Not a good start, and a contest!
truax
Postby truax » Sun Oct 16, 2011 11:50 am
I picked up my new Patrol T on Friday. I w@$#ed and w@*ed it Saturday (don't worry i plan to get it plenty dirty). Saturday afternoon, a beautiful fall day, leaves peaking with color and five kilometers into it maiden voyage -- I'm pushing the bike.
My Ural is stuck in 4th gear and it simply will not drop out of gear. The clutch works, insofar as I can roll the bike when the clutch lever is pulled, and the sift lever moves (up and down) but it simply won't come our of fourth. It clicks shifter clicks like it wants to and is downshifting, the gear just won't release.
I'll be taking it to the closest dealer (200 miles away) this week - assuming I can get the bike on their schedule. My original dealer is even further away. To say I am frustrated would be an understatement. I have tons of bikes, with tons of problem, but never has a bike broken down in the first 5 kilometers let alone 5 miles.
So, before I take in for repair, here is your chance play, "What's wrong with the Brian's Patrol T." To enter you have to be as specific as possible.
I'm guessing some metal shaving, casting fragment has gotten in the wrong place. See-- not a good guess -- too vague.. Remember I've had it less than 48 hours and have driven it less than 5 kilometers so my first hand experience is limited.
Here it is your chance to prove how much you know and to become King of the URals -- or at least mine.
I'll make sure to post the diagnosis when it becomes known to me. As I have yet to get the shop manual, i assume this is a -- pull the engine and get deep in the engine type of repair? I know my limits, and I think this is clearly beyond mine at this point.
So there you have it, guess away...
Truax
2010 Patrol T
Former Bikes: 2009 Suzuki V-Strom (DL1000), 2008 Kawasaki Concours 14, 2006 Triumph Bonneville, 1977 Yamaha XS750, 1982 Kawasaki KZ440 LTD
cdscoot
Re: Not a good start, and a contest!
Postby cdscoot » Sun Oct 16, 2011 12:39 pm
Well that sure sucks! How about put it in gear and rock it back and forth a little whilse keeping a little pressure on the shifter? Other than that -others will give advise! :cheers:
Craig
2010 Patrol T
2009 BMW R1200RT
truax
Postby truax » Sun Oct 16, 2011 12:52 pm
cdscoot wrote:Well that sure sucks! How about put it in gear and rock it back and forth a little whilse keeping a little pressure on the shifter? Other than that -others will give advise! :cheers:
I tried that -- no joy. Thanks for the suggestion though.
Even though it just had come from the dealer, I checked and fluids are correct all around.
Truax
2010 Patrol T
cdscoot
Postby cdscoot » Sun Oct 16, 2011 1:04 pm
The shift lever is actually turning the shift shaft? Not loose or stripped? On another idea- how much thread shows on the bolt with the wire attached down by the reverse shifter? Does the neutral indicator light work when you were in neutral? Is the reverse lever in the foreword position?
Craig
2010 Patrol T
2009 BMW R1200RT
Postby windmill » Sun Oct 16, 2011 1:28 pm
Sounds like the shifter paw spring broke, probably the spring was bad which would explain why it failed so quickly. Another possibility could be the shifter quadrant broke free, but I'm guessing the spring is at fault here.
Actually the transmission is separate and can be removed without removing the engine. It is is very easy to work on http://www.myural.com/Gearbox%20Disasse ... sembly.htm , but at 5km You should make full use of the warranty.
MartyL
Benevolent Emperor
Benevolent Emperor
Postby MartyL » Sun Oct 16, 2011 2:00 pm
Just for grins, pull in the clutch and try to engage and unengage the reverse lever. Don't lose heart.
1976 Yamaha XS650C
2015 Yamaha FJ09
truax
Postby truax » Sun Oct 16, 2011 3:23 pm
MartyL wrote:Just for grins, pull in the clutch and try to engage and unengage the reverse lever. Don't lose heart.
I tried that too. Good idea though.
Looks like it's going in Wednesday.
Truax
2010 Patrol T
tiltman
Postby tiltman » Sun Oct 16, 2011 3:47 pm
I feel your pain. When they delivered my Tourist "T" in late June I rode it a few blocks and it died...pushed it home and the delivery guy replaced a fuse. Drove a few blocks and it died...pushed it home and the delivery guy took it back and they sorted it out back at the shop (bad signal light in the hack kept blowing fuses). Then I had to wait again for another delivery - waiting sucks. I'm over 3200 km and (knock on wood) she's running well.
Everyone says that IMWA stands behind their product and that they'll get it sorted out. But, the waiting is the hardest part. (tom petty had that right)
Kirk
2011 Ural "T"
Thermos
Postby Thermos » Sun Oct 16, 2011 3:56 pm
Dude, that is a bummer! :( Hope it gets sorted out sooner than later. I won't even venture a guess, as this must be agony :brickwall:
-Tom
Yogi Berra
2011 Orange/Silver Patrol
1977 R100S
1977 GL1000
former bikes-
2001 HD Sportster
1981 Honda CX500 Custom
Darkblood
Postby Darkblood » Sun Oct 16, 2011 4:54 pm
Bummer......Try a bigger hammer. :D
I agree it's probably the spring. I've had mine get stuck in the false neutral between 3 and 4 a few times but I just kick the lever harder and it pops into gear. I'm assuming you've tried to kick the heal like you were up shifting to make sure it's not partially engaged into 4th. Occasionally mine won't down shift until I kick the heal to upshift and release tension then she downshifts fine. Noticed this mostly when she was new and still cutting in the gears it's much better now at about 9,000km.
Also have you tried to shift it without using the clutch with the engine off of course?
cdscoot
Postby cdscoot » Sun Oct 16, 2011 5:36 pm
Darkblood wrote:Bummer......Try a bigger hammer. :D
Man how did yours get so screwed up? You're still under warrantee, better get it taken care of!
Craig
2010 Patrol T
2009 BMW R1200RT
Postby VWK75S » Sun Oct 16, 2011 6:16 pm
cdscoot wrote:Man how did yours get so screwed up?
Craig,
You haven’t met Mike yet. :lol:
2009 GearUp 130,000kms
2007 Retro 20,000kms
Darkblood
Postby Darkblood » Sun Oct 16, 2011 6:35 pm
Craig,
Ride it like you stole it! :wink:
Also Have you seen these roads? :lol:
My windshield cracked today when I hit a bump. Drilled a hole at the end of the crack to keep it from spreading and 5 minute epoxi and it's all good... :D
cdscoot
Postby cdscoot » Sun Oct 16, 2011 6:46 pm
Darkblood wrote:
Craig,
Yes - I am still recovering from those roads since August! My back and kidneys may never be the same! :shock: :lol: I should have been on the dirt instead !
Craig
2010 Patrol T
2009 BMW R1200RT
Darkblood
Postby Darkblood » Sun Oct 16, 2011 6:47 pm
cdscoot wrote:
Darkblood wrote:
Craig,
Then you know why the parts keep falling off. :lol:
