Rocker arm question
blairbear
Rocker arm question
Postby blairbear » Sun Mar 13, 2016 4:50 pm
I went in to check a noisy valve sound on the right side ( tub) checked torque both sides,set valves l/s then to the r/s every time I came up to TDC. Something wasn't right the intake rocker was tight. After a few attempts to TDC, I loosed up the adjustment for the intake and found the rocker moving around very oddly. After a few attempts to remove the rocker shaft, I just pulled the whole assembly off.
What I found was the shaft had maybe .020 to.030 engagement in the top hole. In time had worn itself free. I think the shat was never installed far enough and the retaining screw was locked on the shaft instead of in the retaining slot. And somehow in broke the rocker arm bracket web.
Now for the questions, looking at the IPC it shows left and right brackets. Is that in reference to looking straight in on the head?
When I get the new bracket and install it, should the other two head nuts be loosened up and all four brought up together or can I just bring up the two to proper torque?
Thanks
Blair Turney
1206 Covie Drive
Dalton,GA
30720
Re: Rocker arm question
Postby Tomcatfixer » Wed Aug 10, 2016 5:34 pm
I broke the tub-side intake valve adjuster, so I guess I've got to remove the intake rocker to replace it.
Now I've got the same torque question.
Virginia Beach, Virginia, USA
Postby GHGoodwin » Wed Aug 10, 2016 6:09 pm
Loosen them all up. Proper torque is around 35 ft lbs, which is what I use, although there isa lot of discussion on this.
URAL CT
Postby URAL CT » Wed Aug 10, 2016 6:10 pm
On my 07, I was able to purchase just the valve adjuster cup & nut..BTDT :oops: Any of the Ural dealer should have 'em.
With regards to the rocker arm shaft (on my 07), it has a flat spot where the screw sits on preventing shaft rotation...dunno about the new ones. Also I shimmed the top & bottom of the shaft so the rocker striker arm (dunno what ya call it) is hitting close to the center of the valve stem. I get the shims from ModTop, I think he recommends .001" vertical play. I use the feeler gauge to set 'em.
CT
2007 Patrol
Plano, TX
n3303j
Postby n3303j » Thu Aug 11, 2016 1:09 am
Put the rocker shaft assembly on FIRST and bring those nuts lose to torque value. Then loosen and retorque the other side close to value (maybe 20 ft/lb all around). Now torque to final value in the normal pattern.
If you loosen all four nuts the head can shift in relationship to the gasket which increases your chances for leaks at the head gasket. Using the above method guarantees that the head stays in its original position on its gasket.
I'm one of the guys who uses and recommends 25 ft/lb as a final torque value. 50 million BMWs can't be wrong.
Crawford Sales Co.
Postby Crawford Sales Co. » Thu Aug 11, 2016 8:17 am
I would like to add a comment while we are talking about rocker arm assembles. Everybody assumes that the mounting surface of the assembly is flat. It isn't on a lot of them. What ever you torque them you are basically pulling them down flat to the surface of the head which is flat. This is not good because it will change the accuracy of the valve adjustment. Next time you have a rocker arm assembly off put it on the kitchen table or a known flat surface and see how bad it is. A 6 inch belt sander can be your friend if done correctly.
Terry Crawford
Crawford Sales
248-437-8107
http://www.crawfordsales.info
crawfordsales@sbcglobal.net
Users browsing this forum: zapedDog and 10 guests
