Snowmen & Other Stuff
Postby stagewex » Wed Sep 13, 2017 10:13 pm
Couple months ago when I changed all my U-Joints I spent enough time on my back under the rig to notice that my Snowmen were looking sad. There was some minor spider-crazing and cracks. With my next order of spares from Crawford's I had Terry send me two new snowmen. Sitting in the garage for a month before I also ordered a pair of Helper Springs from Van (Gobium).
Summer-like weather today and I was off so:
Had these sitting around for awhile.
Ten (10) years old. Not critical but for a mostly garaged motorcycle a little surprising. Does take a lot of shock.
I didn't have any silicone like Van use's in his video. But I had some silicone chain lube that worked excellent. The Helper Springs slipped right into the new snowmen.
All done and good for another 10 years.
2007 Ural Patrol, 2006 Yamaha TW200, 1995 BMW K75, 1969 BMW r60/2US
Re: Snowmen & Other Stuff
Postby stagewex » Wed Sep 13, 2017 10:30 pm
The other stuff:
Noticed the valve on the pusher was getting sideways. Probably slipped the rim while lower deflation off road. Then filled it and it has been wrong since.
Deflated the tire and used a carpenters clamp and rubber mallet to break the bead. After loosening the valve nuts I put it in 1st gear and was able to rotate the tire on the rim until the valve was straight.
Tightened the nuts and inflated to 40psi. All good.
I also went for a short ride to heat up the FD, dropped the fluid and changed. I did the engine and gearbox oil on Saturday and didn't get to this yet. I also did this a couple months ago and found water had entered the FD making the fluid milky-like, like a Guinness Black & Tan. Another side effect of playing in the water.
Came out nice, thin black this time as it should be, pretty clean. She got a nice bottle of new 80/90 nectar. Then went for a nice long ride.
Postby Snakeoil » Thu Sep 14, 2017 10:30 am
In addition to UV, Ozone is also an enemy of rubber products.
Postby stagewex » Thu Sep 14, 2017 7:42 pm
Those snowmen do take a shock-load beating and are probably the most unloved parts on a Ural.
I don't know what they are really made of but I have some original rubber parts in better condition on my r60/2 and that bike is almost 49 years old.
roscoau
Postby roscoau » Fri Sep 15, 2017 4:29 am
What are the dimensions of these springs? Length and OD?
stagewex wrote:
2009 Tourist with the chair on the left where it should be...
Urals in Australia
Lee Pape
Postby Lee Pape » Fri Sep 15, 2017 9:58 am
gobium has them custom made by a spring maker he knows.
But, together we have it all.
Postby stagewex » Fri Sep 15, 2017 2:12 pm
Go here for Gobiums initial posting:
viewtopic.php?f=4&t=48037&hilit=snowmen+helper
roscoau
Postby roscoau » Sat Sep 16, 2017 5:23 am
stagewex wrote:Go here for Gobiums initial posting:
http://sovietsteeds.com/forums/viewtopi ... men+helper
Thanks for that, I've dropped him a line...
Urals in Australia
Return to “General Hammerin' and Wrenchin' (all model years)”
Users browsing this forum: No registered users and 9 guests
