have someone hit the starter button. If you have a valve leaking compression you will feel it trying to push your hand off the compliance fitting.
Easy-peasy.
Postby Lokiboy » Tue Mar 15, 2016 10:39 am
Raceway sells a "perch ring" I think it's called - extends the ring on the carb to allow the compliance fitting more area to snug against. I bought one and it does the job beautifully
70,000 km and counting
