Repairing a 1996 Full Time 2wd Differential
mash3d
Postby mash3d » Sat Jun 18, 2011 7:07 pm
So now that I have the bike I'm starting into doing the repairs.
First is fixing the differential.
I know I could just replace it with a new one but I wanted to see what went wrong with the old one first.
May be fixing it is cheaper.
So below are pictures of all the steps I took in order with highlights
(this is mostly for me so I know how to put it back together.
My main questions are:
Where could the ball bearings have come from?
Are there any bearings inside the gear driven hub?
The Gear hub was brand new as of February.
I also found 3 small mangled springs that I guess were holding a seal in place.
Not any more.
There was also a lot of little flakes of brass.
I assume that was from the now missing brass washer.
I'd like to thank Dom C. For posting pictures of his disassembly as a guide.
https://picasaweb.google.com/1039368628 ... blyRecord#
Any ideas or tips I would appreciate
thanks
mash
001_Final_Drive_Disassembly by michael32766, on Flickr
002_Final_Drive_Disassembly by michael32766, on Flickr
003_Drive_case by michael32766, on Flickr
004_Final_Drive_case by michael32766, on Flickr
005_Remove_Spacer_Tube by michael32766, on Flickr
006_Remove_gear_hub by michael32766, on Flickr
007_Races for_needle_bearings by michael32766, on Flickr
008_missing_brass_thrust_washer by michael32766, on Flickr
009_remove_Small_ring by michael32766, on Flickr
010_remove_main_Ring_gear by michael32766, on Flickr
011_38_needle_bearings by michael32766, on Flickr
012_2wd_disassembly_4_screws by michael32766, on Flickr
013_Remove_Circle_Clip by michael32766, on Flickr
014_Lift_off_bearing_assembly by michael32766, on Flickr
015_Lift_off_Spider_gears by michael32766, on Flickr
016_remove_Splined_gear_hub by michael32766, on Flickr
017_removed_Splined_gear_hub by michael32766, on Flickr
018_remove_locking_cover by michael32766, on Flickr
019_remove_brass_locking_ring by michael32766, on Flickr
020_removing_brass_locking_ring by michael32766, on Flickr
021_removing_Spider_bearings by michael32766, on Flickr
022_Spider_housing_bearings by michael32766, on Flickr
023_Sun_type_gear_end_A by michael32766, on Flickr
024_Sun_type_gear_end_B by michael32766, on Flickr
032_bearings_Sun_type_gear by michael32766, on Flickr
025_Epicyclical_gear_end_A by michael32766, on Flickr
026_Epicyclical_gear_end_B by michael32766, on Flickr
027_Epicyclical_gear_End_C by michael32766, on Flickr
028_Spider_gear_housing by michael32766, on Flickr
029_Bearing_113 by michael32766, on Flickr
030_Final_Drive_Gear_Assembly_A by michael32766, on Flickr
031_Final_Drive_Gear_Assembly_B by michael32766, on Flickr
Note I took off the half moon bolts by accident. Put them back on for the photo
so they may not be lined up right.
033_Spring_ by michael32766, on Flickr
No idea but I found a few mangled ones like this inside the FD case
034_prop_Shaft_gear_ by michael32766, on Flickr
035_prop_Shaft_end by michael32766, on Flickr
1996 Sportsman/750 Engine
Why Wait? buy it broke :)
BillyG
Thread Killer
Thread Killer
Re: Repairing a 1998 Full Time 2wd Differential
Postby BillyG » Sat Jun 18, 2011 7:57 pm
New one, ha, ha. Cheap, ha, ha, ho, ho. Sportsman parts...ya find them on the shelf right next to the hen's teeth. Nice tear down, haven't peered into one of those in a while.
Good luck.
Bill Glaser
2002 Ural Patrol "CYKA"
mash3d
Postby mash3d » Sat Jun 18, 2011 8:32 pm
by a new one a meant a modern switchable 2wd. I can get one of those, not cheap but at least I can find one.
co_g30
Postby co_g30 » Sat Jun 18, 2011 9:52 pm
Mash, you did a great job recording your disassembly of the FD.
The springs are a mystery to me as I don't recall seeing any when I did this.
the brass bits I am sure are the missing thrust washer. there wasn't much left of it when I took the FD apart.
Did you check the bearings in the wheel hub?
How were the "teeth" on the driven gear hub that I replaced?
dom
CO_G30
2014 Ural Patrol "Scarlett"
1987 BMW R80 "Brigitta"
billtrek
Postby billtrek » Sun Jun 19, 2011 11:15 am
Call Gene at Holopaw. He has some parts for the Sportsman's drive.
Bill
1998 Ural Sportsman, Power Arc Ignition, Denso Alternator, R75 Muffler, 07 Front disc, Hagon shocks
2005 Suzuki M50
mash3d
Postby mash3d » Sun Jun 19, 2011 2:09 pm
Small correction this is a 1996 ural, with 750 engine.
Dom, I added some pics of the gears. The only thing that looks a little rough is the rear part of the sun type gear.
and that's only a couple of teeth.
Everything else seems to be ok.
The bearings that I can see seem to be fine.
Bill I plan on calling gene tommorow. Just need to figure out what i have to order.
co_g30
Re: Repairing a 1996 Full Time 2wd Differential
Postby co_g30 » Sun Jun 19, 2011 6:39 pm
Mash
so that's what you meant by mangled springs!
yeah, I remember some such spring, it went with the seal that seats inside the new driven gear hub or what you've got labeled in your updated pictures as "epicyclical gear", pics number 26 and 27.
so, at the very least, I'd replace that seal. That still doesn't explain the ball bearings you and I found though. :(
recommend asking Gene of Holopaw how many of that type seal there are, since you found more than one mangled spring.
dom
CO_G30
BillyG
Thread Killer
Thread Killer
Postby BillyG » Sun Jun 19, 2011 8:49 pm
Yep, all the circular springs are keepers which go on the inner, inside lip of any seal. They usually pop out due to improper installation (not using a mandrel/cone over a shaft that the inner lip slips over).
Gene was a little sparse on Sporty parts...but he's about the only game in town unless you find one laying around in someones garage...most likely in outter Uberkakmanistan :D
P.S. I never trust a mechanic that wears gloves or...God forbid...shooooooooooooooooes! :twisted:
Bill Glaser
mash3d
Postby mash3d » Sun Jun 19, 2011 9:50 pm
BillyG wrote:P.S. I never trust a mechanic that wears gloves or...God forbid...shooooooooooooooooes! :twisted:
What about underwear? :)
Unfortutanly I have to keep my place somewhat clean to get my rent deposit back.
But I am looking for a garage with attached house to move into, preferably owned by a good looking single woman,
Please send picture of garage. :)
So on installing the springs do you put the spring on the mandrel, flip the seal up over the mandrel
And then slide the spring down into place? I assume so you don't end up stretching the spring?
Thanks,
Mash
BillyG
Thread Killer
Thread Killer
Postby BillyG » Sun Jun 19, 2011 10:52 pm
Whitey tighties are optional. Dickie coveralls a must. No self respecting home Russian motorcycle mechanic leaves home without'em :wink:
Nope. Spring is installed in seal out-o-the-box. Make a a mandrel/cone out of a cut, rolled piece of plastic bottle (your choice), slip the mandrel/cone down on the shaft, spray some silicone or apply thin layer of grease to mandrel/cone. Slide seal down cone over offending splines and such and lightly seat (or fully as the case may be). Hold seal, slip mandrel/cone out and seat seal. Spring should stay put. What pops the spring out of its lip is the inner seal rolling over (no lube) or any rough surface (splines) catching lip or spring allowing/forcing it out of its groove in the seal. Just stick it back in (a little grease on four corners will help hold it in the seal if popping out is a problem) and try again.
Some springs are loose fitting and the spring can be "unscrewed" (look closely and you can see where the two ends meet) and the large end (not the end that screws/fits inside the other) can be trimmed by a couple of coils to tighten it. I do not recommend you do this except in an emergency (1,000 miles from anywhere...in a desert...with cannibals closing in and or buzzards circling) as you can bugger the spring or make the lip/inner seal too tight causing premature failure. Always grease the inner lip of new seals to help them bed-in on the spinning shaft.
Your spring goes inside the seal in pic 26...drops in...fits in a groove around the inner dia.
See my sight below for pictures of how to install this type of seal with a home made mandrel.
Bill Glaser
mash3d
Postby mash3d » Mon Jun 20, 2011 7:51 am
Thanks for the info Bill
I'm being unusually dense this morning and I can't find the pictures your referring to on your site.
What chapter, or section are they in?
Thanks
BillyG
Thread Killer
Thread Killer
Postby BillyG » Mon Jun 20, 2011 9:30 am
Ummm...try chapter 7, section 7.7(j)...I think...maybe...but don't bet on it!
Bill Glaser
mash3d
Postby mash3d » Mon Jun 20, 2011 1:34 pm
I think I found the source of the mystery bearings.
One thing I did not take out of the Final drive housing was the prop shaft.
So I started taking it apart and noticed it had a lot of play in it.
Took it out and the balls form the bearing fell out.
And they were the same size as the mystery ball bearings.
When I bought the bike Dom was nice enough to send me all the spare parts he had. Including replacement ball bearings from his previous build. I took a look at them and notice the ball bearings there were a Double row set.
Checked the parts diagram and it was item 19-34 Part # N72052-2 ball radial -Thrust Double row
So the old bearing was missing an entire row of bearings and the, what looks like brass, housing for them.
I think the bearing fell apart and got chewed up by the prop shaft.
Which explains the balls and brass flakes all over the place.
036_bad_prop_Shaft_bearing by michael32766, on Flickr
I also notice the u-joint shaft was stiff in one direction. Not sure if it's supposed to be like that or not.
If not that may be what casued the failure of the bearing.
On the old bearing the inside housing was made of brass. On the new one it looks like polymer or something.
it's the off tan color on the new bearing. Is that right?
I'm thinking about replacing the prop shaft U-joint. Is there a better after market one that will work? that has a zerk fitting. Or should I just order the stock ural one?
Once I have that and a few other parts I'll start putting it back together.
thanks
mash
mash3d
Postby mash3d » Sat Jun 25, 2011 5:37 pm
Ok I got most of the parts I need. I forgot to order the gear driven hub thrust washer, Splined gear hub thrust washer,
and Rubber Collar seal.
So I have to call Gene back on Monday and order those.
Before I do a few questions have come up.
if any one can help answer them I'd appreciate it.
Take a look at the pictures and the questions below them
These bolts are starting to round off. I'd like to replace them but I've read that they are grade M8 bolts and could be replaced with better Grade M10 bolts. Does anyone know a source and part number and size for them?
Any idea how to get the middle black seal out and replace it?
Does the silver ring come off?
Also there is a lose tube inside, Is there anything else that goes inside? Just wondering if anything came lose or if it's supposed to be like that?
now on the next question I screwed up and forgot to take photos when I took this part off.
Now I can't remember which way the seal goes?
Does the middle black seal go in.....
Direction A?
037_Seal_Direction_A by michael32766, on Flickr
Or Direction B?
037_Seal_Direction_B by michael32766, on Flickr#
Thanks,
Mash
JPanyon
Postby JPanyon » Sun Jun 26, 2011 12:59 am
The seal's center surface appears to have a beveled lip. If so, and it matches the beveled surface of the lip in the hub opening, I'd say "B" is the answer.
Just a guess.
Best Wishes
John Panyon
John Panyon,,,Biking since 1961 on wheels left behind but never forgotten
1948 Indian Chief, 1954 Harley Police Special, 1965 BSA Rocket Lightning, 1972 BMW R75 /5, 1975 Norton Commando, 1977 BMW R100 /7 with "Unobtanium" accessories
2002 Ural BC 1st year 750, my unofficial pickup truck for delivering groceries to the disabled.
My Hack Monkey, (rescued from an Animal Shelter).... https://youtu.be/p7pC38IvvoM
