Fuel Delivery-Petcock?
kneedrachen
Postby kneedrachen » Wed Apr 04, 2012 7:22 am
Morning All,
2 weeks ago, took the 2011 Patrol out for a long ride and ended up running incredibly low on fuel. Filled up and rode the remaing 20 some odd miles back to the Fortress of Fun.
Started up this morning, no problem. When I went to give some throttle, and let the clutch out, the bike died. Fired back up a few times, same thing, except it wouldn't idle veyr long. When the petcock is in the prime position, it will idle, but even WFO, I can't even get above 15 mph. I turned back around to the FoF and the bike sounds "strangled", as if it is being restricted.
I can't get much of an idle nor can I give any throttle in the "run" position, but can in the "prime" position.
This leads me to believe it is a fuel delivery issue and most likely the petcock. I'll postulate that since I ran low on fuel, a bunch of cr@p in the bottom of the tank is in the petcock, or when I bought fuel, there was garbagein there from the sediment in the undergroun tank.
All fuel lines appear in decent shape, all fluids are full, both heads heat up the same, equal exhaust pulses, etc. Is my train of thought logical?
Jdsova
Re: Fuel Delivery-Petcock?
Postby Jdsova » Wed Apr 04, 2012 7:34 am
Me thinks that there is a problem with the vacuum petcocks on the 2011 model.. there was a thread a whiles back on this. Mine(carb blowing off) turn out to be the petcock and the right (car) side valve adjustment (came loose). Petcock was replace free of charge from my dealer. Probly a EPA thing to get em in country...
I'm used to an old non petcock bike, so I went that route with my bike and never looked back. (I have the new vacuum petcock in a storage bag). The poping and farting (what little I had)I attribute to that petcock. To date, I haven't had to use my enrichers but once since then.. and I run stock jets...
later
Edit--I'm used to an old non petcock bike ....should of said...............-I'm used to an old non vacuum petcock bike
J Sova
Peace is that brief glorious moment in history when everybody stands around reloading~" Thomas Jefferson
[*]2014 BMW K1600GTL-E-[*] 2014 2WD Ural Red/October GU-[*]
Past mistresses 2 Urals + 9 previous 2w bikes Marion, Iowa
kneedrachen
Postby kneedrachen » Wed Apr 04, 2012 8:29 am
How do you control fuel flow without a petcock? I've had bikes that had simple on/off, on/off/reserve and on/off/prime and on/prime/reserve.
MartyL
Benevolent Emperor
Benevolent Emperor
Postby MartyL » Wed Apr 04, 2012 9:12 am
You could pull your petcock, clean it, and check all your fuel lines including your crossover. If you don't want your vacuum petcock, get a Yamaha manual one. The write up is on this forum. While your doing this it wouldn't hurt to drain your carb float bowls. Do this outside with plenty of ventilation and have a fire extinguisher near by. Safety first.
1976 Yamaha XS650C
2015 Yamaha FJ09
kneedrachen
Postby kneedrachen » Wed Apr 04, 2012 9:29 am
Marty,
That was my plan for the weekend,I've been searching and have not seen anything about problems with the 2011 petcocks :?
Ragman
Postby Ragman » Wed Apr 04, 2012 12:32 pm
My 2011 petcock did the same thing last month - it clogged up with gunk inside the tank, and even when cleaned it didn't deliver the fuel properly.. Changed it for the Yamaha 2GU2-24500-02 have had no problem since.
Милаж
I'm kind of broken now.
Gone Now:
2010 but New Yamaha TW 200
kneedrachen
Postby kneedrachen » Wed Apr 04, 2012 1:23 pm
I appreciate the reply, this may be the route I take. I'll do a search for the thread now. I called the MD Ural dealer, it looks like he doesn't want the work because I didn't buy the bike from him (I lived in NJ!).
Whatever, shame IMWA has to deal with people like this; it gives the Ural community a bad name.
pidgey
Postby pidgey » Wed Apr 04, 2012 4:37 pm
kneedrachen wrote:I appreciate the reply, this may be the route I take. I'll do a search for the thread now. I called the MD Ural dealer, it looks like he doesn't want the work because I didn't buy the bike from him (I lived in NJ!).
DIY, real easy to do. If I can do this job myself anyone can. :wink: Follow the instructions in the write -up. You can go with the 2GU cheaper, non chrome petcock if ya want.
http://www.sovietsteeds.com/forums/viewtopic.php?f=5&t=326
YAMAHA FUEL PETCOCK ASSEMBLY
YAMAHA OEM # 2GU-24500-02-00, 2GU-24500-01-00
FITS THE FOLLOWING MODELS:
XVZ1300 ROYAL STAR 1996-1999
2005 BMW K1200S with Hannigan SuperSport chair
2007 Suzuki Boulevard S83
2010 Patrol (the lemon) SOLD
Jdsova
Postby Jdsova » Thu Apr 05, 2012 6:54 am
kneedrachen wrote:How do you control fuel flow without a petcock? I've had bikes that had simple on/off, on/off/reserve and on/off/prime and on/prime/reserve.
Ooops your right, I stand corrected... I meant vacuum vs non vacuum where you have the on/ off/ res/ petcock on my post
J Sova
Swordsman
Postby Swordsman » Thu Apr 05, 2012 1:02 pm
Yeah, I don't get that. They must sell the more popular bikes there as well, correct? I can't see any TRUE Ural dealer turning down work. Seems like the ones that get a bad name around here always tend to sell Urals as a side show.
~SM
2010 Ural T with all the trimmings!
"Nothing is boring when you're wearing armor." ~Maxim Magazine
Postby Albuquralque » Thu Apr 05, 2012 2:00 pm
Just bought the 2GU model from my local Yamaha dealer, $25.
kneedrachen
Postby kneedrachen » Sat Apr 07, 2012 10:40 am
Nope, Ural is there only game.
Took apart the petcock, not obstructed at all. Fired it back up, same deal. I did notice that the right side jug gets significantly hotter than the left side and it happens rather quickly. I think I heard almost like a pinging sound on the right side. Valve adjustment due? I'm at 1400km.
Users browsing this forum: No registered users and 7 guests
