JIC & 10AN (army/navy) fittings
Postby gobium » Mon Mar 14, 2016 12:16 pm
Who's here have expertise in jic and 10an .
Yes I Google it
but want to hear from members that actually use these fittings
Mothra35
Re: JIC & 10AN (army/navy) fittings
Postby Mothra35 » Mon Mar 14, 2016 12:43 pm
I don't have much experience with these fittings, but can order through "Russell" the JIC 37* with the hose "barb" type ends and sleeve. Mainly for aftermarket fuel or "oil cooler" trans cooler add ons for vehicles. Don't know what the "10an" is thou...
--2005 Ural Tourist--"Маня"
My U-Tube
Postby gobium » Mon Mar 14, 2016 1:00 pm
Oil.
what is 10AN equaling to JIC?
Postby gobium » Mon Mar 14, 2016 1:03 pm
These are AN fitting .
common in Summitt racing after market .....ect
Postby gobium » Mon Mar 14, 2016 1:31 pm
Never mind .
I found local co.that will machine customers fittings
for my oil cooler project .
Mothra35
Postby Mothra35 » Tue Mar 15, 2016 9:25 am
Sorry, Van, for the delayed response, I don't know the difference or equality of a JIC and 10an (never even heard of 10an) pretty much the ones you pictured are the ones I can get,,,in different angles and in blue and red. :cheers:
My U-Tube
flyboysidecar
Postby flyboysidecar » Tue Mar 15, 2016 12:14 pm
Hi Van, "AN" fittings are very common in aircraft use. Compression type fitting. Most aircraft compression fittings are 37 degree vs automotive 45 degree. Don't know about JIC.
Bob
flyboysidecar
Postby flyboysidecar » Tue Mar 15, 2016 12:17 pm
The hose in your photo looks like "AN" fittings and the hose just screws into the base of the fitting very tightly. They work fine and last for years with no leaks.
Bob.
Postby wooden nickel » Tue Mar 15, 2016 12:51 pm
JIC is 37 degree too. The only common use I know for 45 degree is propane and natural gas. Haven't messed with AN fittings but with JIC the number is the size in 16ths. So a #8 JIC is 1/2" & a #12 is 3/4". You can get the thread sizes for both from the McMaster Carr catalog. The couple sizes I looked at looked to be the same.
Mothra35
Postby Mothra35 » Tue Mar 15, 2016 2:14 pm
Here is what I could order or just go to your local NAPA
BK- 335-5402 10an 10ft..... $81.00
BK- 335-5355 OR 335-5356 .....RED/BLUE OR CHROME STRAIGHT 10AN FITTING $12.00 OR $17.00
BK- 335-5361.... RED/BLUE 45* 10AN FITTING $25.00
BK- 335-5366... RED/BLUE 90* 10AN FITTING $28.00
I can get other stuff too but that's the jest of it....not really trying to sell it to ya, but those are what I sell them for with the company I work for.
My U-Tube
Postby gobium » Wed Mar 16, 2016 6:57 pm
Mothra35 wrote:Here is what I could order or just go to your local NAPA
I got dozen make for $6 buckaroo each.
no set up fee. :wink:
Postby gobium » Wed Mar 16, 2016 6:58 pm
Try to put together a couple oil cooler kits for black market .
Mothra35
Postby Mothra35 » Wed Mar 16, 2016 8:18 pm
gobium wrote:Try to put together a couple oil cooler kits for black market .
Cool, yeah Napa is high Dollar :lol:
My U-Tube
jae
Postby jae » Thu Mar 17, 2016 11:20 am
If they'll work on the '14+ as well count me in for one.
Regarding the original question, the main thing I know about AN fittings is that they can get really expensive really quick. I've got a '71 C10 with a 383 LS1 that's being retro-fitted with an under-bed tank and fuel injection. The -10 AN lines and fittings for a return style system were going to be around $1,100, and that's "at cost" per my mechanic. :shock:
'14 Patrol purchased 1/9/16, OR 1.02 map, 497km on first engine. New engine, throttle bodies, throttle cable, rear brake pads/rotor, final drive and 2wd shaft u-joints as of 8/20/16. Mods
'06 Triumph Sprint (naked), '07 Hyosung GV650, '05 Hyosung GT650, '92 Honda Z50 (125cc now), '87 Yamaha Venture (naked, hacked rat), '04 Yamaha PW50 for the boy, '06 Suzi GSX-R 600 project
Postby GHGoodwin » Thu Mar 17, 2016 11:46 am
I've used AN fittings for years making brake lines. Never had a problem. You'll need to be careful about your tube end cuts and the initial seating of the tube end on the fitting. I have a small tool that you insert into the tube end before you put it on the fitting. The tool helps you check the end cut and slightly expands the tube for the fitting.
They can also be overtightened.
