Final Drive Issues- Chapter 2
Re: Final Drive Issues- Chapter 2
Postby gobium » Mon Mar 07, 2016 9:32 pm
Scott got lucky no other damaged found
You will need new hub spline .
Good luck, ride safe.
Good bye all
made some great friends here
Postby gobium » Mon Mar 07, 2016 9:36 pm
Bolt
Good bye all
Postby gobium » Mon Mar 07, 2016 9:44 pm
Not going to bother extracting broken bolt since
I m not reusing hub spline
Good bye all
URAL CT
Postby URAL CT » Mon Mar 07, 2016 10:09 pm
The cursed broken bolt head at the ring gear. Must be an 07 FD :mrgreen: BTDT :P
CT
2007 Patrol
Plano, TX
Niteblues
Postby Niteblues » Mon Mar 07, 2016 11:14 pm
So where did the head of that bolt go? :?
I never knew there was a zerk fitting on that u joint! :oops: That's the "new" shaft style; mine originally came with a one piece shaft and no zerk fitting. I guess that's why I never bothered to look at it! :(
Scott
2004 Ural Patrol
Postby gobium » Tue Mar 08, 2016 1:21 am
New hub spline and better button bolt . Grade 12.9.
old bolts are 10.9 grade
Good bye all
Postby gobium » Tue Mar 08, 2016 1:43 am
I have all parts .hopefully change out u joint and bench test fd.....ship out Wednesday
Good bye all
WEGUNTER
Postby WEGUNTER » Tue Mar 08, 2016 5:15 am
holy smokes!!!!!!! you don't get faster service than that. way to go Van.
Niteblues
Postby Niteblues » Tue Mar 08, 2016 9:15 am
Van's the Man!
:bow:
Scott
2004 Ural Patrol
Roadking
Postby Roadking » Tue Mar 08, 2016 10:03 am
I love happy endings. :D
2001 HD Roadking FLHRI
Michal
Postby Michal » Sun Mar 13, 2016 5:17 pm
gobium wrote:Not going to bother extracting broken bolt since
Thread with the rest of bolt is in the ring gear...
I'm using 12.9 grade bolts too. Unfortunately one got loose after 20,000km. Perhaps Loctite glue failed. Fortunately a hole in the FD case could be welded.
Михаил
2005 Урал 750 Спортсман (2WD)
Postby VWK75S » Sun Mar 13, 2016 5:24 pm
Michal wrote:Perhaps Loctite glue failed.
That's why I use the bent over tabs.
2009 GearUp 135,000kms
2007 Retro 20,000kms
Niteblues
Postby Niteblues » Sun Mar 13, 2016 8:53 pm
Van made a very cool video of him testing my final drive. Checking the lash play, powering it with a cordless drill in an awesome jig, putting it in 2wd while running, then stopping it and running it in reverse probably faster than it has ever gone in use, and checking the heat of the case while doing all this.
Van had the video on his facebook page.
Scott
2004 Ural Patrol
propwash
Postby propwash » Sun Mar 13, 2016 10:48 pm
FYI, those will not hold any bolt from backing out.
Postby VWK75S » Mon Mar 14, 2016 5:19 am
From experience?
